what is your GO-TO camo pattern?
Discussion in 'Guns & Hunting' started by aficianado, Jan 26, 2010.
  1. Jan 26, 2010 at 1:24 PM
    aficianado
    aficianado [OP] Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    i wear three;
    sitka. that moth wing pattern
    brush, for my texas stuff.
    and i have some unknown green stuff that my basspro revolution fleece comes in.
    i want predator deception green. if i buy the deception brown also, i could probably toss everthing else. going shopping tonight.
  2. Jan 26, 2010 at 2:07 PM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    Last camo I wore was woodland and tri-color desert. That was before the new MARPAT stuff.
  3. Jan 26, 2010 at 2:18 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    mossy oak new break up........for the seasons around here where im at, it blends pretty well,even when all the foliage is off the trees.
  4. Jan 26, 2010 at 2:22 PM
    bigburrito
    bigburrito Local Man
    DuPage County
    '09 TRD OR
    Demello sliders, fog lights anytime, 265/75R16 Duratracs, 60" HiLift, VIAIR OBA 2.5 gallon tank, FM Super 44, TSB springs, 5100s at .85, bent tailgate
    mossy oak break up. otherwise i have an old surplus woodland camo jacket that i use to help me blend in while im raking leaves.
  5. Jan 26, 2010 at 2:23 PM
    Trigger
    Trigger Well-Known Member
    Mossy Oak Break Up.x3
  6. Jan 28, 2010 at 4:53 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    I mix my camo but it's mainly desert digital camo.
  7. Jan 29, 2010 at 11:44 AM
    bigburrito
    DuPage County
    '09 TRD OR
    speaking of camo... i have finally outgrown (horizontally) my old bdu pants i have had for years. these were some of the best and most durable pants ive owned so now im looking for a new pair.
    can anyone recommend a good online retailer to get the quality (military) pants? it seems like nowadays there are a lot of knock offs out there of questionable quality.
  8. Jan 29, 2010 at 11:48 AM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Advantage Timber for the High country and stalking them WORLD class bull elk in AZ
    Natural Gear for the deserts and them elusive JAVELINA!
    Azbackcountry
  9. Jan 29, 2010 at 11:57 AM
    BSPDX
    BSPDX Well-Known Member
    For the Mountains (Cascade/Coastal ranges)
    For the Desert (Eastern/Central Oregon)
  10. Jan 29, 2010 at 12:14 PM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    X2 for the northwest
  11. Jan 29, 2010 at 6:22 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Probably Mossy Oak... Does great for where I am.
  12. Jan 29, 2010 at 6:36 PM
    08TRD Sport
    08TRD Sport ROOTIN AROUND
    Joshua
    Augusta, Georgia
    10 5th Gen 4Runner
    sentlok real tree pattern
