what is WRONG with my system?
Discussion in 'Audio & Video' started by adaptedtheory, Jan 6, 2013.
  1. Jan 6, 2013 at 6:02 PM
    adaptedtheory
    adaptedtheory [OP] Well-Known Member
    04 Tacoma S-Runner
    Window Tint, 8" Sundown SA-8, Kicker ZX500.1
    So.. I have a Sundown SA-8 with 400 RMS.. a kicker amp w 400 watts.. one day my sub just stopped working, cut out. It would occasionally cut out on certain frequencies it seemed like in certain songs, like it would shut down for a few seconds and come back on. But not often. Anyways, the sub appears to be in no way blown, the amp is providing power. Replaced the RCA's. No fuse's appear to be blown. I'm a real rookie when it comes to car audio, but what could be the problem here??? Also, we took the sub and attached it to a home theater, and it works fine. So the sub definitely isn't blown.
    Thanks..
    ANOTHER NOTE: The "protection" light on the amp is completely dim.
  2. Jan 6, 2013 at 6:06 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I figure it as one of a few things:
    Remote wire..make sure it's tight and not busted.
    Power/ground..check them too.
    Is there any kind of pattern to when it cuts out? If so maybe you should watch the amp if it shuts off or goes into protect mode.
    Pull the sub out and check the enclosure wiring. That fixed it for a buddy of mine before, he had no idea what to do and I pulled the speaker out..problem found and solved.
  3. Jan 6, 2013 at 6:07 PM
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    It's almost always a loose conection or bad ground. Make sure you've got good bare metal.
  4. Jan 6, 2013 at 6:16 PM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    Bad ground
  5. Jan 6, 2013 at 9:00 PM
    adaptedtheory
    04 Tacoma S-Runner
    really bad ground can cause this??? My ground probably could have been better... seems like under the cab seat there's NOTHING to ground to. I'll try a different spot tomorrow
  6. Jan 6, 2013 at 9:01 PM
    pinktaco808
    pinktaco808 Hot Steppa
    gain set to high?
  7. Jan 6, 2013 at 9:23 PM
    RedTacomaTy
    RedTacomaTy Well-Known Member
    Complete: -2 10" Kicker CVR Subs -Hifonix Brutus BRZ1200.1D Amp -17x8 Tuff A/T T01 Wheels -265/65/17 Michelin LTX M/S2 Tires To-Do: #1 Satoshi Grill #2 Relocate the Horns #3 Hella 700FF behind the Grill #4 Shorten Mud Flaps #5 Avid Light Bar (w/ 2 Fog Lights OR 2 Driving Lights) #6 Weather Tech Floor Mats #7 Upgrade Door Woofers #8 Scooped Hood
    I agree with Ryan. If they just cut out then come back on it probably means the amp is overheating. There is one song I have on my iPhone where no matter how much power I have going to the subs the amp will ALWAYS overheat. If you have a light on your bass knob that is green but then turns red that means your amp is overheated.
  8. Jan 6, 2013 at 9:33 PM
    ABA180
    East Bridgewater MA
    It could yes..first check your amp. I had one that was bugging me some years ago. The wire had come loose in the spade connector so it appeared to be tight till I dug deeper.
    I'd take some sandpaper to your ground spot and make it all nice and shiny, then try it again and see if that helps.
    How long does it take after you start using the stereo to see this? Wondering if I can spot a pattern
  9. Jan 6, 2013 at 10:01 PM
    adaptedtheory
    04 Tacoma S-Runner
    Ok, it cutting out ORIGINALLY, would happen on a particular song. Then I started noticing it on other particular songs, just one or two. But at no particular time or point in the song, sometimes it would happen sometimes it wouldn't.
    Now, the sub isn't working at all, so there is no pattern, it's just.. not working whatsoever. I'll try cleaning up the ground tomorrow after I get off work.. thanks for the replies and advice
    as far as overheating and the amp.. the amp light is red, but I'm almost certain it's always been red. (oddly enough..)
    Also, note that we plugged in another amp (we knew was in working condition) and had the same results, 0 sub response at all
  10. Jan 6, 2013 at 10:19 PM
    ABA180
    East Bridgewater MA
    Some amps have a separate protect light..and yes some always have a red light to indicate power, I believe my MTX amp does.
    When you say you plugged in another amp, I assume you installed it into your truck..please advise. If so, take your amp and toss it in the other vehicle.
    I'm believing you can isolate this to either your amp wiring or the amp, since you tested the sub out. You didn't mention but if you haven't, test the sub again on a song you know it was originally screwing up on.
    I'd try in this order:
    Put your amp in the other vehicle first. That is the more likely of the 2 causes if I had to offer my gut feeling. I say that because while wiring can make it cut in and out, most times I see that it's the amp before the wiring.
    If your amp works on that test, remove the amp from the other vehicle and try it in yours.
    If both pass, take the sub and put it on the other amp in the other vehicle..jam the hell out of the sub and see if you can cause it then. That's my last idea being that you tried the sub on a home system, but it's possible you didn't power it high enough inside.
  11. Jan 7, 2013 at 8:44 AM
    RedTacomaTy
    Well if it was happening only on certain songs it sounds like it was overheating. It could have happened enough to where it damaged the amp leading it to overheat more easily. Which would cause it to cut out more often on different songs. Then if you let this go on for too long it may have lead to you damaging your subs with them going on and off suddenly and frequently.
    But that's all hypohetical. Check your ground, cable connections, and everything thing else.
  12. Jan 7, 2013 at 8:47 AM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    Sounds like a possible poor ground. I can tell you one thing though. I guarantee your amp is adjusted improperly
  13. Jan 7, 2013 at 8:48 AM
    monsterkx2fiddy
    Reason I say this is due to you saying, "on certain frequencies"..
  14. Jan 7, 2013 at 1:17 PM
    adaptedtheory
    04 Tacoma S-Runner
    Honestly, right now i don't HAVE another vehicle, I don't know a lot of people with systems so I'll have to ask around to get some different help. Friend of mine had an extra amp, we installed it, with the same results.
    Checked today and it's NOT the ground, the amp is getting and sending power... I'll try the amp on a different system when I can but I think it's the wiring or something in my setup. Urgh
  15. Jan 7, 2013 at 2:34 PM
    adaptedtheory
    04 Tacoma S-Runner
    Included an important note in the OP I completely did not notice, the "protection" light on the amp is completely dim.
    Is the amp overheated completely to the point where it isn't functioning? <- my first question. But if so, then why wouldn't our WORKING amp... work?! I'm clueless, but I think it's speaker wire or adjustments on the amp or something
  16. Jan 7, 2013 at 3:07 PM
    ABA180
    East Bridgewater MA
    Could be, but then that doesn't explain the 2nd one. I'm guessing you removed the 2nd amp from something else recently.
    The other thing I'm gonna throw at you is try using the RCA's differently. If you have more than one preamp out on your head unit try using in a different one. Longshot where you said you replaced them, but in theory it could happen. I had the right side of a radio cut out before.
  17. Jan 7, 2013 at 3:16 PM
    adaptedtheory
    04 Tacoma S-Runner
    Don't think theres more than one pre-amp on my headunit.
    @ryan, I'm near certain the sub is properly wired, and definitely no sign of loose connections. The wiring I am not certain on however. I have positive connecting to the opposite negative on the sub, and each remaining positive and negative linking to the amp, just as it seems it would be i thought
  18. Jan 7, 2013 at 6:44 PM
    ABA180
    East Bridgewater MA
    Should be good, he mentioned earlier trying it on a home system and it worked..
  19. Jan 7, 2013 at 6:49 PM
    ABA180
    East Bridgewater MA
    Google your HU, if it's recently made I bet it's got more than one. But honestly I would do the jury rig method of wiring your amp right to battery outside of the truck and see if you can get it to play.
  20. Jan 7, 2013 at 7:48 PM
    adaptedtheory
    04 Tacoma S-Runner
    Yup, same speaker wire that went from the sub to the amp is the one that went from the sub to the home system we tested, which worked
