What is the worst mistake you made doing your own wrenching?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bleep100, Feb 24, 2019.
  1. Feb 24, 2019 at 11:25 AM
    Bleep100
    Bleep100 [OP] TOYOTA 4 LIFE
    17 Sport
    We have all made mistakes . Maybe we can learn from each other . My friend F150 changed his water pump and mixed up bolts and put a slightly longer one in a short hole and cracked his block . Easy job gone way way bad .
    MrCball, gwynn1975, mbarbay and 11 others like this.
  2. Feb 24, 2019 at 11:31 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Holy shit that’s bad.
    It was back in the day when I was a young kid working at my families mobil catering business (fleet of 50+ trucks).
    The maintenance guy was out for the day, so they had me check all the fluids in the trucks. The trucks that were low on windshield washer fluid, I put in antifreeze. It’s the same color!! That was a complete disaster.
    Never had to do maintenance again.
  3. Feb 24, 2019 at 11:33 AM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    On this gen? It was yesterday when I remembered a fellow member saying the Toyota emblem on the steering wheel was held in place by two little pins. By the time I could see it was anchored to death by 6 plastic grappling hooks it was fucking buggered to all hell and I put a sticker over it.
  4. Feb 24, 2019 at 11:34 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I cross threaded the axle nut to my CV axle and in my haste I decided to keep going until I thought it was on there, and then deal with it next time I changed the axle. Big mistake. The axle nut wasnt completely seated and allowed for some play which ruined my wheel bearing and front rotor on that side the next day when I was on a 400 mile road trip. Luckily it didn't present itself until I got to my destination and there was a shop right off the freeway that was able to take care of me. But I learned a good lesson there
  5. Feb 24, 2019 at 11:34 AM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Sounds familiar, I know someone who put washer fluid in their radiator.
    Me, broken screw heads luckily has been my worst. Sometimes though, the amount of shit you have to take off to get a tap into a damaged hole can make a broken screw a nightmare.
    ndoldman59, Manfred, TacoCasa and 3 others like this.
  6. Feb 24, 2019 at 11:36 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Forgot the pilot bearing in a flywheel once, back in my old Honda days.
    Had the damn thing completely put back together and ready to test drive - just happened to see the fucking bearing laying there on the floor mocking me.
  7. Feb 24, 2019 at 11:37 AM
    stun gun
    Aaronski
    Tacomas.
    Zomg just sitting there, so smug
  8. Feb 24, 2019 at 11:37 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I have bad luck with seals.
    I think I have destroyed every major seal on my Jeep. I think I did the rear main seal 3 times because I kept tearing it on install.
  9. Feb 24, 2019 at 11:37 AM
    habanero_taco
    habanero_taco Well-Known Member
    Randy
    2016 Tacoma TRD Sport
    OVTuned
    This ones easy... many years ago doing a "simple" engine rebuild, rings, bearings, valve job, got much more expensive after breaking one of the rings installing a piston and scoring the cylinder wall.... so add boring out the cylinders, plus larger pistons and rings was more of a rebuild than I was planning LOL
  10. Feb 24, 2019 at 11:38 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    i came close to draining the tranny fluid when i did the first oil change myself. i had the wrench on the tranny drain plug but something did not seem right and i figured it out. i am and old fart and it seems like now when i try to fix something i make it worse.
    gwynn1975, TRDSport10, KY_Rob and 5 others like this.
  11. Feb 24, 2019 at 11:40 AM
    Grossomotto
    2017 4WDV6LB6MT
    Just remember 14mm for oil
    gwynn1975, Thyces, TRDSport10 and 6 others like this.
  12. Feb 24, 2019 at 11:41 AM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    me too! i had a 92 with that 2 piece rear seal, it seemed like it went in Ok then after putting it all back together it leaked worse then before.
    i did it a second time and the same thing..i ended up selling it.
  13. Feb 24, 2019 at 11:41 AM
    elduder
    Van WA
    Really common, always wonder what it'd be like to see the AT fluid coming out, thinking "whats wrong with my oil"
    scottalot likes this.
  14. Feb 24, 2019 at 11:42 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I didn't check the rocker arm slots for proper clearance when installing a bigger cam.... ended up lunching the cam on a small block Chevy.
  15. Feb 24, 2019 at 11:44 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I put a timing chain on so the pully was 180 degrees the wrong way and started the engine. I think it actually ran backwards for a few seconds before some of the pistons ate their valves :p. That little BMW was my mechanics teacher.
  16. Feb 24, 2019 at 11:47 AM
    JoeCOVA
    Joe
    Colorado Springs
    Haha, I some how managed while using dawn soup to lube up the seal and push it through, bottom was easy but that top one is a bitch.
    Recognize these?!? I still have 2 left over
  17. Feb 24, 2019 at 11:49 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Put in a clutch backwards. Put the tranny back in and ruined the transmission trying to bolt it in. Removed transmission and replaced clutch and transmission...
    [Edit autocorrect that changes tranny to granny for hilarity]
    mbarbay, scottalot, cshrum and 2 others like this.
  18. Feb 24, 2019 at 11:57 AM
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
    Forgot to put oil drain bolt back on. Realized after I had put in half the amount. Oil all over the floor.
    Luckily it was the beetle and only 1.25 quarts lost. Hahaha.
  19. Feb 24, 2019 at 12:04 PM
    JCOOR
    JCOOR Well-Known Member
    TRD Burglar
    Pretty much disassembled my entire first car. With no money or clue what I was doing it sat in a thousand pieces until I sold it a few years later
  20. Feb 24, 2019 at 12:08 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    now i am going to have nightmares! it was almost a full day from jacking it up getting the pan off doing the job , getting the pan back on to find it was a waste of time.
    one thing i thought of later was if the PCV valve was clogged it would create pressure in the engine block forcing oil out any crack?
    JoeCOVA[QUOTED] likes this.
