What is your experience with Hill Start Assist?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wtf, Nov 8, 2016.
  1. Automatic Transmission: Vehicle is held firmly in place for 2 seconds after releasing brake pedal
    36 vote(s)
    17.6%
  2. Automatic Transmission: Vehicle rolls back and make noises after releasing the brake pedal
    103 vote(s)
    50.5%
  3. Manual Transmission: Vehicle is held firmly in place for 2 seconds after releasing brake pedal
    53 vote(s)
    26.0%
  4. Manual Transmission: Vehicle rolls back after releasing the brake pedal
    12 vote(s)
    5.9%
  1. Apr 4, 2018 at 9:44 AM
    #101
    duckytw
    duckytw Well-Known Member
    Brake on, clutch in, 4lo, and let it roll a little to click into place. 4lo + 1st is the MT hill start assist :D
    tonered likes this.
  2. Apr 4, 2018 at 9:47 AM
    #102
    MaynardVanZant
    MaynardVanZant No.
    Alaska
    2017 DCSB TRD OR MT
    MBRP Catback 2” Bilstein 5100 lift
    I have clutch start cancel, way more useful to me than hill hill start nanny.
    doublethebass likes this.
  3. May 1, 2019 at 9:13 AM
    #103
    silverflash
    silverflash Well-Known Member
    Bill
    Harnett county NC
    2019 TRD 4x4 OFFROAD DCSB Auto Quicksand
    tyger armor side bars tyger tri-fold tonneau cover avs bug deflector II scangauge II
    https://www.toyota.com/tacoma/ebrochure/
    it states standard across all automatic transmissioned tacos. so manuals do not have them.
    i just picked up a new 2019 TRD OFFROAD 4x4 automatic transmissioned and tested in my drive last night which is quite steep. I let the foot off the brake and she immediately rolled back a few feet and made lots of racket. didn't expect that. I did read the other thread - i think it was another thread- that basically said toyota isn't fully disclosing and the OR models crawl control interferes with the hill start assist.
    it would be nice to have as i frequently go up a steep mountain gravel road in 4x4 hi and having it roll back if i have to stop to pick up branches in the way, is unsettling. I suppose i can use the hand brake BUT if everything says it has it why isn't it working as such? I did see a video online where for some toyota vehicles you have to sometimes push the pedal further than normal to engage it.
    here is that link: 1:07 is where they talk about "has to be initiated by the driver"
    https://www.youtube.com/watch?v=oWVN3O5r9o0
    i have seen others take it into toyota but they say working normally? any ideas?
  4. May 1, 2019 at 9:16 AM
    #104
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    I love it in my manual tacoma. Saves on clutch wear & just makes things slightly easier when stopped on a big incline.
    NickleCityTaco likes this.
  5. May 1, 2019 at 9:44 AM
    #105
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The only new MT that has it is the Sport, the discontinued SR MT had it also. The Off Road and Pro MT do not come with it.
  6. May 1, 2019 at 10:25 AM
    #106
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    I've got the off-road, and I really have to question why they wouldn't give that feature to the manual transmission - especially since off-road, you may have to do very steep hill starts.
    Makes me glad for the handbrake
  7. May 1, 2019 at 10:47 AM
    #107
    silverflash
    Bill
    Harnett county NC
    from what i have gleaned from the few posts on here, perhaps the whole crawl control interferes with hill start assist.
    in order to use either multi-terrain or crawl control you must be in 4lo per the manual. thing is, the only time i ever you 4lo is descending a steep mountain gravel road in my xterra because otherwise the abs kicks in and i still skid a little. the same hill in my 4x4 patriot and my gf's awd crv goes down with zero skids. and they both only have 4hi at best- no 4lo. I am guessing becasue the xterra is so much heavier and the abs system must not be that good, that's why the skids unless in 4lo.
    with the taco, i don't know what to expect. i will probably try 4hi and see and if same as xterra, use 4lo. going up the same hill i always go in 4hi and some speed.
  8. May 1, 2019 at 10:52 AM
    #108
    AKGSD
    Joe
    Alaska
    They have a different brake booster from what I've heard, perhaps that has something to do with it
    shakerhood likes this.
  9. May 1, 2019 at 10:53 AM
    #109
    MidCitiesMildMan
    MidCitiesMildMan Well-Known Member
    2017 Toyota Tacoma Limited
    Stock and staying that way
    Same. I have tested it on the steepest hills I can find. It holds the truck firmly in place.
  10. May 1, 2019 at 11:06 AM
    #110
    silverflash
    Bill
    Harnett county NC
    do you have to push the brake pedal in further once stopped like the video shows? I haven't had the chance to try since yesterday.
  11. May 1, 2019 at 1:53 PM
    #111
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    on super steeps
    my 2nd gen holds, slips a foot or two, holds, slips..repeat.... with a lot of barking noises from the brake controller.
    a true assist, not a 'hill hold' for what that is worth
  12. May 1, 2019 at 2:07 PM
    #112
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    Probably restating what many others have stated elsewhere, but if you have an AT TRD Off Road and are stationary on a steep incline and in 2WD or 4HI, it is normal for the ABS brake booster to fire as the vehicle rolls back at a "controlled" rate. While the noise and the backward movement can be alarming to the uninitiated (it was for me until I read up on the hill start assist system for AT TRD OR models), it will slow the backward roll enough to allow you to move your foot over to the gas pedal and give it gas. Once there is enough torque applied to the transfer case, the brake booster will stop firing and you are on your way.
    In 4LO, usually there is enough torque to not require the hill start assist to kick in.
    My guess on why things are different for the TRD OR models to that of other models, would be that they have brake boosters and the other models don't (this is also why the OR models make a whoosh noise sometimes when you push the brakes). It would appear that the brake booster is designed to only pulse the brakes, and cannot hold them statically for any length of time, so it just fires the brakes rapidly to slow the backward movement of the vehicle.
    While its a long running joke, it is actually the case that many of quirks with these trucks are actually "normal". Over the last year of owning my vehicle, I like many on this website, have thought my vehicle was broken in some way, only to find out later through research that it's normal and functioning this way for a reason. It doesn't help that many dealerships are just as clueless as anyone else on the design philosophy that went into the truck, and as such, can't give a reasoned explanation for why things are the way they are.
    It would be helpful if Toyota Corp had a FAQ or AMA type of website where the design engineers could interact directly with consumers and tell them why things are working the way they are.
    shakerhood, Pro-Taco and AKGSD like this.
  13. May 1, 2019 at 3:06 PM
    #113
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    I am glad I found this thread, otherwise I was going to schedule an appointment to have it looked at. I have other vehicle all with hill assist and some with brake hold, and none of them act like my OR does.
  14. May 1, 2019 at 6:02 PM
    #114
    maileboy
    maileboy Well-Known Member
    David
    Mt. View (Big Island) but from Maili
    2017 TRD OFF-ROAD 4dr 3.5-auto, Magnetic Grey
    17’ TRDORDC AT 3.5, doesn’t work.... happened when I got it new, rolled back almost hit car behind, lights on dash, buzzing noise, light stayed on. Next day lights off took to dealer, tech said normal......I don’t depend on it at all, use hand brake if have to. Too much crap on this truck, but I love the truck anyway......
  15. May 1, 2019 at 10:32 PM
    #115
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    Mine works perfect. TRD Sport AC with 6 speed MT.
  16. May 2, 2019 at 6:59 AM
    #116
    silverflash
    Bill
    Harnett county NC
    so obviously toyota's literature is wrong. won't be the first time for a manufacturer misrepresenting something. my 2017 patriot 4x4 states on the sticker it has hill start assist standard. it does not because the standard features also include the 5spd manual and i have the 6spd auto. I don't have hill start assist. Took me a while to dig into that one but my auto package does away with the hill start assist. perhaps our crawl stuff negates the hill start assist for us?
  17. May 2, 2019 at 7:42 AM
    #117
    NickleCityTaco
    NickleCityTaco Well-Known Member
    Western New York
    16 Acess SP 6MT
    stuff and things
    I have a 16 MT sport. Usually when I notice it kick in I'm in first with the break on. I push the break pedal all the way to the floor and then let go of the clutch, thing stays in place enough time for me to notice and then put my foot on the gas. Nice little feature imo. It's kind of fun on a trail hill. If you time it right it can help you get over those small steep technical muddy places.
  18. May 2, 2019 at 8:51 AM
    #118
    silverflash
    Bill
    Harnett county NC
    i wish our OR 4x4 AT's came with it actually working. it seems on my/that model (trd offroad 4x4 automatic trans) it doesn't work as advertised for some reason.
  19. Jun 9, 2019 at 12:06 PM
    #119
    silverflash
    Bill
    Harnett county NC
    So an update. I tested my hill start on my driveway today. In drive and on the hill I release brake. She made some grinding and beeping noises and rolled back about 1 foot then she held it for 2 seconds. I reproduced this a few times. So it does work, just delayed. Definitely usuable for me.
  20. Jun 9, 2019 at 12:51 PM
    #120
    Aldo98229
    Aldo98229 Well-Known Member
    Aldo
    Bellingham, Washington
    2019 Tacoma TRD Off-Road
    Useable...as a wake up alarm...?
