What is this?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Albinator, Feb 15, 2016.
  1. Feb 16, 2016 at 12:22 PM
    mohavestubbs
    mohavestubbs Why not DIY?
    Denver
    97 2.4L
    Odd.. My 2.4 has a different vapor canister (more cylinder shaped) and where that line is coming from on the intake is simply capped off.
  2. Feb 16, 2016 at 12:30 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    EVAP canister. I ran my 98 with the 3.4 without it hooked up for a long time. Didn't throw any codes. It's not a big deal. Just hooked up to the side of my airbox.
  3. Feb 16, 2016 at 12:33 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Usually emissions related things are nonsense anyway :p
    Need not to worry
    Tractorman likes this.
  4. Feb 16, 2016 at 12:43 PM
    Albinator
    Albinator [OP] Well-Known Member
    Utah
    2000 Tacoma 2.7 Manual SR5 4x4; Manual Hub
    Thanks for all the replies. I'll just keep it hooked up for peace of mind since that's where it belongs in the first place.
  5. Feb 16, 2016 at 6:54 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    just google "tiny air filter". better off googling "small air filter" though.
  6. Feb 16, 2016 at 6:54 PM
    CodeSeven
    Serge.
    Coachella Valley
    very true.
  7. Apr 5, 2016 at 5:17 PM
    sdavidson94
    sdavidson94 Active Member
    Samuel
    Bonney Lake
    96 Tacoma 4x4
    -Bilstein 5100s w/ AAL in rear -15x8 Pro Comp 7069 wheels -JVC Head Unit -Linex Bed Liner -UWS toolbox
    Hey, I know this thread has been dead for a few months but I didn't want to start another thread about this part. I've noticed my EVAP canister buzzes intermittently after I turn the engine off. Has anyone else ever had this problem? There aren't any codes on. Does this part need to be changed?
  8. Apr 5, 2016 at 8:53 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Just don't live in places with silly rules.
  9. Apr 5, 2016 at 9:13 PM
    CodeSeven
    Serge.
    Coachella Valley
    check the purge valves first. they may be slightly stuck open and sort of "whistling" as the air dies out from being on. if you know its not the purge valves and is coming from inside the canister, you should probably change it.
  10. Apr 6, 2016 at 2:56 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Yeah its a common thing on the earlier tacos like yours. The newer ones have a slightly different lil doodad on the canister to help remidie the noise. It should be pretty easy to find a couple threads on the subject that even have pics of the slight change of the canister. I know they're on here.
    No worries though, it's harmless...
  11. Apr 6, 2016 at 5:10 PM
    sdavidson94
    Samuel
    Bonney Lake
    96 Tacoma 4x4
    ok, I'll do a little more searching around to see if I can find some more info/pictures of it. Can you just replace it with one of the newer ones with no problems? Thanks for the quick replies!
  12. Apr 6, 2016 at 8:44 PM
    bry838
    oregon
    I think so, i believe its the exact same thing just with that updated piece. They are very expensive to get new at the dealer. Youll have to get lucky at a junk yard or live with yhe noise.
