What is this hoes!!! Help! It's leaking everywhere.
Discussion in '1st Gen. Tacomas (1995-2004)' started by bhh2000, Dec 21, 2011.
  1. Dec 21, 2011 at 11:32 AM
    bhh2000
    bhh2000 [OP] Well-Known Member
    Ben
    Santa Rosa
    2016 DCLB TRD 4X4
    What is it?! Just looked under my truck and saw a huge amount of some kind of hydraulic fluid!?? It seems to be coming from here! Is it an overflow or something? it's in the drivers side next to the block! Any help would be very appreciated.
  2. Dec 21, 2011 at 11:34 AM
    toysr5man
    toysr5man Auto thrasher
    Doug
    downtown, castile ny
    03 tundra trd. 01 taco 4x4 4cyl.
    5100 billys, add a leaf, 6.5 ' meyer plow, 265/75/16. diff drop, tundra brake upgrade, wheelers stainless stell braided brake lines, steering column mod
    to me it looks like the breather for the front diff. have you changed front diff fluid lately? if so did you overfill it?
  3. Dec 21, 2011 at 11:38 AM
    okboatie1
    okboatie1 Well-Known Member
    Darrell
    Chula Vista, CA.
    03 PreRunner TRD SR5 DCSB
    OME 881's w/Dakar's, Deckplate mod, Debadged, door chime mod, 12V outlets always on,
    Yea, looking like a diff breather to me too.
  4. Dec 21, 2011 at 11:39 AM
    rcbs204
    rcbs204 Well-Known Member Vendor
    ^^ yep this
  5. Dec 21, 2011 at 11:40 AM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Damn hoes always actin a fool
  6. Dec 21, 2011 at 11:42 AM
    okboatie1
    Darrell
    Chula Vista, CA.
  7. Dec 21, 2011 at 11:49 AM
    beerye
    beerye Steel Curtain!!
    Brian
    Tucson, AZ
    02 TRD 4x4 5spd
    3" suspension lift 2009 Tacoma Alloys K&N Intake
    Yup its the diff breather, check your fluid levels
  8. Dec 21, 2011 at 12:02 PM
    bhh2000
    Ben
    Santa Rosa
    2016 DCLB TRD 4X4
    Diff breather? I have never Touched the diff since I bought the truck 8 months ago...
    I'd say there is about 8+ ounces of fluid on everything around and under it.... No idea how much has dropped off. Is it still a good idea to drive it?
    My speedometer cable is problematic. This morning when it was below freezing it was being noisier then hell and the needle was vibrating around alot. Could this have anything to do with it?
    How do I check my diff fluid level?
  9. Dec 21, 2011 at 12:24 PM
    okboatie1
    Darrell
    Chula Vista, CA.
    There should be a fill plug and a drain plug on the differential. the drain plug is on the bottom, and the fill plug is about halfway up. Make sure you can loosen the fill plug if you plan on changing/draining the fluid or you could screw yourself. Next, take the fill plug out and stick your finger in there. If you can feel the fluid you should be good. It may be a good idea (depending on how recently it's been done) to drain it and look at the condition it's in. Good luck.
  10. Dec 21, 2011 at 12:35 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    how the hell would the diff breather be leaking?
    although i agree with that it looks like the transmission of front differential breather.
    i was just never aware that fluid could be pumper out of them lol.
  11. Dec 21, 2011 at 12:39 PM
    okboatie1
    Darrell
    Chula Vista, CA.
    Yea, you got me on that one. I'll take a WAG and say (looking at the pic) with all the dirt/mud build up on the breather, it may not have been functioning correctly and had too much pressure build up until it found a way out. but like I said, that is just a bs answer at best.
  12. Dec 21, 2011 at 12:39 PM
    Loudpedal
    Loudpedal Mind = Blown
    Blair
    Not really New, not really Mexico
    02 SR5-Hole 4x4
    Andres Devil Horns, Goodyear Duratracs, Accidental Tailgate Delete (x2), Billy 5100s, OME 881 coils, Wheeler's 5-leafs, BAMF Sliders with kickouts, Box Rocket Fab Bedrack.
    Follow the line and see where it goes. Post a pic of that so we can verify.
  13. Dec 21, 2011 at 12:42 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    I agree that it looks like the breather for the front dif, and I thought the dif/tranny/tc all came to 1 breather too. I remember looking into rerouting them to do that and noticing that it was already done. Or at the very least they came to the same point.
  14. Dec 21, 2011 at 1:27 PM
    mdub
    mdub Well-Known Member
    Missouri
    2016 Black DBLC TRD Off-Road
    ARE CX
    Search on here to find your fill and drain plug.
  15. Dec 21, 2011 at 1:31 PM
    bhh2000
    Ben
    Santa Rosa
    2016 DCLB TRD 4X4
    I'm following the line right now what do you guys think about the speedometer cable? Could that have anything to do with it?
  16. Dec 21, 2011 at 1:32 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I thought this thread was about something else. :(
  17. Dec 21, 2011 at 1:42 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    No,
    Looks like you may have something plugging your breather.
    Have you gone into any deep water lately?
  18. Dec 21, 2011 at 2:35 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Its the front diff breather.....
    I had a similar (but smaller) issue on my 96 many years ago. I never did find out what the problem was.....and other folks had the same issue. I think it was just the design of the diff and how it vented especially when it got really hot.
    I checked & changed the diff fluid and put a new (and extended) breather hose on it. So - even if it did vent up the hose, the oils would flow back down into the diff when things cooled off.
    Since you've lost so much oil, you need to check the oil. It'd be a good idea to change it too....easy peasy. Take the diff breather hose off and make sure its not clogged and fully clean before putting it back on.
  19. Dec 21, 2011 at 2:36 PM
    jackhart
    jackhart Well-Known Member
    11 DCLB
    only reason i clicked on it too. where are these leaky sluts?
  20. Dec 21, 2011 at 2:48 PM
    bhh2000
    Ben
    Santa Rosa
    2016 DCLB TRD 4X4
    Hmmm, alright. So I'll change my diff fluid then. Do you think should drive with it having lost a lot?
