What is the right lift for my tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tytius10, Sep 7, 2014.
  1. Sep 7, 2014 at 2:55 PM
    Tytius10
    Tytius10 [OP] New Member
    Hello, I want to lift my 06 tacoma but don't know what to get. I want it like 4 inches higher but want a smooth ride. Some lifts are stiff and I don't want that. Comment on what I should get.
  2. Sep 7, 2014 at 2:59 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Try doing your own research. There is a sticky in the suspension forum full of info. Your money, your truck, you.are the only one who knows what is right.
  3. Sep 7, 2014 at 3:00 PM
    crushh87
    crushh87 Woo Pig
    Jack
    Texas
    2013 Prerunner Silver
    4in MaxTrac Lift Spindles, 2in Pro Comp AAL, MB 352 16x8.5 Wheels, 285/75/r16 General Grabber AT2s, 2.7L I4
    PreRunner? 4x4? 2wd 5 lugger?
  4. Sep 7, 2014 at 3:00 PM
    zacharypaul89
    zacharypaul89 Eat right, be fit, die anyway
    Zach
    Georgia
    2019 Quicksand Trd Offroad
    Well, the most popular on here is a simple 3" suspension lift. OME and Bilstein/Eibach are the most popular. YOu simply replace the front shocks and springs and AAL to the rear. I'd say 90% of the people on here with a lift went that route. The best part is that it's only around $500 to do. If you don't want to do that, your next-best bet would be a Fabtech or Procomp 3" or 6" lift, which is around $2000
    I have the Bilstein/Eibach's in the front and an AAL in the rear and love it.
    Also, use the search function; this question has been asked hundreds of times
  5. Sep 7, 2014 at 3:01 PM
    Skinny Rogers
    Skinny Rogers U know fish can hear u thinking just b4 u sneeze
    Lance
    NC
    10 taco
    It says dc so it's narrowed to pre or 4x4
  6. Sep 7, 2014 at 3:11 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    In my opinion, the 6" lifts for these trucks are kinda overkill and mostly for just looks and mall crawlers, not to say that some don't put them to use. A good 3" lift should give you what you need and want. Do a search on here. The general consensus i believe, will be to stay away from cheap spacers and blocks, as all they do is just wear out components faster, ride rough and suck off-road. Many different options from just Bilstein 5100's up front, all the way to Fox/King full suspensions that will run you into the thou$ands. Remember, you bought a nice truck, don't put cheap parts on it. Good luck.
