What is this part in the engine bay?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TK7692, Apr 2, 2017.
  1. Jan 16, 2020 at 1:42 PM
    E-Paz 732NJ
    E-Paz 732NJ Well-Known Member
    Eric
    NJ
    2015 Tacoma TRD-OR
    Is this strictly for 2012's??? Just asking because it appears many of you have a 2012. I got a 2015.
  2. Jan 16, 2020 at 1:43 PM
    klavender1
    klavender1 Well-Known Member
    Columbia/Lugoff, South Carolina
    2005 GX 470
    I have one in my 2013 V6.
    MadJacks likes this.
  3. Jan 16, 2020 at 4:14 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    For the V6 engines: 2012 -2015 have the SAI system. There have been reports of failures on all years but mostly with 2012. For 2012 only, there’s the Hewitt bypass system. For all of the above years, HPTuners can disable that system entirely. Of course, this is an emissions system so disabling is for off road use only.
    E-Paz 732NJ likes this.
  4. Jan 17, 2020 at 5:46 AM
    klavender1
    2005 GX 470
    From my understanding, the 2012 didn't have a purge when you turned off the engine. So moisture stayed in the system and messed up the valve that's in it. The 13-15s fixed that with an engine off purge to expel the moisture but it's the little crappy foam filter inside that eventually disintegrates and damages the pump. Hence why you remove it and add that $15 Uni filter.
    We see the same thing at the Lexus dealership I work at. I've seen it happen on quite a few GX models.
  5. Jul 20, 2020 at 10:17 AM
    sithudson
    sithudson New Member
    I have a 2013 4.0 Tacoma with this part. Does anyone else experience a sound from the filter after the vehicle is cut off? Is this normal? Is this the purge mentioned?
  6. Jul 20, 2020 at 11:20 AM
    klavender1
    2005 GX 470
    I'd say it's normal. Mine does the same thing. It seems adding the Uni filter makes it louder and more obvious.
  7. Jul 20, 2020 at 11:26 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Delete that shit. Its like egr on diesels. Useless.
  8. Jul 20, 2020 at 11:29 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    My 2015 makes a sound right at 25 secs. after starting a cold engine. Not really sure how to describe the sound. Likely the system expelling moisture.
  9. Jul 20, 2020 at 12:35 PM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    IIRC, the '12 models will only make that purge during initial start up on a cold engine. This process changed when the '13's thru 15's rolled out to also run the purge again after about 5 to 15 minutes after shutdown. Supposedly this refresh fixed the issues that the '12's were having causing the pump to fail and throw codes. I may have that backwards since I cannot find the source but I do know that there was a change starting with the 13's which fixed the issues the 12's were having. I hope this helps? I would do the delete prior to the pump failing though as in order to do the delete (if you do the computer flash method) the system needs to be working normal and not in limp mode.
    -J
