What is this noise coming from the back of the bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by marito909, Dec 16, 2022.
  1. Dec 16, 2022 at 12:45 PM
    marito909
    marito909 [OP] Member
    Mario
    I started hearing this noise a few days ago and I can’t find where it’s coming from! Do you guys have any idea or have had the same issue ? https://youtube.com/shorts/
    I can only hear it when traveling 5-40mph
  2. Dec 16, 2022 at 12:49 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Have you crawled under and given everything thing a look?
    I’d start with the driveshaft and carrier assembly.
  3. Dec 16, 2022 at 12:57 PM
    BigBiscuit
    BigBiscuit Well-Known Member
    Mass.
    2010 TRD Sport DCSB MGM
    Rear driveshaft U-joint would be my guess.
  4. Dec 16, 2022 at 1:12 PM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    06 DCLB TRD Sport
    -Bilstein+OME suspension, ARB bumper w/Smittybuilt XRC winch, Aero exhaust, CMC, oddball size 275/70R17 General Grabber ATXs on 17x8 0 offset Pro Comp wheels, etc.
    Does it get faster or slower with the speed of the engine or tires, or is it when you go over bumps? If it's either of those that could help narrow it down.
    marito909[OP] likes this.
  5. Dec 16, 2022 at 1:17 PM
    Clearwater Bill
    Billy
    Largo Florida
    And including the year and model of truck might help too.
    Sometimes spare tire mounting chains make odd noises. But some models have cables as I understand it.
  6. Dec 16, 2022 at 1:20 PM
    marito909
    Mario
    It goes faster starting at 5mph the faster I accelerate the faster the sound..
  7. Dec 16, 2022 at 1:21 PM
    marito909
    Mario
    I’m getting the spare tire replaced and I currently have the chain half way down.. maybe I should start by putting it up
    It’s a 2011 SR5 V6 manual trans
  8. Dec 27, 2022 at 6:06 PM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    I'd start by putting the chain all the way up, but I doubt it's your spare tire. How about your carrier bearing that goes around your driveshaft? If that's worn out maybe it's making the squeaking/rattling noise.
  9. Dec 27, 2022 at 6:13 PM
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    Not sure if the SR5 has greasable u joints , if they do try greasing them 1 at a time to see if noise stops or changes. That might help to determine if it's a u joint issue. If they are not geasable perhaps u can spray some lube inside by the caps ? Then diagnose from there .
  10. Dec 27, 2022 at 6:45 PM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    SR5 does. and yes, grease the U joints and report back..
    steelcity2 likes this.
