What is the worst mistake you made doing your own wrenching?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bleep100, Feb 24, 2019.
  1. Jun 25, 2019 at 11:45 AM
    #421
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    I love talking shit to the bosses. As mentioned in another thread...” come on out here and show me how it’s done” union FTW
    Slashaar and MattCowsmasher like this.
  2. Jun 25, 2019 at 11:45 AM
    #422
    stun gun
    Aaronski
    Tacomas.
    I still do this from time to time.
    tcjacado likes this.
  3. Jun 25, 2019 at 11:53 AM
    #423
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Dozens of "quick" TIG jobs in a short sleeve T shirt.....
  4. Jun 25, 2019 at 11:58 AM
    #424
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Tiggin in a short sleeve is nice. Too hot in AZ for long sleeves.
  5. Jun 25, 2019 at 11:58 AM
    #425
    Skydvrr
    Nick
    YMH
    Black '17 OR
    You seem like a union electrician.
  6. Jun 25, 2019 at 12:05 PM
    #426
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    Worst mistake I ever made was becoming a wrench for a living.
  7. Jun 25, 2019 at 12:11 PM
    #427
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Ditto this! On a Jeep 4.0 valve cover job, misread inch-pounds for foot-pounds. Was well past midnight and way tired so I snapped the sucker close to the firewall. Couldn’t get a drill there with the engine in place. I was so fucking livid!
    robssol and shakerhood like this.
  8. Jun 25, 2019 at 12:22 PM
    #428
    TireFire
    Olympic Peninsula
    Kinda surprised you’re still alive. Made me chuckle so thanks for that. On the note of Honda CB’s I’m working on a 350 now (got as basket case) and built a suicide throttle - hastily crossed with clutch cable - and ended up in a ditch on a test ride in shorts, flip flops and no helmet. Miraculously without any damage to man or machine, just ego took one over the head.
  9. Jun 25, 2019 at 12:22 PM
    #429
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    Not really a mistake just a reminder of why I hate exhaust work.
    Offered to replace the rusted out muffler on my girlfriends 2007 Honda Civic. Told her it would be a super quick job and should be done in less than an hour, only two bolts right?. POS spring over bolt exhaust flange bolts. Tight, tight, looser, too loose. Fuck me, snapped the first one off immediately. Took my time with the second one and got it out with a lot of muscling and penetrating oil. Had no idea how to get this completely rusted bolt out of the flange. The other side of the flange had the nuts welded to it so I couldn't just slide it out of put a new nut and bolt in. What an awful design. The new muffler came with a nut and bolt so I figured the OEM design was the same. I tried vice grips, blow torch, penetrating oil. All while working within inches of the gas tank mind you. She kept telling me that it was okay and she would just take it to a mechanic.
    I had just gotten a MIG welder a couple months ago but had literally only laid two beads with it cause I was away at school. Decided to give it a try. I was working in shorts, an old sweatshirt, and a pair of slip on Muck Boots. Had my girlfriend sit a few feet away with a fire extinguisher, told her not to look at the arc, but if she saw a flame hit me with the fire extinguisher. Found a nut the fit, guessed on the setting on the MIG, put two tacks on it, and it held. Of course spatter went everywhere and my tack fucked up the flats of the nut. Spent another 30 minutes at least filing down the flats so I could get a wrench on it. Got a wrench on it and it came off no problem. Made it out with only a few little burns and no fires. Now of course the old donut gasket was completely fused to the exhaust pipe. Each piece I chipped off took a piece of the pipe with it. So I said fuck it, hammered a new gasket over the remnants of the old one and put the new muffler on. Told my gf that this would last a couple years but that exhaust was gonna completely fall apart after that (it was in the same shape as any of NJ exhaust). Turned into almost a 4 hour job, but saved her a couple hundred bucks.
    Bastek, Tommyb08 and Grumpy like this.
  10. Jun 25, 2019 at 12:24 PM
    #430
    unavailableTaco
    unavailableTaco Well-Known Member
    Roy
    Grapevine Texas
    2018 Tacoma TRD PRO
    Full tank of gas
    No, I have not made any mistakes, ever. I have changed a clutch out, changed countless struts, brakes, tuneups, 100's of oil changes, air and gas filter. Valve adjustments every 6 months. Change diff fluid, actually in my last Taco, changed antifreeze many times, belts, hoses, water pumps, A/C units, drive shafts and center bearings, complete exhaust system, changed countless batteries and if I change my mind, I will let you know.
    But I also just turned 65, so I have had a lot of practice going slow as to not make a mistake.
  11. Jun 25, 2019 at 12:26 PM
    #431
    TireFire
    Olympic Peninsula
    Bet your shit don’t stink either
    LarryDangerfield likes this.
  12. Jun 25, 2019 at 12:27 PM
    #432
    unavailableTaco
    Roy
    Grapevine Texas
    2018 Tacoma TRD PRO
    Full tank of gas
    I did mention the one mistake I made.
  13. Jun 25, 2019 at 12:28 PM
    #433
    ResearchMonkee
    ResearchMonkee Techn9cian
    Derrick
    KCMO
    2011 Barcelona Red DCSB Sport
    Drained ATF fluid instead of oil. :bananadance: Took to Valvoline shop to have them fill back up. Now have clunk on stop/go. Thinking I really need to get my hands dirty and do the OBD jump thing to verify correct levels to make clunk go away. Was going to grease up my slip yoke first in driveshaft and hope that solves the problem.
    Bleep100[OP] and monkeyface like this.
  14. Jun 25, 2019 at 12:41 PM
    #434
    stun gun
    Aaronski
    Tacomas.
    Nope.
    As mentioned in another thread, I used to hold a foreman position/company. But went to the floor. So when I say “I can do your job, do mine”, I can say with a smugness never before seen. None of these desk kooks can read a wiring diagram, pneumatic diagram, none have certs, none can weld, none can wrench, rebuild a diff or an engine. So. You know. I’m not hearing it.
  15. Jun 25, 2019 at 12:57 PM
    #435
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    Back in the 70's when I had my first yota...I was changing the oil, got distracted...back at it, and refilled with 4.5 qts...then saw the oil drain plug sitting on the battery. 4.5 qts of fresh oil onto Dad's asphalt, he was not amused.
    Same car a year later, just finished up rebuilding the alternator (new brushes). Took her out for a spin, about a mile out down she goes with smoke rising from the hood. Get out, pop the hood...left a breaker bar on the battery which slid onto the terminals...shorted the battery, took out the voltage regulator and damn near burnt the vehicle.
    Last thing I look at now when I close the hood is the top of the battery. :rolleyes:
    Cheers, Jeff
  16. Jun 25, 2019 at 1:03 PM
    #436
    unavailableTaco
    Roy
    Grapevine Texas
    2018 Tacoma TRD PRO
    Full tank of gas
    So you live in the BoonDocks?
    Bleep100[OP] likes this.
  17. Jun 25, 2019 at 1:07 PM
    #437
    stun gun
    Aaronski
    Tacomas.
    Doesn’t matter where I am.
  18. Jun 25, 2019 at 1:07 PM
    #438
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ...^^^... Did this on my first clunker as a kid .... sold it for parts later.
  19. Jun 25, 2019 at 1:08 PM
    #439
    unavailableTaco
    Roy
    Grapevine Texas
    2018 Tacoma TRD PRO
    Full tank of gas
    I just remembered something I had to redo. My friend and I were building a "race car", bored out 283 to a 292 in a Chevy II. The parts man gave us the wrong throwout bearing. It was too long. They made two that year, one short and one long. So it ran but no matter what gear, it was one speed. Turtle slow. So we had to drive back to the parts store to get the short one at 5 miles an hour while it was playing havoc on the new clutch disc.
    So does that count as messing up?
  20. Jun 25, 2019 at 1:09 PM
    #440
    unavailableTaco
    Roy
    Grapevine Texas
    2018 Tacoma TRD PRO
    Full tank of gas
    MY bad, the G and B are close together on the keyboard. So where is GoonDocks, TW?
