What is your favorite mod or upgrade you have done?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LCBogey, Sep 1, 2014.
  1. Sep 12, 2014 at 8:50 AM
    #61
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Do we know if they work with 2013's? If they do, I'm getting one today.
  2. Sep 12, 2014 at 9:28 AM
    #62
    adrenalnjunky
    adrenalnjunky Well-Known Member
    West Monroe, Louisiana
    07 PreRunner SR5 DCSB
    billie 5100's front @ .85"
    KB - I just forwarded you the PM info he sent me. He says it works 05-14.
  3. Sep 12, 2014 at 9:45 AM
    #63
    pruchai
    pruchai KAMA3
    San Diego, CA
    ‘07 Saab 9-7x 4.2i (it identifies as a Tacoma)
    Not enough...
    1. Katzkin
    2. Leer 100XQ
    3. Custom dog bed
  4. Sep 12, 2014 at 9:47 AM
    #64
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I have one in mine. See my build for pics.
  5. Sep 12, 2014 at 9:53 AM
    #65
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Ordered!!!
  6. Sep 12, 2014 at 8:02 PM
    #66
    TheGrayRider
    TheGrayRider MARANATHA !!!
    NW Florida
    2017 BBP DC 4X4 OR
  7. Sep 14, 2014 at 6:53 AM
    #67
    BeaverYota
    BeaverYota Oregon State Edition
    Josh
    Lake St. Louis, MO
    Sold...
    Its so hard to choose because the modding never stops... So each one becomes a favorite. I've loved learning to wire things. But my lift is probably my favorite for now. And these awesome bedside decals a member made me. 7f16db9cfcc4d9d0ef2be4d251aea372_23a935c81ece91b32e07bad602814369ae67f54f.jpg
  8. Sep 14, 2014 at 6:54 AM
    #68
    adamh1977
    adamh1977 Well-Known Member
    arkansas
    trd sport 4x4
    any time fog,tinted windows to 5% ,plasti dipped gun metal gray,toytec 5100's eibach coils ,led map and dome lights
    My Toytec lift
  9. Sep 14, 2014 at 7:42 AM
    #69
    ThomasMore66
    Dallas/Fort Worth & Durango
    I think the wheels were the most visually transforming change, but I still look at my icons every time I get in the truck. The most unique mod in this area of the country is my Model T. 50b5825cb821af590c8600fb29e0177e_867eb6ee1c46df0b733266bc0196a509a1be8158.jpg9eb41c1a7774075b96f7ddf7a85ef4d2_19382eeff49358fbe1d9d4de6634fb2124b44a50.jpg9fe355b2ff2852b1f3d840e7b66fe1e8_2ddec998ae4130b02eb81f0f98d9e8c312e37ce7.jpg
  10. Sep 14, 2014 at 9:03 AM
    #70
    TaylorU
    TaylorU KC HiLiTES Vendor
    Taylor
    Flagstaff, Arizona
    2010 4x4 TRD Off-Road
    ADS 2.5" coilovers, Light Racing UCAs, 2.125" rear ADS shocks, Raptor-Style Grille using Homertaco mesh and BAMF letters, MB 352 wheels, 285/75r16 Cooper ATPs, Mini D2S 3.0 HID Projectors retrofitted, KC Flex 20", KC Pro6 light bar, KC G4 LED fog lights, Pelfreybilt front bumper
    Damn, such a clean and sweet truck!! Love it.
  11. Sep 14, 2014 at 9:09 AM
    #71
    ThomasMore66
    Thanks. My slow build. I REALLY want the supercharger next.
  12. Sep 14, 2014 at 10:01 AM
    #72
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Best Mod...probably Icons on all 4 corners or when I installed the Truetrac Diff.
    The diff is awesome, but the suspension upgrade is more noticed when driving, unless you need grip off-road.
    PK
  13. Sep 14, 2014 at 10:08 AM
    #73
    BeaverYota
    Josh
    Lake St. Louis, MO
    Sold...
    You and me both brother
