What is the worst mistake you made doing your own wrenching?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bleep100, Feb 24, 2019.
  1. Jun 25, 2019 at 9:02 PM
    #461
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I flipped mine and ran em. :notsure:
    GQ7227 and Bleep100[OP] like this.
  2. Jun 26, 2019 at 12:21 PM
    #462
    Ensemble88
    Ensemble88 Well-Known Member
    San Diego, CA
    2017 Black OR DCLB
    King suspension, SSO bumper w/winch, Pelfreybuilt sliders, morimoto fogs
    Driving down the road, car started sputtering and we pulled off to the side of the road to check it out. Just had an oil change, so I checked the dip stick, looked ok, wiped it off to get a fresh reading and pulled it out again. Bone dry. So I poured another quart in thinking it was low. Still dry. Poured two more quarts in...still nothing. Towed it to a shop and they said the alternator was bad. Nothing related with the oil. I had them check the oil and they took out 7 quarts! Later I realized I was checking the dip stick when the car was half in the ditch and not on level ground...doh.
  3. Jun 26, 2019 at 1:58 PM
    #463
    Slashaar
    Josh
    Kansas City, MO
    As an IAMAW Shop Steward, I approve of these messages! :rofl::rofl::rofl::rofl:
    Bleep100[OP] likes this.
  4. Jun 26, 2019 at 7:34 PM
    #464
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Most dangerous mistakes I've done were at my current job(ford dealer tech) I put lug nuts on by hand and let the service advisor rush me forgetting to tighten the lugs on one wheel on two different vehicles about a week apart, from then on I have not let a service advisor rush my and am known to bluntly tell them to piss off and let me do my job. Two rules I made for myself after that are never put lugs on without a impact gun in the other hand and that every single time a wheel is taken off the car gets driven around the block.
  5. Jun 26, 2019 at 7:39 PM
    #465
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Worst mistake while wrenching?
    I lost a 10mm socket once. :annoyed:
  6. Jun 26, 2019 at 11:47 PM
    #466
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    cgs2k2, Shveet, TireFire and 2 others like this.
  7. Jun 27, 2019 at 12:26 AM
    #467
    Gus87
    Gus87 Well-Known Member
    Chicagoland
    16 trd sport
    Not disconnecting the battery when replacing a stater in my 95 roadmaster. I almost lost a few fingers that day.
  8. Jun 27, 2019 at 12:46 AM
    #468
    dawhoo
    dawhoo Well-Known Member
    James Island, SC
    19 Tacoma DCLB TRD OR Cement - 18 TRD Pro 4 Runner Black Midnight
    Tacoma 17 SEMA Grey with KO2 255/75/17
    So stupid but, I lucked out. Socket to remove battery terminal and connected both terminals - BOOM!! 750 CCA battery and a socket. I'm lucky it wasn't worse for me.
    shakerhood and Bleep100[OP] like this.
  9. Jun 27, 2019 at 8:04 AM
    #469
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    :facepalm:
  10. Jun 27, 2019 at 1:10 PM
    #470
    Slashaar
    Josh
    Kansas City, MO
    What is it with ford techs? I knew a guy who did that at a Ford Lub place and the customer's wheel flew off on the highway. He was promptly fired.
    I forgot to unplug the battery from my wife's corolla and was replacing the starter and nearly zapped myself. Was lucky I didn't damage the battery or any wiring too.
  11. Jun 28, 2019 at 12:06 PM
    #471
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    @Bleep100 , would you mind if I opened this up to self inflicted carpentry/construction stories?
    Bleep100[OP] and My Name is Rahl like this.
  12. Jun 28, 2019 at 12:12 PM
    #472
    joeyv141
    New Jersey
    Best part for mine was it was the same service advisor both times and both times he interrupted me while I was running the lugs on and as soon as the wheels hit the ground he took it from my stall, if I had test driven it like we are suppose to I would have felt it was loose, now I dont let it leave unless I test drive it. Neither wheel separated from the vehicle but only cause the customers noticed the noise they were making.
  13. Jun 28, 2019 at 12:13 PM
    #473
    Chad_QS18
    Chad_QS18 Well-Known Member
    Chad
    NoVA
    2018 Quicksand Tacoma Offroad
    Slammed on 16s
    Long post comin..
    Used to be a tech at carmax. Finished up a customer vehicle, took it through the car wash before delivering it. Had a buddy in the passenger seat.
    We used to play this game, passenger would hold the bar that allows the seat to slide back and forth, driver would slam on brakes, passenger gets a little ride.
    I slammed on the brakes pretty hard coming out of the car wash, buddies head hit the windshield, cracks all over the damn place.
    Hard one to explain to the customer, but I kept my job somehow.
  14. Jun 28, 2019 at 12:15 PM
    #474
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Same thing happened on here, the Dealer Tech forgot to tighten the wheel on the guys Tacoma and it came off on the highway.
  15. Jun 28, 2019 at 12:19 PM
    #475
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    All I will say is 10 quarts of fluid in the engine, zero transmission fluid. Ooops.
  16. Jun 28, 2019 at 12:22 PM
    #476
    Tommyb08
    Tommyb08 Well-Known Member
    Tom
    Jersey Shore - Ocean County
    2017 TRD Sport 4X4 DCLB Black
    Damn that’s crazy, at least you kept at it and got it squared away. I’m sure she was greatful. Seems like a lot of easy jobs never turn out being easy. I learned not to say it anymore, “this won’t take long, it’s easy”. Every time I say that it ends up being a pain in the ass lol.
  17. Jun 28, 2019 at 12:24 PM
    #477
    Slashaar
    Josh
    Kansas City, MO
    Not me but some kid at a shop was new and we took my wife's car in for an oil change. Started driving music up loud then I heard the dreaded knock. Music off, car dies instantly. I have to push it off the road. Kid put the wrong oil filter on, it blew off 30 feet from the shop and left a trail of oil for 2 miles. Kid kept his job somehow. they replaced her engine and the car had 240k miles on it and got an engine with 112k. Halved the mileage.
  18. Jun 28, 2019 at 12:26 PM
    #478
    Tommyb08
    Tom
    A few months back I had jacked up my back and my neighbor offered to change my oil for me as I was due. He told me he was good and knew where the drain pan was. I guess he had a brain fart, but at least he stopped when he saw the red fluid coming out :anonymous::rofl:.
  19. Jun 28, 2019 at 12:51 PM
    #479
    Bleep100
    Bleep100 [OP] TOYOTA 4 LIFE
    17 Sport
    That sounds good :bananadance:
    PzTank[QUOTED] likes this.
  20. Jun 28, 2019 at 1:06 PM
    #480
    Bleep100
    17 Sport
    I worked construction and we had a rule that no one on our crew was aloud to say piece of cake , you know why .
