What is this loud popping noise when I turn my front wheels out of a parking spot?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fore, Mar 22, 2011.
  1. Mar 23, 2011 at 7:08 PM
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
    Just tint and ppl for now.
    I was getting a similar noise with my Truck. It was the steering stops. They needed some grease. Does this happen when the steering wheel is turned all the way to the left or the right (full lock)? just another suggestion.
    Pap
  2. Mar 23, 2011 at 7:15 PM
    Fore
    Fore [OP] Well-Known Member
    07 PreRunner
    No, just with a slight turn when reversing out of a parking spot, then "METAL POP" then again "METAL POP" back to straight when moving forward to drive away.
  3. Mar 25, 2011 at 8:07 AM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    That's the same noise I get but only reversing to the right. Do you have the stock anti-sway bar? Perhaps removing it may get rid of the noise and further isolate the root cause.
  4. Apr 8, 2011 at 6:51 AM
    robdawg14m
    robdawg14m Rob
    Robert
    Denton, TX
    08 DC 4X4 SR5
    Apline IDA-X100 Head Unit Massive P 950.5 Amplifier 100x4 + 550x1 Diamond Audio 10" D1 Sub Focal K2 Component 165KR Debadged 33x12.5 Toyo MT 18" ATX Artillery Toytec ultimate lift kit LR UCA's Wet Okole seat covers
    I have been having the same noise for about a month now. I have checked everything I possibly can. I am taking the truck to my mechanic next week, so I will update you when they figure it out.
  5. Apr 8, 2011 at 7:35 AM
    bayou_fennec
    bayou_fennec blah blah blah
    Austin
    05' PreRunner
    Kenwood Head Unit, Bed Mat, Weather Tech Floor Mats, Nfab Wheel 2 Wheel Step Bars, LED Bed Lights
    Had the same problem with my 05 double cab 2wd. it was the lower control arm bolt. the lca on the passenger side was not tightened after an alignment was done. no problem since torqueing it to 100 ft-lb
  6. Apr 8, 2011 at 8:22 AM
    reg boulette
    reg boulette Well-Known Member
    Check the slip joints/knuckle joints in your steering column. Sometimes you can 'lube' them quiet with grease if this is the problem.
  7. Apr 8, 2011 at 8:57 AM
    Nick54
    Nick54 Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    Tie Rod Ends?????
  8. Jul 4, 2011 at 3:57 PM
    3ps14
    3ps14 Well-Known Member
    Orange, CA
    05 trd sport dc
    OME 885s, Black FJ Alloys, TSB AAL, BHLM, Satoshi, Hellas, Black Valence, 6k HIDs
    I have the same problem going down driveways in full lock. I hear a loud metal pop/clunk. My truck is lifted 3 inches with bigger tires.
  9. Jul 4, 2011 at 4:06 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    X2 look at your lower control arm and see if there is a shiny spot where the steering stop touches the control arm.
  10. Jul 4, 2011 at 5:31 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    I have also been experiencing a loud "pop" sound from my passenger side. 2WD Base, no lift, 225/75 over 215/75. Sounds kinda bad honestly.
    It seems to mostly happen when backing up and turning the wheel left at or near full lock. It has happened several times, while making right cornerning moves, with foot on the brake. I've also had it happen several times under sudden/hard braking.
    I've checked several things already mentioned, I'll check again with a few more ideas from this thread. I have checked LCA cam bolts, but I'll check them again.
    Noise seems to happen with truck in more stressful spots, I try to take it easy to prevent the noise.
  11. Jul 5, 2011 at 12:24 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Found the issue this afternoon.
    The R-LCA was popping at the caster (rear) eccentic/nut/bushing. On alignment turn-tables you could see the wheel "pop" and a coworker spotted the LCA movement at the rear bushing. LCA nuts are supposed to be torqued to 155 Ft-Lbs.
    I didn't hear anything on the way home, I did take it kinda easy, I did however do a fair amount of turning/backing up/wheel turning, etc when I got in the parking lot at home, no sounds so far.
    I do still have some wheel shimmy at highway speeds, but I does seem improved, still think I've got a tire issue with one of my tires.
    MudFlap likes this.
  12. Jul 5, 2011 at 1:03 PM
    sloppyjoe
    sloppyjoe They are more like guide lines.
    All Over
    Silver and simple
    Non
    Puts me out then. Thanks!
  13. Jul 5, 2011 at 3:00 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    should be 100ft lbs
  14. Jul 5, 2011 at 3:16 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    I checked in AllData, it's 155.
    At 100ft lbs I was still popping.
  15. Jul 5, 2011 at 3:32 PM
    #35
    brutalguyracing
    F.U> GUYZ
    broken mods
    100 ft lbs as per FSM
    if your is 4 x 4
  16. Jul 5, 2011 at 3:33 PM
    #36
    brutalguyracing
    F.U> GUYZ
    broken mods
    unless your a 2wd
    then it 155
  17. Jul 5, 2011 at 4:26 PM
    #37
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    :cool:
  18. Jul 5, 2011 at 4:34 PM
    #38
    brutalguyracing
    F.U> GUYZ
    broken mods
    see you should put that in your aviator thingy and this wouldnt be an issue
  19. Jul 5, 2011 at 4:40 PM
    #39
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Check out the blue lettering off to the left. :D
  20. Feb 3, 2015 at 6:13 AM
    #40
    hg3
    hg3 Well-Known Member
    hg3
    kingsville, texas
    2011 tx pro 4x4
    6 inch bds db lift kit with Fox 2.0 coil overs and Fox 2.0 rear shocks 18x9 xd grenades with 4.52 backspacing and -12 offset 35x12.50 toyo mt's Pioneer 5600 7 inch touchscreen Rockford Fosgate tweets and rear Alpine front 6x9 Rockford p500 for sub Pioneer 4 channel for doors Halo's Westin bull bar custom paint with mounted piaa lights Led interior lights Rugged ridge floor liners Stainless Steel 6 rod holder Overhead DVD player Road armour rear bumper w/ shackles and led lpl Dipped red emblems
    Did u ever get this fixed?? If so, what was it?
