What is this plug for?
Discussion in '1st Gen. Tacomas (1995-2004)' started by offrdmania, Apr 23, 2015.
  1. Apr 23, 2015 at 6:54 PM
    offrdmania
    offrdmania [OP] Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    96 2.4 auto 2wd, it comes out of the same harness as the plug for the MAF. What is it for? I highlighted it in the picture.
  2. Apr 23, 2015 at 7:00 PM
    BamaToy1997
    Bill
    Navarre, FL
    Terminal test port if memory serves correctly. I may be wrong.
  3. Apr 23, 2015 at 7:44 PM
    phoenix ray
    phoenix ray Well-Known Member
    ray
    Phoenix AZ
    00 PreRunner X-cab TRD
    5100's, AAL, AEM/Spectre true CAI , Magnaflow muffler with mandrel-bent exhaust and header, 4.88's, BFG KO2 12.5 x 33 on 15" AmRacing Outlaw II's, 17" electric cooling fan in factory shroud, frame-mounted remote large-size oil filter, adjustable cam sprocket
    Earlier 1st gens had a separate air intake temp sensor. This may be that unused plug. The new MAF may have a temp sensor built in.
  4. Apr 23, 2015 at 8:15 PM
    offrdmania
    Templeton, Ca
    There is a temp sensor going into the air filter box just ahead of the MAF, is that what you are referring to?
