What is the purpose of the 2024 MT having less power than the auto!.
Discussion in '4th Gen. Tacomas (2024+)' started by Sandthemall, Dec 3, 2023.
  1. Dec 4, 2023 at 11:32 AM
    2001 4x4
    2001 4x4 Well-Known Member
    2008 TRD Offroad 6MT
    Long overdue for that update! Now we won't be able to go 80mph in reverse! ;)
    Junkhead and shakerhood[QUOTED] like this.
  2. Dec 4, 2023 at 11:33 AM
    TurboDA6
    TurboDA6 Well-Known Member
    Nothing to do with driveline strength.
    More to do with emissions. It's much easier to control emissions on an automatic vehicle because the ECU and TCU can work together to keep emissions as low as possible as the two systems know what each other are doing. The way revs change during gear changes, sudden declutching, etc can have a big effect on emissions. That's why modern vehicles with MT have suffered driveability complaints usually centered around rev hang and rev limits, which is done for emissions.
    Might also be that Toyota wanted the most refined engine/trans tuning possible, shouldn't be a surprise that slightly different tunes will work better with different trans options. It could be that the MT tune just feels better than keeping the AT tune.
    The bigger bummer about the Tacoma MT is the ridiculously low rev limit, which to me is the biggest indicator that it's done for emissions....
    TAC1 and TreeFortRichard like this.
  3. Dec 4, 2023 at 3:42 PM
    Sandthemall
    Sandthemall [OP] Well-Known Member
    Sandamal
    2023 TRD OR MT
    …what about those of us with sensitive skin…? ;)
    WilliamJames likes this.
  4. Dec 4, 2023 at 10:56 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Sheldon says it was for NVH reasons. Easier to just lower the redline than do anything else.
    TurboDA6[QUOTED] likes this.
  5. Dec 4, 2023 at 11:19 PM
    proudsource
    proudsource Active Member
    2023 OR 6MT IC
    getting the manual in the 3rd gen made a little more sense. first, by most reports the 6-speed auto shift logic is lame so you dodge that. second, the 3.5L V6 needs to be rev’d up to properly harness it and the manual allows you to do that regularly.
    if I were in the market for a 4th gen, I don’t think the manual would be very appealing. the new 8-speed auto will probably be adequately improved and the fact that not only can you not pair it with the highest powertrain option, but it is detuned (albeit marginally), would steer me away.
    another thing that bothers me is the electronic parking brake. a pull-up handbrake and a stick shift are like peanut butter and jelly to me, considering how often it is used versus mostly just shifting to P in an auto
    2001 4x4 likes this.
  6. Dec 5, 2023 at 6:22 AM
    specter208
    California
    Real manual enthusiasts don’t care about any of that.
    dneal, 6MTPro, Jeff Lange and 2 others like this.
  7. Dec 5, 2023 at 7:06 AM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    This is huge. 3.73 up to 4.066. The 3rd gen is way to high, clutch out and light throttle its happy at 8-10mph. Way too fast for parking lots and a problem for backing a trailer up hill.
    shakerhood[QUOTED] likes this.
  8. Dec 5, 2023 at 8:14 AM
    Sandthemall
    Sandamal
    2023 TRD OR MT
    So is it crankshaft hammering or NVH? Somebody's speaking with forked tongue. Regardless, this is a smart pivot because the crankshaft hammering sounds like an engineering/durability issue.
    shakerhood likes this.
  9. Dec 5, 2023 at 8:18 AM
    specter208
    California
    It’s the same thing. Crankshaft hammering is excessive vibration.
  10. Dec 5, 2023 at 12:20 PM
    Brucey
    Brucey Well-Known Member
    Bruce
    2018 DC LB SPORT 4X4
    Ovtuned
    I believe tfl said it was rpm limitations. The manual have a lower redline than the automatic. I also think it is to prevent people from blowing their trans from clutch dumping.
  11. Dec 5, 2023 at 1:27 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Peak torque is also raised from 1700 RPM to 2800 RPM. You MT guys will NEVER hear the end of that...
    WilliamJames, BC Hunter and Junkhead like this.
  12. Dec 5, 2023 at 2:39 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    It's not the 8hp I would worry about, sounds borderline of a weak component or design issue.
    shakerhood and Sandthemall[OP] like this.
  13. Dec 5, 2023 at 5:01 PM
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    Sounds like they gave the MT models the minivan tune. :popcorn:
  14. Dec 5, 2023 at 6:47 PM
    2016Tacoman
    J
    So no Ovtunes possible without damage ?
    Good to know your a whopping 8hp lower to eliminate damage.
  15. Dec 5, 2023 at 6:50 PM
    #35
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Not necessarily to eliminate damage. More likely to give the driveability/NVH profile that was desired.
  16. Dec 5, 2023 at 6:51 PM
    #36
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
  17. Dec 5, 2023 at 6:52 PM
    #37
    2016Tacoman
    J
    Still kind of ridiculous.
    This will be interesting.
  18. Dec 5, 2023 at 7:06 PM
    #38
    Clearwater Bill
    Billy
    Largo Florida
    I would 'guess' it may relate to rear thrust bearing stress because of the challenge in balancing a low displacement engine to achieve good NVH results.
  19. Dec 5, 2023 at 7:24 PM
    #39
    2016Tacoman
    J
    Hard to believe 8 hp would make that big of a difference.
    No Ovtunes that's for sure.
    Didn't worry about crap like that in the old days LOL. :rofl:
    At 57K go for it.
  20. Dec 5, 2023 at 7:27 PM
    #40
    OpeCity
    Long Beach, CA
    Hard to say if it’s ridiculous without being part of the complex engineering project
