What is the name of this part?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Snowbrdr1220, Mar 28, 2014.
  1. Mar 28, 2014 at 12:40 PM
    Snowbrdr1220
    Snowbrdr1220 [OP] Well-Known Member
    PA
    13 DC TRD Off Road NBM
    So after a trip to the dealership for a free oil change; I noticed that the little black rubber cap under the oil filter gutter drainage system was never put back on. (The little rubber cap you pull off before putting a bottle under the filter drain system) I've tried searching Tacoma World and Google under every possible name I can think of like: "tacoma oil filter drainage cap", "tacoma oil filter drain plug", etc. Does anyone know what it's officially called? Or where I can buy one from?
    Also, should I even be worried about not having it? Seems like it might prevent oil from dripping out of the filter drain system after an oil change. But not sure if I should even worry about it or not, what do you guys think? Does everyone still have one on your truck?
  2. Mar 28, 2014 at 12:42 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    nope
  3. Mar 28, 2014 at 12:44 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    I wouldn't worry about it nor replace it...I'm at 130,000 miles and haven't had it since the first change. It's just to release the oil in the filter anyways when doing the oil change.
  4. Mar 28, 2014 at 12:49 PM
    Snowbrdr1220
    PA
    Cool, thanks guys! I was actually thinking it might be better to not have it on. In case I ever just throw the oil catch bottle under there and forget to take that cap off.
  5. Mar 28, 2014 at 12:50 PM
    95 taco
    95 taco Battle Born
    This^
    when draining the oil from the filter take some flexible rubber line (like fuel line) and put one end on the nipple, and the other in the oil pan, no oil will drip on parts that way.
  6. Mar 28, 2014 at 12:53 PM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
  7. Mar 28, 2014 at 12:55 PM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    Part # 9033907016
    Also used as a plug somewhere on the intake.
  8. Mar 28, 2014 at 12:56 PM
    jessandjamie
    jessandjamie Well-Known Member
    Arizona
    Its nothing more than a glorified vacumm cap. If it really bothers you go to an autozone and look for the vacumm line caps. They come in all kinds of sizes.
  9. Mar 28, 2014 at 1:21 PM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    I took mine off because when I clean my engine the water doesn't drain properly and causes corrosion inside the oil catch.
