What is the worst mistake you made doing your own wrenching?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bleep100, Feb 24, 2019.
  1. Feb 26, 2019 at 4:58 AM
    #141
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    Had an ex with a Pontiac Grand and her door lock knob somehow fell down into the door panel, but i could just touch the top of it with the tip of my finger, but no way to pull it up. So i got superglue and the plan was to put one drop on my finger, glue it to the knob and pull it up, then put acetone on the glue to release my finger. Put glue on finger, inserted into hole, and immediately glued myself to the side of the hole which my finger just fit into... Stood there in her driveway in the sun looking like an idiot for a long time and eventually had to pull the skin off.. lol
  2. Feb 26, 2019 at 5:03 AM
    #142
    swissrallyman
    The worst one was with my 2010 Tacoma, went to do a radar detector install, had the dome light cover off and went to drill a hole in the little metal bracket for a ground wire. Brand new tiny titanium drill bit, cordless drill, was givin'er and it was hard to get started because that bracket had some flex to it, so I was leaning on'er. Finally she took, and the drill bit flew through it in a millisecond, and then continued right through the roof. Truck was about 1 week old with a 1/8 hole drilled though the roof. Had a dab of sealant on there for the rest of its life...
  3. Feb 26, 2019 at 5:14 AM
    #143
    CRCs Reality
    CRCs Reality Well-Known Member
    Pittsburgh-Ish
    2017 DCSB TRD Sport (OVTuned)
    on my 1985 Toyota SR5 x-cab..
    Adjusted the valve clearance when it was still hot (IIRC, manual specified to do this cold), which resulted in burning an exhaust valve.
    Which resulted in me pulling the head to take it in for a valve job, in December, in Colorado above 9000 feet with no garage.
    Oh, the 22r has an aluminum head and cast-iron block, so when you have the head redone, you're supposed to do some work on the block so they seat properly, but my 22 year old self was too broke to do that. So I did my level best to sand and clean the block myself (again, December, Colorado, 9000 feet, no garage, etc, etc).
    Which resulted in a blown head gasket a few hundred miles later. And another a few hundred miles later. When the head gasket blew the second time, I was 4-wheeling (longwater gulch) and slid backwards downhill into a tree on the passenger-side, trashing the passenger door and front fender.
    Traded it in on an 88 4-runner the next day, and have been extra careful when doing maintenance ever since.
    robssol, cshrum and xxTacocaTxx like this.
  4. Feb 26, 2019 at 5:15 AM
    #144
    ETsemaj
    ETsemaj @Koditten Pirate Radio member #001
    James
    Cape Canveral, FL
    2018 Cement Tacoma Off Road
    speaker and tweater upgrade DMM phone mount and a large wishlist
    Thouht i would be nice and drive a friend home after work. Went to shift my car (04 dodge neon) into R and wouldnt shift. would go into 1-5 fine just not R. well i drop her off and i start looking at my car. luckily i had some tools in the car and i started taking the center console out, everything looked fine. So then i try to get eyes on the tranny. well the battery tray was in the way so i start popping bolts out. wasnt paying attention on the last bolt and i had the rachet wrench end on the bolt. next thing i know, the bolt is just a few threads from coming out but with the wrench on, its stuck against the transmission. and there was no way to get the bolt back in at all to get my wrench back. sold it to the dealer for my 2018 Tacoma. And atleast i know where one of my 10mm wrenchs went.
  5. Feb 26, 2019 at 5:57 AM
    #145
    Mountain Minstrel
    Mountain Minstrel Well-Known Member
    Prather, CA
    '17 DCSB MT INFERNO
    My '80 Yamaha XS1100 rounded the second gear dog in the transmission which was the very last part that comes out of the engine cases. So I split the cases and took a Dremel tool and undercut all the dogs (never missed another shift but neutral was hard to find). Anyway after putting the whole thing back together as I'm putting the cam caps on I drop a washer and watch as it goes right down the opening for the cam chain. I tried for the longest time to get it out with a magnet but ended up having to split the cases again to get it out.
    Lesson learned … cover all openings every time.
    robssol, cshrum, whatstcp and 2 others like this.
  6. Feb 26, 2019 at 6:05 AM
    #146
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Has anyone successfully replaced an 04 ford f150 5.4L spark plugs, without breaking one?
  7. Feb 26, 2019 at 6:06 AM
    #147
    CleanWilly
    CleanWilly Well-Known Member
    2017 Access Cab Offroad
    Working with a sprocket on my race bike, I needed to tap lightly with something. Should have gotten a small hammer or wrench but I was in a small space between my wife's car and the garage wall and didn't want to walk to my work bench. Within reach was a can of flat black spray paint and I thought 'hey, I can just use the rim on the bottom of the can'. A few light taps later and I punctured the can, emptying the contents all over the side of my wife's two week old Civic. I quickly grabbed a rag but it was almost immediately dry and it did nothing. Lots of laquer thinner, and LOTS of elbow grease later, it was gone. She forgave me. Eventually....
  8. Feb 26, 2019 at 6:08 AM
    #148
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Not me, but my dad tried changing the oil on his brand new BMW Adventure and just torqued the screw in how he saw fit...started leaking. Had to ride it like that from Mission up to the nearest BMW motorcycle dealership aka the one in Austin.
  9. Feb 26, 2019 at 6:31 AM
    #149
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Gasoline plus styrofoam= Napalm
    Atleast that’s what I learned from the anarchist cookbook :devil:
    AxisCab likes this.
  10. Feb 26, 2019 at 6:53 AM
    #150
    MFTAF13
    MFTAF13 "If it ain't broke, fix it till it is"
    Bob
    NorCal
    13 MGM TRD OR
    Lift, sliders, skids & some other stuff.
    Ever notice how paint applied normally takes forever to dry. But paint applied accidentally...dries almost instantly ?
    Bastek, Skydvrr, ABA180 and 10 others like this.
  11. Feb 26, 2019 at 7:05 AM
    #151
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    bought a TORNADO gas saver for my 3.4l TRD truck, of course. I still have it as a momento if anyone wants it i'll send it to ya but u pay the shipping. fits 3.4l intake hose and your guaranteed to get 30 mpgs. https://youtu.be/yRxTwzOvS7Q
  12. Feb 26, 2019 at 7:06 AM
    #152
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Please tell me you’re joking?
  13. Feb 26, 2019 at 7:07 AM
    #153
    BillsSR5
    bill
    2014 SR5
    nope
  14. Feb 26, 2019 at 7:09 AM
    #154
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    :violent:
  15. Feb 26, 2019 at 7:13 AM
    #155
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Using a cheap torque wrench on an $1,800 aluminum jet ski head.
    $40 dollar wrench wound up costing me $1,840.00.
  16. Feb 26, 2019 at 7:15 AM
    #156
    BillsSR5
    bill
    2014 SR5
    ouch!
  17. Feb 26, 2019 at 7:25 AM
    #157
    jmneill
    SE
    Lesson learned.
    Far better off using your own good judgement over putting faith in a cheap torque wrench.
  18. Feb 26, 2019 at 7:34 AM
    #158
    Dkurtz42
    Dkurtz42 Bill Hwang
    David
    Barberton, OH
    2023 Tacoma DCLB TRD SPORT 4x4
    - Gator ETX Soft Roll Up Tonneau - Clazzio black leather seats - Nitto Ridge Grappler 255 80 17 tires - Supreme Suspensions 2" and 1" lift
    Came close once. BP has green for regular gas and black for diesel. Was trying to fill up diesel on a hazy morning so I went for the green, which is the color of diesel at most stations. Tried at least 4 times and couldn't get it to start. My credit card wasn't working luckily. Finally figured it out before the pump would kick on. A worn credit card strip saved my butt.
    HappyGilmore and EatSleepTacos like this.
  19. Feb 26, 2019 at 7:46 AM
    #159
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    But there are so many people here who swear by their harbor freight tools....
  20. Feb 26, 2019 at 7:58 AM
    #160
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Was running Nitrous Oxide on a small block Chevy, lots of fun. Decided it wasn't enough and stepped it up a notch with a 125HP jet. It was alot of fun the first 3 times I hit the button. Mind you that this was at Pismo Dunes Comp Hill, someone on here might have even seen this go down. On the 4th time I pushed that little button of joy, the motor let me know it had had enough in a real bad way. Lots of fire, smoke, the smell of oil and and a trail of parts where it decided to just shit its insides out all over the hill. Was done with this toy after that. Live and learn.
    Wulf, eccracer104, robssol and 4 others like this.
