What is this going into the rear differential?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by perpetualenigma3, Dec 25, 2016.
  1. Dec 25, 2016 at 8:21 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    dude...pretty sure?
    its certainty haha. With your build dealer won't even know what they are looking at haha.
    Best of luck though brother.
    Perhaps when it was leaking it was damaged, like something hit it.
    Or when replacing the o ring you over torqued it and damaged something?
    phillstill and Biscuits like this.
  2. Dec 25, 2016 at 8:34 AM
    perpetualenigma3
    perpetualenigma3 [OP] Well-Known Member
    Mr.
    Im here and there. Mostly there than here.
    2016 QuickSand Taco TRD OffRoad
    A new bolt here, a new bolt there, a new bolt everywhere.
    Yes with the switch out it is disengaged
  3. Dec 25, 2016 at 8:35 AM
    perpetualenigma3
    Mr.
    Checked it all I did was pull it out to swap the oring out because the other one was damaged
  4. Dec 25, 2016 at 8:37 AM
    perpetualenigma3
    Mr.
    Probably I should have just let it leaked and took it to the 4x4 shop on the 28th to fix the leaking. Now I have a whole new set of problems like getting it there.
  5. Dec 25, 2016 at 8:37 AM
    Bxnanaz
    Bxnanaz Well-Known Member
    2021 Tacoma TRDOR 6MT
    Have you tried:
    -Pulling it out
    -Pressing the locker button
    -Re-install
  6. Dec 25, 2016 at 8:38 AM
    perpetualenigma3
    Mr.
    Yes, I tried that and lifting the wheels and rotating the wheels manually while pushing it in
  7. Dec 25, 2016 at 8:39 AM
    Bxnanaz
    Damn. That's weird for sure.
  8. Dec 25, 2016 at 8:44 AM
    perpetualenigma3
    Mr.
    Yes for the life of me I can't figure out what it is or how it goes in. It doesn't retract and only extends
  9. Dec 25, 2016 at 8:57 AM
    perpetualenigma3
    Mr.
    If I could at least figure out what part it is maybe I could find how it goes in the differential
  10. Dec 25, 2016 at 8:58 AM
    Bxnanaz
    Definitely one of the downsides of having a new truck :/
  11. Dec 25, 2016 at 9:04 AM
    Midnighttaco08
    Midnighttaco08 Traffic Direction Moonlighter
    Sam
    Gilbert, AZ
    08 DCSB Indigo Ink TRDOR 2017 CM Tundra TRD OR 4x4
    Some Bubble Gum and Duct-Tape IG** Midnighttaco03 Camburg uni-ball UCA w/ CO Rear Dakar with Fox 2.0 bottom overload removed GG G3D radius bar 50" roof mount GG G3 straight 32" front valence Rago fab bed clamp pod mounts 2 GG amber pod rear OTRATTW custom switch panel in sunglass holder K&N cold air Gibson exhaust Alpine INA-W900 head Mr. Marv box and amp rack IDQ-10 - Interfire Mono Focal fx45 component front Alpine type S Co-ax rear Homer taco TRD Grill GG LED low/high beam TRD seat covers OEM bed mat Weathertech floor mats with replacement TRD-OR decals Weathertech in-channel vents GG Flush mount pod replament fog light kit GG green ditch mount 3x2 pods Fog lights anytime Tailgate hoseclamp mod LED dome light LED map lights LED reverse lights LED license lights Rear window decals: Mall rated, Tacomaworld.com, U-Haul power tow, soundtech, mammoth.
    This sounds stupid, but have you tied to drive the truck turning slightly side to side? Sometimes the locker wil get stuck and the truck needs to be rolling to disengage.
    Happens to me every once in a while.
    Biscuits and ZachPrerunner like this.
  12. Dec 25, 2016 at 9:11 AM
    Joe23
    if you have it taken out it disengages right?
    any way to put the plug in so it doesn't leak but keep the connector for the solenoid disconnected maybe? That way you can at least drive?
    I can't find anything on it in the manual so not sure, but could it be the solenoid is damaged? Or is it retracted already and it just seems like it should retract more?
    I think someone mentioned earlier it works on a switched ground? Try following the cable, maybe it got damaged somewhere and is grounding out on the frame or something so completing the circuit.
  13. Dec 25, 2016 at 9:12 AM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    He's correct. I'm not sure if the 3rd gens have the same disengagement process, but my prerunner is the same way. The locker will stay engaged until I turn side to side while rolling for a minute or two.
    Biscuits likes this.
  14. Dec 25, 2016 at 9:14 AM
    Joe23
    this is why I hate E lockers lol.
    ZachPrerunner[QUOTED] likes this.
  15. Dec 25, 2016 at 9:17 AM
    #35
    perpetualenigma3
    Mr.
    Yes I sir tried that too. I a stumped
  16. Dec 25, 2016 at 9:17 AM
    #36
    perpetualenigma3
    Mr.
    lol
  17. Dec 25, 2016 at 9:21 AM
    #37
    ZachPrerunner
    Southeast TN
    Damn turd gens always acting up ;)
    tomwil likes this.
  18. Dec 25, 2016 at 9:51 AM
    #38
    Joe23
    did you try the jeremy clarkson tool?
  19. Dec 25, 2016 at 9:55 AM
    #39
    hirod
    hirod Well-Known Member
    hawaii
    16 double cab short bed OR
    did you try disconnecting the battery?
  20. Dec 25, 2016 at 9:56 AM
    #40
    Aussiedogs1
    Aussiedogs1 Well-Known Member
    SW Montana
    2013 TE 4runner
    It looks just like the same set up as in the jeep rubicon lockers. (But better being a Toyota) and electric and not vacume. There is a plate inside that pulles the switch out and the switch has to get behind the plate. Which you must disassemble the 3rd member to reinstall the switch correctly. learned the hard way on that one. Never have had the one on my 4runner apart being a Toyota but I'm guessing the same set up. If it is like that don't drive it.
