What is the worst mistake you made doing your own wrenching?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bleep100, Feb 24, 2019.
  1. Feb 28, 2019 at 6:20 PM
    #281
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Worst mistake I made was thinking replacing the catback on my Subaru would be easy. It's just 2 bolts....
    2 bolts that underwent years of heat cycles, covered in road salt.
    They didn't acknowledge a week of daily pb blaster. Heated them with a torch, nothing.
    Pounded socket on, breaker bar immediately rounded the nuts off.
    Ok cutting time!
    Of course my sawzall can't get an angle, so I spend what seemed like forever with a handsaw and finally get the bolts cut on the nut side.
    Still can't pound the bolts through, they have become fused with the flange.
    20 minutes of drilling, three hours total and I finally get the fucker off. 3 hours to remove 2 bolts, then 15 minutes installing the new exhaust.
    cshrum, xxTacocaTxx and Bleep100[OP] like this.
  2. Feb 28, 2019 at 6:24 PM
    #282
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Vice grips...to take it off...
  3. Feb 28, 2019 at 6:39 PM
    #283
    bulldog77
    bulldog77 Well-Known Member
    2018 Tacoma DCSB Off Road Cement
    I learned 3 lessons all in the same day.
    1. Brake fluid is flammable.
    2. How to use a fire extinguisher.
    3. How to remove shit stains from my underwear.
    It was a bone headed move and nearly burned down my ATTACHED garage.
  4. Feb 28, 2019 at 6:45 PM
    #284
    Bleep100
    Bleep100 [OP] TOYOTA 4 LIFE
    17 Sport
    We all have said shit shouldn't have done that .
    bulldog77[QUOTED] likes this.
  5. Feb 28, 2019 at 7:01 PM
    #285
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    Was being lazy working on my old motorcycle and set the tank on the seat frame. It fell off and put a big dent in an otherwise perfect tank. Ugh.
    wilcam47 likes this.
  6. Feb 28, 2019 at 7:03 PM
    #286
    Pyrotech
    Pyrotech Well-Known Member
    High amps in this case is not much.... 1 amp
    Yes ONE amp...
    Remember as voltage goes down, amps go up.
    That transformer feeding your house might have a 5 to 10 amp fuse feeding your home at 200 amps, and probably several others as well, Depending on its rating. 7200v depending on your power companies system voltage, down To 120/240
  7. Feb 28, 2019 at 7:05 PM
    #287
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    At that point I'm of the opinion just throw the shitty drawers out. Underwear is cheap.
  8. Feb 28, 2019 at 7:11 PM
    #288
    bulldog77
    They were my lucky pair! lol
  9. Feb 28, 2019 at 7:13 PM
    #289
    My Name is Rahl
    Maybe they weren't? :notsure:
  10. Feb 28, 2019 at 7:16 PM
    #290
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Fires also used to happen on unmodified VWs because the fuel filter would leak onto the distributer, I always moved it underneath on all my air cooled VWs.
    SWCOLO[QUOTED] likes this.
  11. Feb 28, 2019 at 9:36 PM
    #291
    Zoop
    Zoop Well-Known Member
    And it did, right after it went through reverse.
  12. Feb 28, 2019 at 10:38 PM
    #292
    S0ju
    S0ju Well-Known Member
    Norcal
    2018 mgm dclb sr5
    Luckily this was the worst 1 for me. I broke & cross threaded 1 grade 8 seat bolt. Didn't want to deal with it so just went to a shop and had them take it out and rethread
  13. Feb 28, 2019 at 11:36 PM
    #293
    Teter808
    Teter808 Well-Known Member
    Hawaii
    2016 DCSB TRD OR 4x4
    My uncle was teaching me how to tune my ‘69 Valiant, he showed me how to connect the timing gun, then gave it to me and said point it at the pulley and to see timing marks on it. So I leaned over then put my hand on down on the car when I got zapped. I suppose I completed some circuit with that hand. My uncle casually says, “oh yeah, don’t touch the car.”
    On my ‘83 SR5 Coupe it needed a timing belt and I decided it was something I could do. Wrong. I striped one of the bolt heads half way through the job and couldn’t drive my car till I figured out if I should go forward or put things back together as best I could. With my uncle having relocated out of state I ended up putting it back together and took it to a real machanic.
    I look back and and am still glad to have tried. Up to that point I mostly only did oil, tires, greased, and flushed coolant. That timing belt was a bit much with the knowledge and tools I had.
    Not mine, but close. Mine was two tone blue with aluminum wheels.
    cshrum, wilcam47 and TomTwo like this.
  14. Mar 1, 2019 at 2:46 AM
    #294
    Kilokato
    Kilokato Go Vols!
    George
    East Tennessee
    2016 SR5 Access Cab V6 Auto 4wd
    Limited wheels, extra rope hooks in bed.
    When I was a teenager I used transmission fluid for brake fluid in a Mustang I had....the seals all swelled up and locked the brakes up...
    cshrum and wilcam47 like this.
  15. Mar 1, 2019 at 3:13 AM
    #295
    My Name is Rahl
    Uh, how? Car manufacturers put neutral between drive and reverse for a reason.
  16. Mar 1, 2019 at 4:21 AM
    #296
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Its directly proportional. For example through a human body.
    V =IR
    If we are talking about for example step down/ up transformers then that applies.
    Actually 0.1 amp can be lethal.
    Pyrotech[QUOTED] likes this.
  17. Mar 1, 2019 at 7:00 AM
    #297
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Man putting some of that stuff together will make a preacher kick out a stained glass window :frusty:
  18. Mar 1, 2019 at 7:37 AM
    #298
    Zoop
    Eh, maybe I was headed toward park, anyways, it was an exciting experience.
  19. Mar 1, 2019 at 7:43 AM
    #299
    My Name is Rahl
    I lost my brakes once going down a slight incline and at the bottom of which was a T intersection. I was only doing about 8-10 mph, but I was about to hit a lady in a van. I jammed the shifter up into park to get it to stop. This was in a '98 Exploder. Loved that thing, even though I broke 3 door handles in 6 months. Eventually, the head gasket went and I parted it out.
    wilcam47 and Zoop[QUOTED] like this.
  20. Mar 1, 2019 at 7:45 AM
    #300
    Zoop
    Hah! Nice! I miss having a shit-box. I popped a brake line on a 87 Corolla AllTrak (station wagon looking thing with push button AWD, manual, fun as hell in the snow). I worked the downshift while my brother worked the e-brake. Managed not to hit anyone, coming off a freeway to a T, no cars but blew a red light. At least with a manual it was easy to get home!
    lol, by the time it went to the yard, I had to crawl in the passenger side, only the floor vents worked, one window was plexiglass. The brake line was the killer, took a look under and was like "oh hey check out all the other rotted stuff", scrapped it, cleaned out the block, got like $350 back on a $500 car.
    The good ole' days.
