What is the worst mistake you made doing your own wrenching?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bleep100, Feb 24, 2019.
  1. Jun 25, 2019 at 5:00 AM
    #401
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Makes sense. But, like I said, I heard it from a grouchy old mechanic and I wasn't inclined to argue with him after he showed me a technique to extract a broken bolt without drilling it :laugh:
    Bleep100[OP] and Skydvrr[QUOTED] like this.
  2. Jun 25, 2019 at 5:07 AM
    #402
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Higher percentages of carbon in the steel are what make it hard. So it either has more carbon or doesn't. Heat is heat :thumbsup:
    Bleep100[OP] likes this.
  3. Jun 25, 2019 at 7:49 AM
    #403
    msapers
    msapers Well-Known Member
    Scott
    Los Angeles
    2017 TRD Off Road DCSB V6 MT
    I'm a really good mechanic. I have the tools and skill to tackle anything up to and including full custom fabrication, engine builds/swaps, etc. I got there by being a shitty mechanic with shitty tools and half assing things because I didn't know better. Here's a few of my greatest hits:
    1. Broke a head bolt on my Jeep 258 after changing a head gasket. (What's a Touque to Yield Fastener? You can't reuse them?? FUCK!!!)
    2. Filled a TH350 automatic with 90w gear oil. (The bottle said it could be used in transmissions...)
    3. Put the rear caliper spacer on the wrong side of the caliper on my old Kawasaki KZ1000 and spit out the pads on the freeway.
    4. Overtightened and broke or stripped out approximately 9,567,243 bolts
    5. Reversed the wires on the neutral switch on my CB750 chopper. Every time the bike was in neutral it was a dead short
    6. Arc welded about 400 wrenches to battery cables, fenders, brackets, etc while changing batteries
    7. Screwed up the wiring in my house and ended up with 220V in the living room. Ever heard a vaccuum cleaner scream?
    8. Before I had proper tools, I used Vise Grips and crescent wrenches on EVERYTHING. Never met a bolt I couldn't round off.
    9. I believed the internet. This was possibly my most destructive period
    10. Set myself on fire a couple times when I was first lesrning to weld
    We all screw up. All of the above were many years ago and my work is high quality now. I guess experience is the best teacher. Or maybe classes. Classes are probably a little better.
  4. Jun 25, 2019 at 7:52 AM
    #404
    STrooper
    STrooper For HIS glory!
    Jack
    NC
    2018 TRD Sport QuickSand / 2020 TRD Sport Cement!
    :eek:How did you end up removing it???
  5. Jun 25, 2019 at 7:59 AM
    #405
    Bleep100
    Bleep100 [OP] TOYOTA 4 LIFE
    17 Sport
    Way back when I had no tools and rounded bolts I beat sockets on them and I had sockets I never could get the nuts out of even in the vise . I also had to resort to hammer and chisel on some , boy was that a job -- you are bringing back nightmares .
  6. Jun 25, 2019 at 8:04 AM
    #406
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Heat and then drill/easy-out. Then bought me a set of Snap-on torx bits.
    They put the steering wheels bolts on way too tight at the factory.
  7. Jun 25, 2019 at 8:09 AM
    #407
    takomajake
    takomajake Well-Known Member
    Jake
    2021 DCLB SR5
    Wish there was a video for this! Lol
    My best mistake was forgetting to take the old oil filter gasket/seal off. I assumed it came off with the filter. Went to back out of my parent's garage and watched the oil pressure drop and a loud ticking noise start. Oil was everywhere. It was on a v6 camaro and the filter was on the front of the engine. The belt made sure every pulley and under the hood was well lubed. I double check that every time now even if I can see it on the old filter.
  8. Jun 25, 2019 at 8:10 AM
    #408
    Tommyb08
    Tommyb08 Well-Known Member
    Tom
    Jersey Shore - Ocean County
    2017 TRD Sport 4X4 DCLB Black
    Agreed with both, took my '17 into my local Toyota shop to get new T4R Pro Sema rims, BFG KO2s and alignment. Came out loaded with grease but figured it happens I'll clean it off at home. After I get home, closer inspection showed 3 out of the 4 rims had light scratches on them where they installed them. Never again, they did nothing for me, F you Shore Toyota!
  9. Jun 25, 2019 at 8:12 AM
    #409
    unavailableTaco
    unavailableTaco Well-Known Member
    Roy
    Grapevine Texas
    2018 Tacoma TRD PRO
    Full tank of gas
    I have not made any mistakes ever, with one exception. I replaced the struts and did not tighten the bottom cross bolt enough. Just tightened it.
  10. Jun 25, 2019 at 8:13 AM
    #410
    Bleep100
    17 Sport
    You will :rofl:.
    Tommyb08, Shellshock and eccracer104 like this.
  11. Jun 25, 2019 at 8:24 AM
    #411
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    A mistake i have done plenty of times is when making brake lines or fuel lines, end up getting distracted and flare the line without putting the tube nut on first.
    TomTwo, xxTacocaTxx, Dee_Rail and 8 others like this.
  12. Jun 25, 2019 at 8:25 AM
    #412
    msapers
    Scott
    Los Angeles
    UGH!!! Yes, I've been there.
  13. Jun 25, 2019 at 8:34 AM
    #413
    Señor
    Señor Well-Known Member
    CA Central Coast
    '18 TRD OR DCSB Magnetic Gray Metallic
    What is the worst mistake I made doing my own wrenching?
    I opened my own auto repair business. Being your own boss is good but, when seemingly every form of local government wants a slice of the pie, (Fire Dept inspector, B.A.R., Water & Sewer inspector, etc,etc) No paid vacations, health ins. yada,yada, yada!
    I now work for a large corporation, Get paid 3x as much, Complete health benefits package, 401, and pension. Union backed so I can talk back to the bosses and call it questioning. best move I ever made.
    tcjacado, Tommyb08, Slashaar and 6 others like this.
  14. Jun 25, 2019 at 9:12 AM
    #414
    msapers
    Scott
    Los Angeles
    Did I mention welding in flip flops? Yeah.
  15. Jun 25, 2019 at 9:23 AM
    #415
    My Name is Rahl
    :eek:
  16. Jun 25, 2019 at 10:00 AM
    #416
    MGM3Pedal
    MGM3Pedal Well-Known Member
    Rob
    Appalachian Mountains
    2017 MGM DCSB 6MT TRD Sport 4X4
    Lets just say I won't ever use a spring compressor ever again. Paying a shop to assemble the struts is money well spent.
  17. Jun 25, 2019 at 10:05 AM
    #417
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    they have a fancy machine they put them on...:D
    MattCowsmasher likes this.
  18. Jun 25, 2019 at 10:15 AM
    #418
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    My mom was a nurse. Had someone come in that did that except rested the lumber on his leg. Oops.
    xxTacocaTxx, wilcam47 and shakerhood like this.
  19. Jun 25, 2019 at 11:18 AM
    #419
    Truky!
    Truky! Well-Known Member
    Satellite Beach FL
    2021 TRD Offroad
    On one of my first cars, I was adjusting the carburetor, and while it was running, I dropped the nut down the throttle body. It banged around until it found it's way all the down past the valves and into the cylinder. Rattled in there for years...
  20. Jun 25, 2019 at 11:38 AM
    #420
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    ...that you know of or care to admit.
    wilcam47 and MattCowsmasher like this.
