What is this connector?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Versus78, May 16, 2020.
  1. May 16, 2020 at 1:59 PM
    Versus78
    Versus78 [OP] Member
    Sébastien
    2016 Tacoma, TRD Sport
    Hi guys,
    I was just routing a cable in the cab and noticed that 2 pins connector, on the drivers side.
    Is it supposed to be plugged somewhere?
    I have a 2016 Trd Sport, DBL Cab. automatic transmission.
  2. May 16, 2020 at 2:00 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    That's the 10+ HP button! Where's this at? Driver's kick panel?
    GillyLink likes this.
  3. May 16, 2020 at 3:11 PM
    Versus78
    Sébastien
    Actually it just up and right from the accelerator, I think the green connector goes to a blower motor/vent control for climate control. Tubing is for Air-conditioning I guess... There doesn't seem to have any other accessories I can connect this connector to... And all accessories are working.
    I'm just wondering what it's for ...
  4. May 16, 2020 at 3:13 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Crawl control. You don't have it. :rofl:
    Bleep100 likes this.
  5. May 16, 2020 at 3:18 PM
    Versus78
    Sébastien
    Damn!! :)
  6. May 16, 2020 at 5:20 PM
    caribe makaira
    Caribbean, Puerto Rico
    Versus78[QUOTED][OP] likes this.
  7. May 16, 2020 at 5:31 PM
    caribe makaira
    OP, what color are the wires to the 2 pin connector?
    Rouge et bleu?
  8. May 16, 2020 at 5:42 PM
    Versus78
    Sébastien
    Yes!
    Rouge et bleu!
  9. May 16, 2020 at 5:44 PM
    caribe makaira
    Il semble que ce soit un système que votre véhicule ne possède pas ...
  10. May 16, 2020 at 5:47 PM
    Versus78
    Sébastien
    I'm curious about what is a "clearance warning ECU". Like one poster replied, it might be related to the "crawl mode" of the Trd Offroad?
    Would it be possible to have a copy of your diagram?
  11. May 16, 2020 at 5:50 PM
    caribe makaira
    It is the little round things on the rear bumper...it gets louder as the vehicle approaches a possible collision while moving slowly...
    Skydvrr and Versus78[OP] like this.
  12. May 16, 2020 at 6:00 PM
    Versus78
    Sébastien
    Ok I don't have that option. Makes sense :)
    Thank you!!
  13. May 16, 2020 at 6:01 PM
    caribe makaira
  14. May 16, 2020 at 6:04 PM
    caribe makaira
    Follow the wire to the center console area, see if you have this connector:
    It should be behind the center console switches, below the head unit.
  15. May 16, 2020 at 6:13 PM
    caribe makaira
  16. May 16, 2020 at 6:25 PM
    Versus78
    Sébastien
    Thank you ! That's good information. You seem to know the electrical of that truck pretty good. :)
    I don't have issues with the system.. I was routing a coax cable for Ham radio installation in my truck and when I was zip-tying the cable I noticed that connector. From what I understand about the diagram that connector would be to connect the buzzer if I had the sensors installed in my bumper...
  17. May 16, 2020 at 6:37 PM
    caribe makaira
    You are correct...
    :thumbsup:
  18. May 16, 2020 at 6:49 PM
    STrooper
    STrooper For HIS glory!
    Jack
    NC
    2018 TRD Sport QuickSand / 2020 TRD Sport Cement!
    So the other question is, would it be possible to install an actual bumper sensor since your truck is pre-wired? I wonder if mine has the same connector, mine is a 18 Sport.
  19. May 16, 2020 at 6:56 PM
    Versus78
    Sébastien
    Well, I don't want to tear down my console but I am assuming that the cable is pre-installed but the clearance ECU isnt there either...
