What is this wire / connector for?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wolftree, Oct 16, 2011.
  1. Oct 16, 2011 at 7:23 AM
    wolftree
    wolftree [OP] Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    I have a base model, standard cab 2011 Tacoma, 4 cylinder, 4x4, 4 speed automatic transmission. The cheapest 4x4 I could get. The only other option is daytime running lights. While looking under the hood, I discovered an unused wiring connector with a red wire and a white wire feeding into it. This is tied off just behind the drivers side headlight and and in front of the battery.
    Does anyone know what this connector goes to? I am assuming it would go to an option or package that is not on my truck, But what? The wires are too small to feed fog lights, but they could feed a relay to fog lights. Any other ideas?
  2. Oct 16, 2011 at 9:07 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
  3. Oct 17, 2011 at 6:19 AM
    wolftree
    Rick
    Ohio
    Gelo, I agree about the manual transmission being cheaper and overal a better choice with the 4 cylinder engine. But, I am a right leg amputee and use a "Left Foot" accelerator pedal that I bolt to the floor with a custom machined 2"x10"x1/2 steel plate. So I need to have an automatic transmission. This is also why I chose a Toyota Tacoma 4x4, to get me through Ohio snow on the backroad I live on.
    I do not have a digital camera, so I cannot post a photo.
    I was looking at these wires to hookup future fog lights upgrade. But, I think I will use a different approach, rather than these wires. I am considering using a "Accessafuse" as a power source and coming off the unused power window fuse location at the in-cab fuse block to feed the dash switch, This would then feed the foglight relay. This would give me a "switched off" circuit as well.
    Rick
