What is the purpose of the 2024 MT having less power than the auto!.
Discussion in '4th Gen. Tacomas (2024+)' started by Sandthemall, Dec 3, 2023.
  1. Jun 30, 2024 at 8:23 PM
    #101
    SlippRott
    SlippRott Well-Known Member
    22 Silver OR
    Planning...suspension, front slimline bumper, winch, full skids, 2" lift, SCS Ray 10's, Pizza cutters, Power Tray, Switch-Pro, Alu-Cab Contour Canopy.
    Someone probably said this already but according to the truck kings video and Sheldon the engineer there is 8HP less because it was exceeding the operational specs of the trans (aka trans could not handle it). Additionally, we just learned that the auto trans in the TFL truck failed because the trans exceeded operational specs by 1.7% and they are going to fix it through software (AKA lessen torque in those specific conditions where it exceeds the trans capabilities).
    This does not sound like the OVERBUILT Toyota that we are all used to. I am not an engineer and I am sure I am missing a lot but exceeding operational specs by 1.7% and failing does not sound encouraging to me. You would think there would be a 10-20% cushion there but what do I know.
    daveeasa likes this.
  2. Jun 30, 2024 at 8:39 PM
    #102
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    They went 1.7% over the cushion.
    Vitamins likes this.
  3. Jul 1, 2024 at 3:22 AM
    #103
    Unit59
    Unit59 Keystone State
    Craig
    East Central PA
    2023 Tacoma TRD OR
    Anyone know what 24 Tacoma models are available with the MT? Everyone I've seen is auto and I tried building one on Toyota's website, and all I see are auto trans options?
  4. Jul 1, 2024 at 9:22 AM
    #104
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    SR, Off Road, Sport in Double Cab 4x4 short beds.
  5. Jul 1, 2024 at 9:57 AM
    #105
    Unit59
    Craig
    East Central PA
    2023 Tacoma TRD OR
    Thank you!
    shakerhood[QUOTED] likes this.
  6. Jul 1, 2024 at 10:30 AM
    #106
    shakerhood
    Southern Ohio
    You are very welcome
  7. Jul 2, 2024 at 11:41 AM
    #107
    Jacob06
    Jacob06 Well-Known Member
    Atlanta
    2024 TRDOR 6MT
    I am imagining that having a manual transmission with a human shifting it to go into gear at 2000 rmps with an engine that makes peak torque (317lbs) at 1700 rpms wouldnt be very nice for the clutch or the transmission.
    So they played with the tuning to get the peak torque to a higher rpm (2800 rpm) away from where 90% of the shifting would occur and that new tune yielded 8 less horsepower and 17 less torque's.
    I am only guessing but I doubt it was a situation where 8 less hp was saving anything.
    Surely they knew that owners would be able to squeeze more than an extra 8HP out of these engines.
    The peak numbers only tell part of the story. A bigger part of that story is where in the rpm's does this occur?
    And this explanation was probably too much for Toyota to expect the general public to digest so they just said crankshaft hammering and moved on to the next dumb question.
    I was more curious as to how they accomplished this than why, but they just tuned it differently, and it uses all the same parts.
    R242 and hemlockz like this.
  8. Jul 4, 2024 at 3:41 PM
    #108
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    In a video he said it was de rated for crankshaft hammering (vibrations). Which if true, sounds like a lazy way of improving the NVH. Didn’t say it was for protecting the trans. This transmission can handle 300torque at 1600rpm with a 2.5 1GD diesel in the Hilux.
    shakerhood likes this.
  9. Aug 19, 2024 at 6:39 PM
    #109
    az79k5
    az79k5 New Member
    Mark
    2024 SR - MT
    I just read through this thread after getting my first Tacoma with the MT.
    The truck has pretty good acceleration once in 3rd and beyond.
    1st gear is really little short in my opinion. I like the manual transmission, but I really cannot get a consistent smooth shift on 1 to 2 and 2 to 3. It seems to take forever for the RPM’s to come down if I get on it from a start and try to get through the gears.
    All in all, I like the truck and like the MT.
    Any gotchas or issues to look out for in the 4th gen Tacomas since the release?
    atc250r likes this.
  10. Aug 19, 2024 at 7:07 PM
    #110
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    Don’t shift from 5th to 1st.
  11. Aug 19, 2024 at 7:14 PM
    #111
    az79k5
    az79k5 New Member
    Mark
    2024 SR - MT
    Sounds like my wife’s bullet blender if successful.
  12. Aug 20, 2024 at 5:35 AM
    #112
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    1st gear is going to be short in a truck to accommodate a load. Probably not good for the life of the transmission but you could start out in 2nd gear unloaded. Short low gears is probably the biggest downside to the manual's driveability, but that's where the manual also has an advantage. People used to complain about the tall reverse gear. I wonder if that's has been improved?
  13. Aug 20, 2024 at 5:36 AM
    #113
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    1st, 2nd, and R are the exact same gear cluster from the previous gen transmission, however the tailset reduction gears connecting the counter shaft to the output shaft are 20.1% lower in the new transmission, so overall those 3 gears in the new transmission are 20.1% lower.
    1/2/R in the new transmission are about the equivalent of regearing a 3rd gen to 5.29 on stock or not much larger than stock tires.
    batacoma[QUOTED] likes this.
  14. Aug 20, 2024 at 5:40 AM
    #114
    batacoma
    batacoma Truck Wars
    Sounds like an improvement on the reverse. I recall some discussion with the engineer on the manual and reverse gear from one of the earlier videos.
  15. Aug 20, 2024 at 5:45 AM
    #115
    az79k5
    az79k5 New Member
    Mark
    2024 SR - MT
    4-lo in 1st and 2nd gear is a wildly low crawl. The available torque would seem to be a recipe for finding weak spots in the driveline and axles.
  16. Aug 20, 2024 at 5:47 AM
    #116
    az79k5
    az79k5 New Member
    Mark
    2024 SR - MT
    I’m not familiar with Tacomas or their history. Isn’t reverse just the backside of 1st gear on any MT?
  17. Aug 20, 2024 at 6:00 AM
    #117
    BLtheP
    Plano, TX
    No, and I really don’t know where that came from, but I sure have heard it a lot over the years. Maybe in the olden days or something, but definitely not in any of the transmissions I’ve owned from Jeep, Ford, Nissan or this Tacoma.
    4th gen Tacoma RC60F ratios:
    1 - 4.784
    2 - 2.423
    3 - 1.443
    4 - 1.000
    5 - 0.777
    6 - 0.643
    R - 4.067
    3rd gen Tacoma RC62F ratios:
    1 - 3.982
    2 - 2.017
    3 - 1.321
    4 - 1.000
    5 - 0.848
    6 - 0.713
    R - 3.385
    az79k5[QUOTED] and shakerhood like this.
  18. Aug 20, 2024 at 6:04 AM
    #118
    BLtheP
    Plano, TX
    Should be a significant improvement for sure. Having 5.29s on mine made a large difference and gives perspective on what the 4th gen would be like. 1st is pretty low as such, which seems to be a complaint of some, but I'm happier with that than the stock 3rd gen gearing for sure. My guess is instead of complaining about how bad R is, now 1st being too low will be the center of attention lol. Still, R is only adequate. It's still pretty tall feeling, but it is a lot better than it used to be.
    batacoma[QUOTED] and atc250r like this.
  19. Aug 20, 2024 at 8:24 AM
    #119
    Want-a-taco
    Want-a-taco Well-Known Member
    New Brunswick, Canada
    2024 TRD Offroad 6MT black
    I wish R was geared as low or lower than 1st. R is for Reverse, not Racing.
    Have to use 4-low if I want to crawl the slightest incline on if I don’t want to stall or burn the clutch.
    Hope someone makes a 2-low kit.
  20. Aug 20, 2024 at 8:39 AM
    #120
    BLtheP
    Plano, TX
    I wish R was something stupid low like 7-8:1. Difficult to fit a gear that large into a small transmission though.
    Based on browsing the wiring diagram, I don’t think 2 low will be any more difficult to achieve on 4th gen than it was on 3rd gen.
    joba27n and Want-a-taco[QUOTED] like this.
