What is this sound? (video)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HumboldtTaco707, Oct 23, 2012.
  1. Oct 24, 2012 at 6:42 AM
    BamaToy1997
    Bill
    Navarre, FL
    When I replaced my clutch during the engine replacement, I went with a Banhauf Stage 3 clutch. I'll never go back to a standard clutch again after driving with this clutch!
  2. Oct 24, 2012 at 10:43 AM
    HumboldtTaco707
    HumboldtTaco707 [OP] Well-Known Member
    Humboldt
    2006 4x4 Blackout
    Dynomax cat-back with super turbo muffler dumped before axle, JBA LT headers, rear fox shocks w/ piggyback, wet okoles, 1 10" square kicker, husky liners, URD short throw, URD maf calibrator
    K well now im a little confused. So If I get the TSK kit and the flywheel/clutch combo from URD I would also need a clutch disk and pressure plate? Or are those just other names for clutch n flywheel? And I dont think Id mind a stage three, i've heard good things about them and I dont think Id mind the extra stiffness. But I will def look into it more and consider a stage II. Thanks for all the help guys, btw. I know I can ask a lot of questions haha sorry :rolleyes:
  3. Oct 24, 2012 at 11:37 AM
    BamaToy1997
    Bill
    Navarre, FL
    Depending on the kit, some clutch/flywheel kits come as an entire kit, which includes a new flywheel, new clutch disk, new pressure plate, pilot bearing, and release bearing. Looking at the kit on the URD site, it shows in the picture a new flywheel, clutch, and pressure plate, but not the pilot or release bearing. You would have to contact them directly on your application.
  4. Oct 24, 2012 at 11:44 AM
    HumboldtTaco707
    Humboldt
    2006 4x4 Blackout
    Yeah I should probably just call URD. I wanna make sure I get everything I need if im gonna pay to have my tranny dropped. I wish I had time to do it myself:(
  5. Oct 24, 2012 at 11:49 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    The TSK kit + the URD clutch and flywheel kit should be all you need. There may also be a pilot bearing, but I am not sure on this vehicle. URD should know. You might want to call them to make sure you get everything you need.
    This operation is not for the faint of heart. I am not sure if you are planning on doing it yourself. If so, it will be a learning experience. Be patient, follow any instructions, set aside some extra budget for tools, and give yourself enough time.
    Edit: Dang, I am slow. Bill is a tech, so he knows better than me anyway.
  6. Oct 24, 2012 at 11:53 AM
    HumboldtTaco707
    Humboldt
    2006 4x4 Blackout
    Im swamped with work or else I would give it a go. Im just gonna take it to this guy in town who works on toyotas a lot. But yes ill give em a call to make sure.
  7. Oct 24, 2012 at 11:53 AM
    KodiakToyTRD
    KodiakToyTRD Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    Lol not for the faint of heart is correct. I did it myself, I was pressed for time also. 7 hours R and R. FUCKING SUCKED.
  8. Oct 24, 2012 at 11:56 AM
    HumboldtTaco707
    Humboldt
    2006 4x4 Blackout
    + rep for all you guys :D thanks for the help
  9. Oct 24, 2012 at 3:28 PM
    HumboldtTaco707
    Humboldt
    2006 4x4 Blackout
  10. Oct 24, 2012 at 3:29 PM
    KodiakToyTRD
    CO
    If you're not replacing the clutch and flywheel, the TSK is all you need.
  11. Oct 24, 2012 at 3:32 PM
    HumboldtTaco707
    Humboldt
    2006 4x4 Blackout
    Oh I thought it was just recommended to replace the clutch if you replace the TOB. Im pretty sure im on my stock clutch with 130k isnt that quite a bit for a clutch?
  12. Oct 24, 2012 at 3:35 PM
    KodiakToyTRD
    CO
    Uh, I replaced on the TOB when I did at 60k. I haven't had any issues. No need to replace flywheel though, just clutch and pressure plate.
  13. Oct 24, 2012 at 4:20 PM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    It can also be the input shaft bearing.
  14. Oct 24, 2012 at 4:23 PM
    HumboldtTaco707
    Humboldt
    2006 4x4 Blackout
    See this is what ive also heard but idk how to distinguish the two
  15. Oct 24, 2012 at 5:06 PM
    #35
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Does the sound lessens as you go up tru the gears? And/or did it actually start as a rattle before it bacame a squeak? If so, i would say its the imput shaft bearing.....
    Good luck with it
  16. Oct 24, 2012 at 5:50 PM
    #36
    KodiakToyTRD
    CO
    I can almost guarantee you that if you put that sleeve on, your noise will go away. Almost every manual Taco in the 05+ range with the aluminum pilot shaft has a TOB squeak. Threads on this site about it are rampant. That was the reason I joined this site.
  17. Oct 24, 2012 at 7:00 PM
    #37
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Clutch wear really depends on the driver, but 130K is a decent amount of time on the original clutch. I'd say it is due. I am pretty light on clutches and normally replace at 120K before they get completely worn out.
    Here's the deal. There is no way to tell if the noise is caused by the issue that Kodiak and others have had or if it is the TOB/release bearing until you get it taken apart. You can buy parts for one or the other, but you have a 50/50 chance of getting the right parts to fix the noise. But you'll need a new clutch soon anyway, and the noise and mileage, to me, indicate a worn TOB.
    You don't need a flywheel. Getting it turned (like a brake rotor) is recommended but not required.
    Not to discount what Kodiak and others have said, but if it was me I would start with the Aisin clutch kit since it would be needed anyway. Once it is apart, you can decide whether the URD kit is needed or not -- it is expensive for what it is. To me, the sound indicated a worn TOB.
    That Aisin kit at RockAuto is a good kit, don't forget the discount code.
    Anyway, that is what I would do.
  18. Oct 24, 2012 at 8:35 PM
    #38
    HumboldtTaco707
    Humboldt
    2006 4x4 Blackout
    Well the thing is my tires are pretty loud at highway speeds and my exhaust is pretty loud as well so its hard to tell if it lessens but I can still hear it. Plus, up until very recently i've had some front end problems with plenty of sounds and vibes (still have vibes) so I have no idea if it started as a rattle.
  19. Oct 25, 2012 at 6:22 AM
    #39
    BamaToy1997
    Bill
    Navarre, FL
    In my professional opinion, since your transmission will already be out, the best course of action is to fix it right. Even if your sleeve is not worn out, if it is the older style and has not been fixed, do it now, so you won't have to do it later. In my career I have only replaced ONE flywheel on a manual transmission due to clutch problems, and that is because the clutch disc wore out so much that the rivets scored the flywheel.
    I would recommend: Clutch, pressure plate, TOB, pilot bearing, and the updated sleeve kit.
    A decent tech can complete that job in about 3-4 hours if he has a lift and the proper tools.
  20. Oct 25, 2012 at 9:17 AM
    #40
    HumboldtTaco707
    Humboldt
    2006 4x4 Blackout
    Yeah I decided thats what ill do. Ill just call urd and order everything once i get paid here
