What is the worst mistake you made doing your own wrenching?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bleep100, Feb 24, 2019.
  1. Jul 21, 2019 at 2:05 PM
    #521
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I tried Changing the brakes on my Grand Am once, rounded the bolt on the caliper, tried easy outs which just shaved the bolt head even more. Had to throw in the towel and take it to a shop that welded a nut on and got it out with heat.
    PzTank, My Name is Rahl and tcjacado like this.
  2. Jul 21, 2019 at 6:16 PM
    #522
    Frankenstuff
    Frankenstuff Busy iracing
    Frankie
    16TRDORDCsb 4x4 & 2020 BMW M2 competition
    16 trd ORdcsb4x4 c4 swingout rear, cbi t3 front , arb lift,16"grabber x3 rtt, hilift,jerry cans,and sliders . 81 hilux trail donkey
    Let it turn into my profession.
    Slashaar and auskip07 like this.
  3. Jul 21, 2019 at 6:31 PM
    #523
    whitepony04
    whitepony04 The Big Igloo is coming...
    Tanner B
    Oklahoma
    19 trdordcsbxyz
    Eibach pro kit, 3 leaf aal, ecgs, fn fx pros, bfg ko2, gator sfx, Meso stuff
    Bought one of these oil containers to change wife’s oil in her grand Cherokee. Ended up with 6 qts of oil on my garage floor. 10 minute oil change turned into 90 minute cleanup.
    Slashaar and PzTank like this.
  4. Jul 21, 2019 at 6:41 PM
    #524
    My Name is Rahl
    What was wrong with it?
  5. Jul 21, 2019 at 6:43 PM
    #525
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    What was wrong with it? I use something like that sometimes because it will hold the fifteen quarts from my truck.
    PzTank likes this.
  6. Jul 21, 2019 at 6:44 PM
    #526
    whitepony04
    Tanner B
    Oklahoma
    19 trdordcsbxyz
    Even with the vent open, the draining oil cannot go down the hole fast enuff. It overflows the sides and gets everywhere. I should have read the reviews.
    Slashaar likes this.
  7. Jul 21, 2019 at 6:46 PM
    #527
    whitepony04
    Tanner B
    Oklahoma
    19 trdordcsbxyz
    I took my pro charger piping off to paint it. I stuffed some plastic grocery sacks inside the piping to prevent overspray dust from getting on interior of piping. Reassemble everything and car won’t start. Guess what I left inside the piping...
    Bastek likes this.
  8. Jul 21, 2019 at 7:18 PM
    #528
    eon_blue
    Azusa, CA
    Weird, I have one of those (might even be the same one) and that never happens. Maybe the Jeep drains faster than the Tacoma does?
    My Name is Rahl likes this.
  9. Jul 21, 2019 at 7:19 PM
    #529
    eon_blue
    Azusa, CA
    @BartMaster1234 had a similar experience recently installing his supercharger....
    didn't you Tyler
    Slashaar and My Name is Rahl like this.
  10. Jul 21, 2019 at 7:33 PM
    #530
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I have no idea what you’re talking about...
    :luvya:
    Slashaar, Bastek, PzTank and 3 others like this.
  11. Jul 21, 2019 at 7:34 PM
    #531
    CTtoNoVa
    CTtoNoVa Well-Known Member
    2017 DCSB TRD OR Magnetic Gray
    Pop N Lock
    Overfilled blinker fluid
    Slashaar and cosmicfires like this.
  12. Jul 21, 2019 at 8:21 PM
    #532
    6 gearT444E
    Deep South
    Herculiner Hootus
    Two bad ones for me.
    First one was many moons ago. Changing oil filter out on my old 6th gen civic with the d16 engine. For those of you who've owned one of those, know that the filter is in between the firewall and block and barely visible; basically feel for it and thread the new one back in. I installed the new one not realizing I left the gasket from the old one still on the block. Didn't bother to check for oil leaks afterward. Got about 20 miles from home and damn near blew the engine, luckily I filled it back up with oil and limped back home and realized what my dumb ass has done. Now I ALWAYS make sure the old gasket comes off with the old filter.
    Second was last year, re-assembling my F350. Had the 7.3 pulled and was putting everything back together. Went to start it up and the starter sounded like it shorted out. Well turns out it did, the ZF6 transmission cooler lines run real close to the starter solenoid bolts, turns out I bent one of the cooler lines re-assembling. Once the engine turned over the transmission pumped about a gallon of oil on the ground before I realized what was going on and shut it off. Luckily all it cost me was replacement lines, which probably weren't a terrible idea anyway considering the truck is almost 20 years old now. Lesson learned, ALWAYS check clearances of stuff when putting back together :D
    Slashaar, Bastek, TomTwo and 3 others like this.
  13. Jul 22, 2019 at 7:01 AM
    #533
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Oh yeah, blame it on the pan :D:rofl:
  14. Jul 22, 2019 at 7:04 AM
    #534
    PzTank
    Above the Notches
    I use a slightly different large capacity Flotool from Wally World for my 10 quart 5.2. Works like a charm (except the little vent tube cap hasn’t snapped on since the first week I’ve owned it) and those 10 drain FAST...
  15. Oct 15, 2019 at 5:16 PM
    #535
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I just changed the diff fluid and realized I put the fill plug in the drain position. Only realized that 2 qts into the refill.:facepalm:
    That's what I get for finishing in the dark. Guess I can treat it like I'm flushing the diff with new fluid to make sure I got all the old stuff out, right?!
    ughhh. I'll change it again next week or whatever. Gotta get paid and buy more fluid. I hate dumb mistakes. :frusty:
  16. Oct 15, 2019 at 6:39 PM
    #536
    gwynn1975
    gwynn1975 Well-Known Member
    2018 Tacoma
    Chevy 63 swapped 35’s Custom dents
    Shattered my finger tip. Doctors wanted to amputate from the first joint up but I decided to have a deformed finger instead of a nub
  17. Oct 15, 2019 at 6:48 PM
    #537
    Itchyfeet
    Itchyfeet Well-Known Member
    I did that on a vw jetta
    Slashaar and Bleep100[OP] like this.
  18. Oct 15, 2019 at 7:11 PM
    #538
    jon_elc
    jon_elc Well-Known Member
    NorCal
    2011 SR5 4x4 Timberland Mica Snugtop Rebel
    245-70R-17 Revo3 Cut mudflaps 4.5" F / 1.5" R
    when i was like 11-12 yo, i was helping my dad rotate tires on the 4x4 f-100, but I thought i was being more efficient by leaning the tire against the side of the garage instead of laying it flat on the driveway.
    A little while later, I bumped into it and it rolled down the driveway, into the street and down the hill. When i was trying to chase it down, i was too scared to try to grab it or try to kick it over and it accelerated down the hill until it crashed into the curb and flew up into the driver's door of a neighbor's pickup. Stupid kid.
  19. Oct 15, 2019 at 7:13 PM
    #539
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Show off the aftermath
  20. Oct 15, 2019 at 7:45 PM
    #540
    Jermstn
    Jermstn Active Member
    2018 TRD Sport DCLB
    Remember to always use jack stands.
    Ended up deleting the finger nail, fingerprint and rearranging pieces of the bone.
