What is the point of S mode?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoManTaco, Jul 31, 2020.
  1. Jul 31, 2020 at 8:32 PM
    TacoManTaco
    TacoManTaco [OP] Well-Known Member
    I don't understand the reasons behind using it. I know it locks out the higher gears but i dont know when you would want to use it.
  2. Jul 31, 2020 at 8:36 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Trailer pulling.
    Dirk Diggler, Frito, Chew and 10 others like this.
  3. Jul 31, 2020 at 8:38 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Engine braking.
    Dirk Diggler, BRFab, mallege and 4 others like this.
  4. Jul 31, 2020 at 8:42 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Down hill towing.
  5. Jul 31, 2020 at 8:43 PM
    mchertel
    mchertel Well-Known Member
    Mark
    Colorado Springs CO
    2020 Tacoma Off-road
    Toytec 2 inch boss lift
    All the time to keep the RPM’s in the power band. Also helps tremendously when driving in the mountains. And while 4 wheeling so the truck doesn’t shift when you don’t want it to.
    slvrtaco11, cryptolyme, jc63 and 9 others like this.
  6. Jul 31, 2020 at 8:44 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    Need more play time!
    Skydvrr likes this.
  7. Jul 31, 2020 at 8:51 PM
    TacoWdrd
    TacoWdrd Well-Known Member
    Shane
    Ohio
    2019 MGM TRD OR
    Yeah it ain’t no Ferrari peddle shifter but it has its place :thumbsup:
    E-Paz 732NJ and Truks4elk like this.
  8. Jul 31, 2020 at 8:52 PM
    TacoWdrd
    Shane
    Ohio
    2019 MGM TRD OR
    Peddle... pettle... paddle :drunk:I’m lost
  9. Jul 31, 2020 at 9:14 PM
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    19 TRD SPORT TACOMA / 21 LIMITED RAV4
    this and that...
    simulated manual transmission :laughing:
    4x4spiegel likes this.
  10. Jul 31, 2020 at 9:16 PM
    StayinStock
    StayinStock Pepsi > Coke
    Bob
    Missouri
    Yes I do
    Some
    To keep from being in 6th gear at 35mph.
  11. Jul 31, 2020 at 9:18 PM
    Bishop84
    Bishop84 Well-Known Member
    Tunnels.
    Hills.
    Towing.
    Racing.
    Offroading.
    Onroading.
    Voting.
    Overlanding.
    Underlanding.
    Volcanos.
    Dynos.
    Car Soccer.
    Hobbs, Rock Lobster, AKGSD and 13 others like this.
  12. Jul 31, 2020 at 9:29 PM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    I use it whenever merging on a freeway especially if it's a short on ramp and i need to build up speed quick, i put it in s and shift to 3rd. Huge improvement over just mashing on the gas in d
    TOMRR and Jojee117 like this.
  13. Jul 31, 2020 at 10:47 PM
    sparechange
    sparechange Well-Known Member
    Snoqualmie, WA
    2016 DCSB OR
    second hand lift, fuzzy dice
    was a lot of help teaching my 11 yr old to drive
  14. Jul 31, 2020 at 11:03 PM
    toucan
    toucan Stupid truck
    Sam
    Oregon
    2013 DC offroad MGM. 2012 Super White SR 4x4 RC
    SCS/Bilstein/Icon/JBA/ Relentless/ATH/Smittybilt/Meso/Mobtown/Archive Garage/BAMF/Pioneer/Rockford Fosgate/Sundown/Wet Okole/Spiker Engineering/I'mMr.Yo/RAMMounts/Softopper/Weathertech/Factor55/Morel/DD
    CB Tag
  15. Aug 1, 2020 at 4:55 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    From what i've experienced from this 3.5 motor after coming from a 4.7 v8 engine braking is nearly non-exsitent on this v6. If i go down the same hill in 4th gear with my taco it will run at least 10 mph faster than my tundra did in 4th. Pretty sure both trucks had the same final gearing.
  16. Aug 1, 2020 at 6:09 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    It's an additional step, just ignore if you have no use for it.
    I use it when towing and off-roading.
  17. Aug 1, 2020 at 6:10 AM
    Tacospike
    Two Trucks
  18. Aug 1, 2020 at 6:19 AM
    TacoMamba35
    PNW
    Yes, I agree - the engine braking in this one isn't great. I suspect this has a lot to do with the VVT and simulated Atkinson cycle.
    That said, I find S mode most useful when descending a large hill or steep mountain trail while using 4LO. What's weird is, the engine seems to be programmed to change the valve timing from atkinson to otto cycle around 2500 rpm to maximize engine braking. You'll notice a huge difference in engine braking power, exhaust tone, etc at that point. The annoying part is, it seems to bounce back and forth between the two valve profiles, making you go fast, slow, fast, slow. My brakes still thank me though!
    AKGSD likes this.
  19. Aug 1, 2020 at 6:21 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I like it for saving the brakes going down large hills/mountains. The problem is the other traffic doesn't like to run that way so I have to use my brakes anyway.
    cryptolyme likes this.
  20. Aug 1, 2020 at 6:27 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Is it it present in S3 or below?
    Could be the torque converter going from slip to lock, back to slip.
    Hobbs and TacoMamba35[QUOTED] like this.
