What is the recommended lifespan for the shocks/ struts?
Discussion in 'Suspension' started by saugus, Sep 20, 2011.
  1. Sep 20, 2011 at 9:19 AM
    saugus
    saugus [OP] Well-Known Member
    They wear out after a while right? Any way to check? I have 133k currently. When it's due, I will be looking for an upgrade if it will mean a better ride with and without heavy loads. I have the most basic 2006 2.7 model. I checked the bilstein 5100's and I don't think they fit my truck.
  2. Sep 20, 2011 at 9:23 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    How long they last depends soley on the driving conditions. Heavy hauling and flexing the suspension can wear out components quicker. Replace the shocks when the truck is 'bouncy'. It should be one of the check points of a safety inspection (if your state mandates them).
  3. Sep 20, 2011 at 12:31 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Anywhere after 70k.
    Look for oil leaks. Bounce each bumper, if it bounces more than a couple times after=replace.
  4. Sep 20, 2011 at 3:13 PM
    saugus
    oil leaks from shocks?
  5. Sep 20, 2011 at 3:18 PM
    Pugga
    Massachusetts
    yes, if you see oil leaking from a shock, it's a good indication that the seal has blown and it's time for replacing (or rebuilding if you have high end shocks).
  6. Sep 20, 2011 at 3:56 PM
    saugus
    Thanks for the replies. Anybody want to suggest a good upgrade for the barebones, 2.7L, rwd, 5 lug? I'm wondering which of kyg, tokico, bilstein, rancho, etc. are better. I have stiff tokico's on my corolla.
  7. Sep 20, 2011 at 3:58 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    bilstein 5100s!
  8. Sep 20, 2011 at 3:59 PM
    saugus
    I tried finding them but don't think they make them for my 5 lug. :mad:
  9. Sep 20, 2011 at 4:21 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  10. Sep 20, 2011 at 4:40 PM
    saugus
    Thanks I matched your bilstein numbers to the ones I looked up earlier on tirerack at $66 each. Comes to $280.16 shipped. Now I will check the truck and decide.:cool:
  11. Sep 20, 2011 at 5:27 PM
    saugus
    Just bought these (or something similar to):
  12. Sep 20, 2011 at 5:50 PM
    KenLyns
    Belly of the Beast
    Cool. These will probably last longer than the Toyota OEM ones.
