What is this in my power steering pump
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kevins60, Feb 5, 2023.
  1. Feb 9, 2023 at 3:04 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Sometimes you need to vent to people that can understand it does help
    Kevins60[QUOTED][OP] likes this.
  2. Feb 11, 2023 at 12:20 PM
    Kevins60
    Kevins60 [OP] axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    I did the flush this morning and only made a small mess. A little bit of brakleen and half a roll of paper towels later and it’s all good. Fingers crossed my leak stops.
    Bivouac, Kwikvette and Wulf like this.
  3. Feb 11, 2023 at 4:28 PM
    Bivouac
    :fingerscrossed::fingerscrossed::fingerscrossed::amen:
  4. Feb 11, 2023 at 4:37 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    I always make a mess when swapping power steering fluid. I use a Mityvac hand pump, but I always manage to spill some.
  5. Feb 11, 2023 at 6:37 PM
    Kevins60
    Kevin
    Odessa FL
    I turkey basted as much as I could from the reservoir and I would have been fine except that the hose I was going to use to plug the reservoir inlet was too small. I didn’t let that stop me from trying to jam in on while power steering fluid kept pouring out. I’ll get it right next time.
  6. Feb 17, 2023 at 12:00 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The latest Toyotas with hydraulic PS still use ATF, with Dexron/Mercon (Dexron III) as the spec. That is also what Toyota recommends for older vehicles that called for Dexron II.
    Jeff
  7. Feb 17, 2023 at 2:08 AM
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    How long did this take you ? Sounds like a second person to help would make it much easier?
  8. Feb 17, 2023 at 7:54 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Really getting front end up in the air......and finding a tubing union was 90% of the job....
    really only took minutes.......there's not much fluid in that whole system.....
    just have to go slow and keep refilling the res......
    I've seen others do it with the engine running........yeah big mistake....
    pumps just fine....with engine off.....trust me.......
    Beauty of it is.....now I can use a turkey baster and suck the reservoir couple times a year....
    .........so everything stays nice and ruby red......
    .........I dont have a dog........I'm living vicariously thru the truck......
  9. Feb 21, 2023 at 11:56 AM
    Kevins60
    Kevin
    Odessa FL
    Following up. It’s been nearly 2 weeks since the flush and so far no leaks.
    Here’s a cool trick used in order to turn the steering wheel from lock to lock without starting the engine or jacking up the front end. I put folded lawn and leaf bags in front of the front tires and rolled forward until they were centered under the tires. I could spin the steering wheel from lock to lock with one finger.
    Madjik_Man and Kiloyard like this.
  10. Feb 21, 2023 at 6:11 PM
    O'Silver_Taco
    MD
    Thats a great ideal.....
    .....last week we were trying to get a light to stay on a stand.....
    just the weight of the cord pulled the light off....
    it was covered in those contractor bags folded up....
    after about the fifth time ...I said ah @#^ it......
  11. Apr 4, 2023 at 3:10 AM
    Kevins60
    Kevin
    Odessa FL
    Whohoo! No leaks at the two month mark after replacing whatever was in my power steering with Valvoline Max Life ATF. Had the rack boots off the replace the ITRs last week and there are no leaks anywhere.
    Kiloyard, Madjik_Man and Wulf like this.
