What is this bilstein nonsense?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tmat, Jun 20, 2009.
  1. Jun 20, 2009 at 12:11 PM
    tmat
    tmat [OP] Well-Known Member
    Treavor
    Cypress, CA
    07 Regular Cab, PreRunner
    BHLM, de-badged, custom Manoukian flowmaster exhaust system, Bilstein 5100 front adjustable shocks set at 1.75", "smoked" foglights, Satoshi grille mod, 265/75r16 BFG T/A KO tires, AFE Pro Dry S air filter, solid rear window, Weathertech floor liners and painted grill surround
    "NOT RECOMMENDED FOR USE WITH LIFT SPACERS OR COILS UNLESS LOWEST (STOCK) SETTING IS USED." taken from Toytec.com
    This is what it says about the Bilstein's...so does that mean if I get the toytec coilovers I can't adjust them? And when i say them I am referring to the bilstein shocks. And how are coilovers even adjustable? Help...
  2. Jun 20, 2009 at 12:20 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    The bilsteins have notches on them to compress the coil and provide lift. Coil spacers already compress the coil. As for why you can't use them with lift coils I'm not sure.
  3. Jun 20, 2009 at 1:00 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You can use lift coils or spacers with the 5100 above the stock setting because it preloads the springs too much and can unseat the spring perch (in theory). IDK if it's ever happened...but what you willl most likely notice is a really rough ride if you try.
    As for the Toytec coilovers- They have a threaded collar that sits on the spring perch at the stock setting. Adjust the ring where the spring sits up and down along the threaded collar and you get your adjustable lift.
  4. Jun 20, 2009 at 1:27 PM
    tmat
    Treavor
    Cypress, CA
    so basically what this thing is saying is If I get coil overs and install them with the bilstein shocks I cannot adjust the bilsteins or the coil overs? The statement is ambiguous, which is why I'm confused.
  5. Jun 20, 2009 at 1:33 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    No. You have to set the billies at the stock setting and then you can adjust the coilovers how ever you'd like. The coilover uses a piece that is separate from the shock to adjust.
  6. Jun 20, 2009 at 1:40 PM
    tmat
    Treavor
    Cypress, CA
    Oh got it got it. And the shocks already give lift right? So if I have the coilovers at the stock setting I'm getting a ~2" lift?
  7. Jun 20, 2009 at 1:48 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    No... the shocks have a collar that can be moved up and down the body of the shock. With your stock springs you can move that collar and get two inchs of lift.
    If you use aftermarket lift springs with the 5100's (for the better ride) you set the collar on the shock so it is the same length as a stock shock and the lift comes from the coil.
    The coilovers kit fro Toytec uses the coil and a threaded part to provide a variable amount of lift. So the 5100 collar will go at the stock location and the coilover collar will go on top of that.
  8. Jun 20, 2009 at 2:53 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    As Brunes already said...
    Lift coils OR spacers already have an extreme amount of force to lift your vehicle.
    The *coil seat* (where the bottom of the coil sits) is located on the shock itself. Having a lift coil OR spacer AND adjusting the 5100's higher than the stock setting - you run a risk of breaking the shock where the coil seats.
    There's just too much pressure for the shock to handle.
    That's why you'll see that warning...
  9. Jun 20, 2009 at 3:06 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    With the stock setting on the Bilsteins and the Toytec coilovers, you'll get up to 3" of lift. All it's saying is that you can't combine the two to get even more lift (e.g. you can't set 2.5" on shock plus 3" with spacers or the coilovers for a 5" lift).
  10. Jun 20, 2009 at 8:21 PM
    tmat
    Treavor
    Cypress, CA
    ahhh I see. It all makes sense now. Thanks guys!
