What is the worst mistake you made doing your own wrenching?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bleep100, Feb 24, 2019.
  1. Mar 2, 2019 at 4:27 PM
    #341
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Before or after you rode the Hershey Highway?
    My Name is Rahl likes this.
  2. Mar 2, 2019 at 5:07 PM
    #342
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Might be! I think you mean Gigawatts
  3. Mar 2, 2019 at 5:44 PM
    #343
    Sharpish
    Brian
    High voltage is far more dangerous. But low voltage, high amperage, hits like the Columbia river. Slow but massive.
    TomTwo likes this.
  4. Mar 2, 2019 at 6:07 PM
    #344
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Yep lots of current there. That’s 4 times the voltage and a shit ton of amps. Nothing to play around with when it shorts out. I’ve seen videos of those things exploding. Not something I would want to be near
    TomTwo likes this.
  5. Mar 2, 2019 at 6:27 PM
    #345
    sramirez1516
    sramirez1516 Saul R.
    Saul
    2002 Toyota tacoma xtracab prerunner 2.7
    None
    The worst thing I've done was forgetting to plug a single injector on my 02 Eclipse after replacing the spark plugs. I had to remove the intake manifold. It sounds easy but it was an SOB because there were many components that had to be removed. Those who have owned an Eclipse know how little room those sickers have under the hood.
  6. Mar 2, 2019 at 8:42 PM
    #346
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    Was working on a 2015 bmw330x twin turbo. It had some issues, and I was set to disassembled the engine head down to the cams. I had just removed all 6 of the injector lines (high pressure direct injection).. detailer came by and opened the car door as this was soon to be a lot used vehicle for sales (I had not removed the battery/disconnected).. got a face full of fuel from all 6 lines from the fuel rail.. engine was toast.. previous owners skipped maintenance and the oil filter housing leaked oil (theh are prone to) this went on for a while. It then caused the belt to slip off the pulleys and get sucked into the crank seal, it are the seal, and also destroyed the oil pump chain that is right behind the seal.. starved the engine for oil.. needed all new bearings, and new turbos....
    TomTwo likes this.
  7. Mar 3, 2019 at 12:18 PM
    #347
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    My simple little ditch light install took a turn for the worst in about 10 seconds. I was having fun minding my own business on a Friday night dinking around with my truck in the driveway. It started to rain so I hopped in and moved my truck forward about 6’ to get it into the garage to keep going. I for some reason out of habit when it rains flipped on my windshield whippers forgetting I had stuffed a bunch of extra wiring up under to cowel to keep it organized as I was running wiring. Well long story short the whipper motor grabbed the wiring and winched it into itself and ripped every DT connector and the wiring out of the connectors on the battery. I spent the next hour cutting about 12’ of wiring out of the motor and links destroying my wiring harness. Needless to say I was pretty pissed at myself:frusty:
  8. Mar 3, 2019 at 12:30 PM
    #348
    tdnick
    tdnick Go Vols!
    Alabamer
    2018 Cummins 4x4
    Unbolted the steering box on my Jeep while I had the steering wheel turned installing a new front bumper
    Don’t do this
    wilcam47 and TomTwo like this.
  9. Mar 4, 2019 at 6:12 AM
    #349
    Bryanccfshr
    Bryanccfshr Well-Known Member
    2018 Trd OR , 2018 TRD Pro 4Runner
    I was in high school as well.
    I did row through all 4 gears going backwards down my country street. Forgiving machines.
    TomTwo[QUOTED] likes this.
  10. Mar 4, 2019 at 7:04 AM
    #350
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    BSFord and FritoBandito[QUOTED] like this.
  11. Mar 4, 2019 at 12:08 PM
    #351
    Dravnx
    Dravnx Well-Known Member
    jeff
    Santa Rosa, Ca
    2018 SR5
  12. Mar 4, 2019 at 12:22 PM
    #352
    Noelie84
    Noel
    Wales, Maine
    Ever since I picked up my mig welder, this has been my go-to for a broken stud before I start drilling. So far, I've been 100% successful and I haven't had to drill in years.
    Welding the washer and then the nut usually gets the bolt/stud red-hot and it backs out super easy.
  13. Mar 4, 2019 at 12:24 PM
    #353
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Genius
    whatstcp, shakerhood and wilcam47 like this.
  14. Mar 4, 2019 at 12:37 PM
    #354
    Noelie84
    Noel
    Wales, Maine
    Seriously. A couple of years ago I even used it to back out an exhaust stud on a '70 Mopar smallblock that had snapped off practically flush with the head, no problem. Saved me a lot of trouble, because the motor was still in the truck and it was the last stud back, so I'd have had to pull the head to get onto it with a drill.
    whatstcp, TomTwo, bax and 2 others like this.
  15. Mar 4, 2019 at 12:49 PM
    #355
    Bullnettles
    Bullnettles Well-Known Member
    Jared
    Houston
    2017 OR DCSB
    I put the O-ring on the wrong lip on Sunday and drove 10 miles, then got a low oil light. Biggest facepalm of my life, lost 3 quarts.
    whatstcp, TomTwo and cshrum like this.
  16. Mar 4, 2019 at 12:57 PM
    #356
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    had that happen to me on my 79 camaro on the way to work...I didnt have any straps to hold it down so I found a shoe lace I had and stopped before coming in the front gate and pulled it down and tied the shoe lace to get me on base and back home...it cracked my window. I dont remember changing it though...
    I dont run into this problem much but I like the idea of the washer...Seems like it would also protect the area around to block it from getting welded shut. Definitely going to use this though...
    whatstcp, TomTwo, xxTacocaTxx and 2 others like this.
  17. Mar 4, 2019 at 1:09 PM
    #357
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I like the idea of the washer too, I have always just welded a nut onto the stud and it works about half the time.
  18. Mar 4, 2019 at 1:09 PM
    #358
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I forgot to tighten the oil drain bolt on my turbo 240sx. The plug fell out while tuning the car at 10psi, oil went everywhere, I didn't notice until I spun a bearing and the engine started rod knocking.
    whatstcp, bax and wilcam47 like this.
  19. Mar 4, 2019 at 1:11 PM
    #359
    Noelie84
    Noel
    Wales, Maine
    Yep. You fit a tight washer on over the stub to keep any overflow from welding the bolt/stud to the block/base material/whatever. And then once the washer is welded on it gives you that much more contact area to weld the nut to, as well. The only thing to really be careful with is if you're extracting a bolt from an aluminum block or transmission housing that you NEED to let it cool down first, otherwise it'll come out but it'll take the aluminum threads with it.
    whatstcp and wilcam47[QUOTED] like this.
  20. Mar 4, 2019 at 1:16 PM
    #360
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    Put rear shocks on my wife’s Altima with a impact gun.
    Snapped the bolt on the top with a quickness.
    Had to rip out the entire rear of the vehicle so I could weld in a new nut.
    Also added 5 quarts of oil to my tacoma with the drain plug still out.
    Party!
    wilcam47, The_Devil, TomTwo and 3 others like this.
