what is this?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DBTaco, Dec 13, 2012.
  1. Dec 13, 2012 at 6:21 PM
    DBTaco
    DBTaco [OP] Well-Known Member
    NC
    '08 4x4 TRD off road
    I had my windshield replaced today which was in the agreement when I bought the truck. There is this little black box looking thing on the drivers side at the upper corner. Kinda shaped like a oblong triangle. Its held by two sided tape looks like. Its having a hard time sticking back to the windshield. I'm hoping someone knows what it is since I don't have a picture of it. Can someone help
  2. Dec 13, 2012 at 6:30 PM
    Pannell_Trd
    Pannell_Trd Well-Known Member
    Tyler
    Georgia
    2009 Prerunner Double Cab Trd Sport
    Yellow foglights 20% tint
    i have no idea ?
  3. Dec 13, 2012 at 6:31 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Do you have an aftermarket alarm? Could be a shock sensor for an alarm.
  4. Dec 13, 2012 at 6:38 PM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    COuld be an aftermakret alarm. Could you post a picture of it?
  5. Dec 13, 2012 at 6:41 PM
    DBTaco
    NC
    I will try to post a picture tomorrow. I only got one key, no keyless entry but I'm going to check with a Toyota dealership to see how much one is. So I don't know if it has an alarm. The wires go down the pillar part between drivers door and windshield. I didn't know if it was something on every tacoma
  6. Dec 13, 2012 at 6:47 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater,FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x9 Fuel Krank wheels, 35x12.50 Cooper Discoverer STT, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Maybe an aftermarket Bluetooth mic ?
  7. Dec 13, 2012 at 11:18 PM
    myth01
    myth01 Well-Known Member
    south sf, ca.
    08 taco Trd sport
    eclipse nav.-w/ Bluetooth & iPod 3'' revtech add a leaf lift kit snug top ss truck cap dive tank racks in back Aux fuse box Aux back up lights, w/ interior fj cruiser stock switch Back up cam Turn signal cams Interior inverter -switched Aux audio/video inputs -RCA (including iPhone cable)w/ 4 input switch Mag light mount Tyredog stand alone tpms Spare tire extension hose Avid off road light bar(powder coated)
    If you have an aftermarket nav. It may be the GPS antenna
  8. Dec 14, 2012 at 4:05 AM
    tacomaconvert
    tacomaconvert Well-Known Member
    NY
    '12 White SR5 DC 4X4
    Factory roof rack, bed extender Extang Full Tilt Tonneau
    Is it the interior side of some sort of glass mounted antenna, like the older cell phone or radio (CB, ham radio?) antennas?
  9. Dec 14, 2012 at 4:15 AM
    Namyo
    Namyo -
    I has one, it's for my two way alarm. Check with an audio shop for a remote.
  10. Dec 14, 2012 at 4:15 AM
    Mpgillespie
    Mpgillespie Well-Known Member
    Moore, OK
    13 PreDCSB Stormtroopen Taco
    Maybe one of those pay,ent devices, if you don't pay your car payment they shut your car off?
  11. Dec 14, 2012 at 4:23 AM
    DBTaco
    NC
    Lets hope not. LOL. I looked at it this morning and it has a part number on it so I'm going to Google it online after I get off work to see if it comes up.
  12. Dec 14, 2012 at 4:52 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Its not a factory option for sure
  13. Jan 3, 2013 at 4:53 AM
    DBTaco
    NC
    I googled the part number 118B1128 which is the thing two sided taped to the inside of my windshield. From what I can tell its a remote start antenna. I'm not sure if its an audiovox or a code alarm brand since both use same part number. Also I don't know if its just remote start or remote start and keyless entry.
  14. Jan 3, 2013 at 5:05 AM
    Burns
    Burns Well-Known Member
    Truck shopping again!
    Sounds like it is some kind of aftermarket remote start, it is definitely not for the key-less entry.
