What is this in my glovebox?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fly4food84, Aug 7, 2008.
  1. Aug 7, 2008 at 6:45 AM
    fly4food84
    fly4food84 [OP] Active Member
    New Orleans, LA
    PreRunner
    I opened my glovebox today and on the side closest to the door was a black cylinder like object with a grey cap attached to the glovebox. What is it???
  2. Aug 7, 2008 at 6:52 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Nevermind.
    I misread your post.
  3. Aug 7, 2008 at 6:53 AM
    tdm156
    tdm156 Well-Known Member
    San Antonio, TX
    2009 DC 4x4 SR5**Sold
  4. Aug 7, 2008 at 6:57 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    does your glovebox slam open or gently close?
    If it slams open, then you need to reconnect the damper to your dash.
  5. Aug 7, 2008 at 6:57 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    It maybe the shock, so the glovebox doesn't just fall when opened.
  6. Aug 7, 2008 at 7:00 AM
    fly4food84
    New Orleans, LA
    PreRunner
    Oh, it was never connected!
  7. Aug 7, 2008 at 7:01 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    if it wasn't pressed on all the way, it can pretty easily pop off.
  8. Aug 7, 2008 at 7:29 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I bet the Ridgeline doesn't have all these problems.
  9. Aug 7, 2008 at 7:31 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    Damn it I knew I should of bought one. :laugh:
  10. Aug 7, 2008 at 2:23 PM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Same here :D
  11. Aug 7, 2008 at 3:23 PM
    Synapse
    Synapse Well-Known Member
    Birmingham
    2008 Tacoma
    how does it connect? i mean, the glove box seems to be in the way connecting it and ther is only two options to hook it back up.
  12. Aug 7, 2008 at 9:41 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    No, because they a tampon holder in that spot instead.
  13. Aug 7, 2008 at 10:40 PM
    Synapse
    Birmingham
    2008 Tacoma
    Hahaha, my wife thinks ridgelines are cute. Enough said.
    silverback07 Thanks for taking the time to take pics and write that up. Im able to fix it now!
  14. Sep 8, 2008 at 9:54 AM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    I have the same problem. I am going to try to slide a plastic sleeve (ink pen barrell) over the bent nub, then drill through it as Siverback did. If possible, I want to use a stainless machine bolt so I can reinforce both ends with washers and put a nut on the back side of the plastic panel that the nub is attached to. If successful, I'll take pics. I am thinking it might be a little more permanent and sturdy solution. I may also epoxy a larger washer onto the back side of the flat panel the nub is attached to for better support. This entire set up is FUBAR 200%. Toyota did a great job designing this truck, but certainly failed here. Does anyone know if they fixed this in the 20007-2009 models? Just got through installing a Peripheral iPod interface adapter. I also removed the panel that both right and left center air vents are attached to....a bit more tricky, but done sucessfully. I keep my ipod in the tray to the lower right of the steering column. Phil
