What is the worst mistake you made doing your own wrenching?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bleep100, Feb 24, 2019.
  1. Mar 4, 2019 at 1:20 PM
    #361
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Flux core or solid wire? I use solid wire to keep it from getting porous. I've also heard that using flux core can harden the bolt, so if you do end up having to drill it's even worse, but don't have anything scientific to back it up.
    TomTwo and shakerhood[QUOTED] like this.
  2. Mar 4, 2019 at 1:43 PM
    #362
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I use solid core and 75/25 gas, never heard about that on the flux core, interesting info.
    TomTwo likes this.
  3. Mar 4, 2019 at 1:46 PM
    #363
    Noelie84
    Noel
    Wales, Maine
    I heard it from a grouchy old mechanic. Might be total BS, but he's the one that taught me the trick with the washer so I was inclined to believe him :notsure:
    Squidink and shakerhood[QUOTED] like this.
  4. Mar 4, 2019 at 1:49 PM
    #364
    shakerhood
    Southern Ohio
    The washer sounds awesome cause of the increased contact area, gonna give it a try next time a broken bolt happans.
  5. Mar 4, 2019 at 1:52 PM
    #365
    Noelie84
    Noel
    Wales, Maine
    He had a lot of neat tricks for stuff. I learned a lot working with him; he'd been wrenching since he was a kid and was probably 60 or so when I was working with him.
  6. Mar 4, 2019 at 2:49 PM
    #366
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    I have used flux core, solid core and also a stick welder to weld nuts on broken bolts, I always tried to use a washer too if I could hang one on the broken bolt. Also Left hand drill bits work real good to, the left hand drill bit will snag/grab while drilling and back the bolt right out.
    tcjacado likes this.
  7. Mar 4, 2019 at 2:51 PM
    #367
    TomTwo
    Bill
    I-85 Southbound
    After turning wrenches for a living for 40 years I resemble this remark :D
    Bleep100[OP] likes this.
  8. Mar 4, 2019 at 2:52 PM
    #368
    ShadowRunner
    ShadowRunner Well-Known Member
    Brady
    '16 Tacoma - SEMA 2017
    My buddy drained his tranny oil instead of engine oil without knowing, and continued to put oil in the motor...$6k bill later and the solution was solved.
    Slashaar, Bullnettles and TomTwo like this.
  9. Mar 4, 2019 at 2:55 PM
    #369
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I changed my leaf packs out and forgot to put the bumps back in. No idea if this will end up being a problem. Still rolling without bumps.... :crapstorm:
    My Name is Rahl likes this.
  10. Mar 4, 2019 at 3:21 PM
    #370
    myaccountname
    myaccountname Well-Known Member
    Well, I guess I better fess up. I had a Subaru hatchback - fantastic car and easy to work on, once you knew that the spare was on top of the engine and purchased a copy of "How to keep you Subaru Hatchback ALIVE"
    So, I was moving and the van rental guys wouldn't let me have a trailer for the car, just a front wheel dolly. Quick check of the magical HTKYSALIVE book, and they said just remove the drive shaft from the rear diff, and tie it up out of the way with some wire. So, I didn't have a piece of wire handy, and used a short rope. Fully intended to change the rope for wire before leaving.
    Did not do so.
    1000 miles later, and I'm shopping for a prop shaft.
    Funny part is, I had earlier replaced the valve thingy for the heater. So, this car cost me a cock and a shaft.
  11. Mar 4, 2019 at 4:22 PM
    #371
    Slashaar
    Josh
    Kansas City, MO
    I've done that. Realized my mistake after a molten squeaker tab went flying out of the driver-side front wheel on the test drive.
    godzilla888 and My Name is Rahl like this.
  12. Mar 4, 2019 at 4:28 PM
    #372
    Slashaar
    Josh
    Kansas City, MO
    I replaced my caliper on my 99 Grand Am (POS) that I had before the taco. Found out it was bigger than oem when I had to roll home 40 miles on a donut, while the inside of the rim intermittently scraped the caliper and shot sparks out all the way home... Guess the spare was bent too.
    robssol and cshrum like this.
  13. Mar 4, 2019 at 4:35 PM
    #373
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    Used a cheap torque wrench when changing the oil pan gasket on a ‘93 civic. Snapped one of the bolts cause the damn wrench didn’t want to click at such a low setting (those studs were pretty small). Did the rest by feel. Surprisingly it didn’t leak much oil missing that one bolt. Leaked less than the old cracked gasket. Put 100k miles on that car after that job, even drove it coast to coast twice with 280k on the clock with no worries whatsoever. Miss the ole shit box.
  14. Mar 4, 2019 at 5:09 PM
    #374
    1911tex
    1911tex Well-Known Member
    2018 Silver Metallic Limited
    Many moons ago...my mistake was doing it myself.....without the correct tools!
  15. Jun 20, 2019 at 10:49 AM
    #375
    Anton338
    Anton338 Ill-Known Member
    Anton
    New Jersey
    2018 TRD Off-Road DCSB
    Mostly electrical shit that nobody cares about.
    One time I had my windshield wipers up while washing and then I opened the hood on them. Yikes.
  16. Jun 20, 2019 at 10:52 AM
    #376
    crazy joker
    crazy joker Well-Known Member
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    Real men just call it camping
    I’ve done that before
    Shaun4079 and Bleep100[OP] like this.
  17. Jun 20, 2019 at 11:01 AM
    #377
    ParadiseToy
    ParadiseToy Member
    Charlie
    Penn Valley, CA
    2006 4 door, 6' bed, SR5, 4x4
    Stock, so far.!!
    Not disconnecting the battery when swapping out the alternator on my wife's Camry. Blew the 40A megafuse in the fuse box. Nothing worked, just when I though I had the screw in there, it would go juuust out of sight. A TOTAL PITA to replace. Took me 4 days of frustration. I'd work on it for 1 or 2 hours before I peeled off every obscenity in the book and retreated to the A/C inside the house. Thankfully my wife was out of town for the week.
    As usual, the first time you do something it's hard. Although I've never had to do it again, I'm sure I could do it in about twenty minutes
    robssol, Bleep100[OP] and Tommyb08 like this.
  18. Jun 20, 2019 at 1:34 PM
    #378
    Slashaar
    Josh
    Kansas City, MO
    Done that but instead of opening the hood, the wind blew and they fell into my windshield and cracked it. I was replacing the wipers....
  19. Jun 20, 2019 at 1:46 PM
    #379
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    If there’s ever problems with this i.e. nut not holding, prep the washer and nut. Often times there’s a zinc coating and when you get on it, it falls apart. I’ve seen people in a rush skip this part and it takes even longer to un-botch the job. Blast it/grind it
  20. Jun 20, 2019 at 2:20 PM
    #380
    Spermcock
    Spermcock Well-Known Member
    Marc
    Satellite Beach, FL
    2020 Cement TRD OffRoad DCLB "Carlos"
    MESO Coin Holder, Stage Shift Knob, Stage 1 Tails, Stage 4 Turns, Fuse Extender, Gasshole, Puddles Lights, and hopefully more to come! RokBlokz Black-out Badges
    Years ago had to pop the spare on the 4Runner and decided to go top speed the car...not the smartest idea to begin with but it was a full spare and top speed on a 4Runner is not that fast. Of course it was under 70 mph... ;)
    Anyways, after top speed I felt an odd rumble especially on turns or swerves. Thought it may be rotors going bad but got out to check it out. Turns out, I was yapping while I was changing my tire and forgot to torque the lugs down. Somehow by the grace of God one stayed tight and didn't snap the bolt...during a top speed test.
    Wonder sometimes how I'm alive...
