What is this sound? (video)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HumboldtTaco707, Oct 23, 2012.
  1. Oct 23, 2012 at 5:17 PM
    HumboldtTaco707
    HumboldtTaco707 [OP] Well-Known Member
    Humboldt
    2006 4x4 Blackout
    Dynomax cat-back with super turbo muffler dumped before axle, JBA LT headers, rear fox shocks w/ piggyback, wet okoles, 1 10" square kicker, husky liners, URD short throw, URD maf calibrator
    So this sound started recently and it's getting worse. It starts after my truck warms up for a few minutes, then theres this chirping sound that only goes away when i press my clutch in all the way. I originally thought TOB, but some are saying its something in the transmission since I have to press the clutch all the way in for it to go away. I recorded this video today. The harsh sound right before the chirping goes away is when I push the clutch just enough to feel it (an inch or so), then when I push it in the rest of the way it disappears. So what are your thoughts?
    http://www.youtube.com/watch?v=eYdzT3yhQrc
  2. Oct 23, 2012 at 6:53 PM
    HumboldtTaco707
    Humboldt
    2006 4x4 Blackout
  3. Oct 23, 2012 at 6:58 PM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    Sounds like a spring in the pressure plate rubbing. Clutch in my c230 mb sounded the same way before it exploded....
  4. Oct 23, 2012 at 7:20 PM
    gasgasman
    gasgasman Well-Known Member
    Girard
    Texas
    It's not in the transmission. When you push the clutch in, the transmission is disengaged.
    I agree about the pressure plate springs rubbing.
  5. Oct 23, 2012 at 7:51 PM
    BamaToy1997
    Bill
    Navarre, FL
    My experience with this noise is more like it is a release bearing, or the clutch fork. The clutch for is an easy fix and you can search on this forum to find several fixes. I would look at that first.
  6. Oct 23, 2012 at 8:30 PM
    HumboldtTaco707
    Humboldt
    2006 4x4 Blackout
    Well if its disengaged when I press in the clutch wouldnt that explain why the sounds there until I press the clutch?? That means that sounds only there when my transmission is engaged
  7. Oct 23, 2012 at 8:34 PM
    KodiakToyTRD
    KodiakToyTRD Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    Its the TOB on the pilot shaft. You need the TSK from URD, comes with a stainless steel sleeve and enlarged TOB.
    You will need to drop the trans, put the sleeve on and reinstall the trans. About a days work with the right tools.
  8. Oct 23, 2012 at 8:38 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I am pretty sure from the sound and your description that it's the TOB sliding on the pressure plate spring fingers. It will eventually grind all the way through them. For now, don't rest your foot on the clutch pedal, and push hard and quick to let the bearing do its job and not grind the spring down. You need a new clutch and TOB, and have the flywheel turned if you can.
  9. Oct 23, 2012 at 8:41 PM
    KodiakToyTRD
    CO
    I have a manual, I had noise just like the OP, the pilot shaft in these manual trans trucks is aluminum, and the TOB is steel. With constant use, the TOB scores the pilot shaft and creates that squeak. The reason it quits when you push the clutch all the way in is because that area of the pilot shaft is not scored as the TOB does not hardly ever operate at the end of the pilot shaft.
    I used the TSK sold by URD and this has fixed my problem for over 2 years now.
  10. Oct 23, 2012 at 8:43 PM
    Jayitaliano
    Jayitaliano Member
    Los Angeles
    06 PreRunner 6 Speed
    procomp leveling kit headlamp mod (black housings) FJ Cruiser Anthracite wheels
    I removed my 6 speed due to this noise exactly!!.... i had 85k miles so obviously i replaced the clutch at the same time. anyway it was the release bearing. It was very rough to turn, gritty and noisy compared to the new one. after the new clutch kit noise was gone. good luck.
  11. Oct 23, 2012 at 8:51 PM
    Jayitaliano
    Jayitaliano Member
    Los Angeles
    also.. my noise followed your clutch position description to the T, the only reason i think it goes away when all the way down is the squeek is only audible during light engagement of the bearing but once pressed all the way too much pressure is on the bearing for it to squeal.. i had a stethoscope on the trans while the clutch pedal was fully pressed and the same noise was present just very muffled.
  12. Oct 23, 2012 at 8:53 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    This makes sense, too. But, if you are going to drop the tranny and have over 60K miles, might as well replace the clutch and bearings at the same time just in case. Aisin kit with all the parts you need are $345 at RockAuto.
  13. Oct 23, 2012 at 9:06 PM
    HumboldtTaco707
    Humboldt
    2006 4x4 Blackout
    Hmm so sounds like a TOB after all. Thanks for the help guys. I was planning on upgrading my clutch n flywheel anyways, guess ill just do it sooner and put off getting bumpers for now. So i would need the urd kit, clutch and flywheel, and where should I get the bearings from? Is aftermarket worse than oem?
  14. Oct 23, 2012 at 9:08 PM
    KodiakToyTRD
    CO
    Are you talking about the TOB?
  15. Oct 23, 2012 at 9:14 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Like I said, RockAuto has an Aisin kit that has everything except the flywheel. But if you are doing a flywheel, are you planning on going with a stronger clutch, or ?
    I would do what Kodiak and the other poster said as well.
  16. Oct 23, 2012 at 9:29 PM
    HumboldtTaco707
    Humboldt
    2006 4x4 Blackout
    yes
    so that kit comes with a clutch as well? I would like to get the stage 3 or 3+ clutch/flywheel package from urd.
  17. Oct 23, 2012 at 9:31 PM
    KodiakToyTRD
    CO
    The TOB comes with the Trans Sleeve Kit from URD. Since you're putting a sleeve on there, they will be sending a bigger beefier TOB.
    I think that stage 3 is a bit much for our trucks unless you plan on racing it.
  18. Oct 23, 2012 at 9:45 PM
    HumboldtTaco707
    Humboldt
    2006 4x4 Blackout
    So then all i should get is urd kit and clutch/flywheel? Or am I missing something still? What do you mean by too much? Like stiffer and harder to shift??
  19. Oct 23, 2012 at 9:56 PM
    KodiakToyTRD
    CO
    This is the TSK kit, it comes with everything: The TOB, the Sleeve, an Allen wrench, lube and instructions.
    http://urdusa.com/p1260519023/Throw...IT,-2005+-Tacoma-V6-6-Speed/product_info.html
    The stage 3 kit is a competition race clutch, extremely stiff, not something you'd want for everyday driving.
  20. Oct 24, 2012 at 4:20 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    With that URD kit, you would still need the clutch disk and pressure plate. Most will come as a kit, so you'd have an extra TOB. If you really want to do the flywheel and upgraded clutch, URD sells a combo. I would stick to Stage II.
