What is the worst mistake you made doing your own wrenching?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bleep100, Feb 24, 2019.
  1. Feb 28, 2019 at 8:57 AM
    #261
    sabersoul1217
    sabersoul1217 Well-Known Member
    Jeremy
    Friendswood, TX
    2021 F-150
    Broke a bolt replacing the valve cover on my old '03 Neon. And I will say that I'm not touching suspension ever again. My '08 Caliber taught me that I HATE it.
    Oh, and replacing my alternator pulley on that Caliber with a standard pulley instead of the fancy dual-clutch one that was on it. It chewed through AC compressors after that until I replaced the alternator with one that had the right pulley.
    TomTwo, xxTacocaTxx and wilcam47 like this.
  2. Feb 28, 2019 at 9:02 AM
    #262
    ABQTruman
    ABQTruman Well-Known Member
    New Mexico (It's a state)
    2018 TRD-OR ACLB
    bone-ass stock
    Jump starting my 2nd gen in the dark and rain. Definitely crossed up Neg and Pos and blew several fuses and the fusible link.
    Once I got all that replaced, though, the problem I had of blowing headlight and license plate lamps every few months was gone.
    BigMacMcCoy likes this.
  3. Feb 28, 2019 at 9:09 AM
    #263
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Cross threaded one of the 3 starter motor bolts in the aluminum block on a Honda Accord. It was a bolt that underneath and was felt but not seen. Using the braille method I had to drill, tap, and helicoil a fix. It held for many years though.
    My Name is Rahl and xxTacocaTxx like this.
  4. Feb 28, 2019 at 9:10 AM
    #264
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I guess it counts...but I was putting a small leveling kit on my wifes 4Runner and I go to take the shocks off the springs after compressing them and I shear the shock strut bolt. the bolt had corroded and when I went to take it apart it sheared. ended up having to put new struts and take them apart. I prob shouldnt have put that type of lift on it in retrospect. but I was newb, It did look good though once I finished.
    cshrum and sabersoul1217[QUOTED] like this.
  5. Feb 28, 2019 at 9:10 AM
    #265
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Um....
    Never mind.
    Lawfarin and wilcam47 like this.
  6. Feb 28, 2019 at 9:17 AM
    #266
    BLACK04TRD
    BLACK04TRD Well-Known Member
    Bethesda, MD
    2004 Tacoma TRD, 3.4L, 5spd -- SOLD
    Stock AF
    The other day I was replacing the spark plugs and spark plug wires on my 3.4l. When re-tightening one of the coil packs I over tightened and snapped the bolt. Was too scared to drive it like that and it's my only vehicle, so I had to take a $35 round trip uber to go get a replacement bolt :D
    TacoManOne, cshrum, whatstcp and 2 others like this.
  7. Feb 28, 2019 at 9:31 AM
    #267
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    About 15 years ago I swapped the U-joints in the driveshaft on a '94 Nissan 4x4 without realizing that I'd seriously jammed a needle bearing in one of the caps (bent it right in half) when I was pressing the new joints into place. Put it all back together and tested it out, and as soon as I locked the hubs in it hopped around the yard like a bucking bronco because that joint didn't want to flex for sh*t. Had to take it all apart and do it over again with a fresh joint, and you can be damn sure that I tested it off the truck before I put it back together a second time. :anonymous:
    Other than that, I've been lucky that the worst I've screwed up since then was when I welded new spring perches on to the rear axle of my 84 W150 plow/work truck a couple of years ago. I didn't let the axle tubes cool down enough between welds and I overheated the passenger side axle bearing & seal. Ended up noticing some slop a few weeks later and had to replace them.
    xxTacocaTxx likes this.
  8. Feb 28, 2019 at 9:34 AM
    #268
    tonykarter
    tonykarter Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    More than anyone else in my life, I too have been my own worst enemy at times. The most egregious of these times are when I had a tool in my hand...
    And never more obvious than when I am sitting in my yard with my hand stuck inside the bung hole of my 1997 Chevy truck's gas tank that I had dismounted to put YET ANOTHER in a long string of fuel pumps in it, and while I am sitting there my college roommate calls me and tells me to look up. There he is, up above me in a Citation corporate jet, flying over my house with some of his oil patch executive friends, going to stay at Halliburton's private estate outside Agusta, to attend the Sunday round of the Master's golf tournament. The tools I have held, and the tool that I am.
  9. Feb 28, 2019 at 9:35 AM
    #269
    thdrduck
    thdrduck Well-Known Member
    Yup. 1976 going to replace the trans in a 65 Olds Delta 88 (425 big block), car rolls off the ramps and the front tire just missed my head, onto my shoulder, down my chest and finally stops with my shirt pinned under it. The guy helping me cut my shirt off and pulled me out. Went to the ER later that night and found out I cracked all my ribs on that side and bruised my heart (you could see the tire tread marks on my chest perfect for a few days). They wrapped me with a bandage and sent me home with a bill.
    I have not worked on a vehicle using ramps since. With age come wisdom (unless you are just stupid).
    tacofish, AxisCab, cshrum and 2 others like this.
  10. Feb 28, 2019 at 10:32 AM
    #270
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    Its a skill knowing when you're in over your head.
    Hell the fucking bakflip cover 10 min youtube install is a joke. It took me 4 hours.
    My three year old was "helping" though.
    Easy bleeder[QUOTED] likes this.
  11. Feb 28, 2019 at 10:48 AM
    #271
    AverageGuy
    AverageGuy Well-Known Member
    Jeff
    Kansas City
    Former Tacoma Owner. Currently Own a Lexus GX470
    Changed the radiator on my Jeep XJ, left a socket near the fan which then shot said socket through the new radiator.
  12. Feb 28, 2019 at 11:14 AM
    #272
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    I had always known that the resistance of human skin played a role in the effect of the electrical shock, but always thought it negligible at high amperage.
    Your reply reset my assumptions.
    This article was eye opening to say the least. Did not know that higher amperage can be less fatal than smaller amperage.
    https://www.asc.ohio-state.edu/physics/p616/safety/fatal_current.html
    cshrum likes this.
  13. Feb 28, 2019 at 11:22 AM
    #273
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Water content will play a role. After all that’s how the electricity is flowing through your body.
    shakerhood likes this.
  14. Feb 28, 2019 at 11:22 AM
    #274
    SWCOLO
    SWCOLO Well-Known Member
    2016 DCSB TRD OR 4x4
    Helping a friend install a freshly rebuilt (by us) 1776 motor in a 1951 VW split window. Motor goes in super easy, we hookup wiring, fuel lines...etc. He gets in, cranks it up and instant flames. We forgot to the tighten the fuel line T fitting for the 48 IDA Webers and it spewed raw fuel all over the coil and distributor. We had an extinguisher fairly close, but it still ended up with a few blister scars in the paint and little discoloration. Good thing we had not installed that electronic fuel pump or the additional 2 seconds of pressure could have made things a little more interesting. Man I miss the air cooled scene.
  15. Feb 28, 2019 at 11:38 AM
    #275
    knayrb
    Bryan
    Pure stock
    One more - my stainless steel watch band became a 5 million watt heating element while working near the positive lead on the battery. It was bright red in no time. I even burned my right hand fingers getting that sucker off. I had quite the blister around my left wrist for weeks. I NEVER work on my vehicles with any jewelry now.
    AxisCab, Squidink and Lawfarin like this.
  16. Feb 28, 2019 at 12:02 PM
    #276
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    I made the mistake of loosening the upper bolts first on a Texas flanged Spicer/Dana 20 t-case.. it rested on that lower bolt fora few days before it broke off the lower ear.. cast iron can't be welded that easily... wound up getting anew transfer case that did not have the holes in it for the shfiter rods of the stock t-14 trans on my 74 CJ-5.. wound up having to replace the transmission.. (excused my upgrade to a T-18a...
    another one:
    I was replacing the front wheel bearing on my fathers 2000 GMC 2500 duelly 4x4 plow truck.. I had removed 2 of the 4 bolts holding the bearing on... the top left, and bottom right were frozen solid/rusty, and were recessed in the knuckle.. so I could only get at it with a shallow socket, and a breaker bar/ratchet.. I had a propane torch, and my impact would not fit, and the head of the bolts were starting to strip the corners.. I heated the bolts as much as possible.. soaked them in PB blaster, deep creep, marvel... etc.. tried heating again.... eventually I got the top one loose, and out, but the bottom one was frozen solid.. I wound up drilling it out... took me about 2 hours with different sets of drillbits as the ones I had were not up to the task of cutting the hardened grade 10 steel bolts. eventually I got it out, and replaced the bearing.... never worked on a rusty GMC again...
    I have more... but....
  17. Feb 28, 2019 at 4:13 PM
    #277
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    And since you were on US ships, that boat is probably still working today.
  18. Feb 28, 2019 at 4:30 PM
    #278
    My Name is Rahl
    Even an auto could have been shifted to neutral...
    MR E30 likes this.
  19. Feb 28, 2019 at 5:26 PM
    #279
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    You have it backwards. Higher voltage shocks can be less fatal than lower voltage ones, not amperage. However usually most higher voltages have dangerous currents available.
    Example 20,000 volt static shock (next to 0 current available) vs 45 volt (high amperage supply available) shock. Current through your body is the key factor, especially across the chest.
    Higher amperage is more fatal. Look at the chart.
    Bottom line if one does not know what they are doing seek assistance.
    Lawfarin, cshrum, xxTacocaTxx and 2 others like this.
  20. Feb 28, 2019 at 5:50 PM
    #280
    Colorado_Taco17
    Colorado_Taco17 Well-Known Member
    Jake
    Denver, CO
    2017 Tacoma TRD Off-Road
    CBI bumper/skids, BAMF sliders, Bilstein 5100s & 5160s
    My headass stripped the flare nuts at the end of my brake lines while trying to install extended brake lines. Still currently trying to figure out the best solution lol
