What just happened?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by robm7, Apr 2, 2017.
  1. Apr 2, 2017 at 7:50 PM
    robm7
    robm7 [OP] Well-Known Member
    2012 TRD OR
    Okay I have a 2012 Taco, couple times I have started it - it would crank but not start. Changed the battery and it has plenty of gas.
    Something in common both instances I was parked on a pretty steep spot. Gravity? No it can't be, it's fuel injected.
    Banana in the tail pipe? Never
    Rodents? I check this the other day and nothing.
    What do you guys think is happening?
    ChadsPride likes this.
  2. Apr 2, 2017 at 8:19 PM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    Distributor?
    Got Spark?
  3. Apr 2, 2017 at 8:25 PM
    robm7
    2012 TRD OR
    Missed checking those
  4. Apr 2, 2017 at 8:27 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Can you smell raw gas? Leaking injectors flooding the engine? How long was it between shutting down and trying to start? I like throwing darts.
    LOLLY, ChadsPride and PottMatter like this.
  5. Apr 2, 2017 at 8:35 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Key immobilizer.
  6. Apr 2, 2017 at 8:39 PM
    Wolftaco0503
    Adam
    Chicago
    Maybe check your plugs?
  7. Apr 2, 2017 at 9:03 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Aliens.
    TheRealKrobar, ChadsPride and airwhen like this.
  8. Apr 2, 2017 at 9:45 PM
    airwhen
    airwhen "You done messed up A.A.Ron!!!!
    Seattle, WA
    2015 TRD Sport DCSB 4X4
    Too much to list!
  9. Apr 2, 2017 at 9:53 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Check battery grounds
  10. Apr 2, 2017 at 10:03 PM
    AANorthwest
    AANorthwest Well-Known Member
    Washington
    2012 DCLB 4x4 TRD sport
    So you turned the key and it would just crank over but not start? You then let off the key, turned it to the off position and then tried to start it again and it would start?
  11. Apr 3, 2017 at 2:18 AM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    Any CEL's?
  12. Apr 3, 2017 at 4:40 AM
    robm7
    2012 TRD OR
    yes with a little gas
    none yet
    solid
    what do you mean aliens? (Paul)
    Maybe I'm overreacting but it seems to happen when truck is parked on a steep spot
  13. Apr 3, 2017 at 4:57 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Mine does this too, also happens on flat ground occasionally also.
    Havnt been able to figure out why.
    robm7[OP] likes this.
  14. Apr 3, 2017 at 6:37 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Mine does the same thing, does it randomly. Got the battery tested, it was good, alternator good, I cleaned the battery posts and thought it solved the problem up until a few days ago.
  15. Apr 3, 2017 at 6:39 AM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    My 08, 11 and 15 all did it, usually on cold windy days or on a decline/incline even slight. It's been discussed here before. Something about the fuel pump and delay.
  16. Apr 3, 2017 at 6:40 AM
    TegoTaco
    Ontario, Canada
    Mine happened during a rain storm.
  17. Apr 3, 2017 at 6:40 AM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Does anybody turn the key in the on postistion and give it a few seconds before starting? Diesels burned that in me and I never stopped doing it.
    ChadsPride and VA SOFTACO like this.
  18. Apr 3, 2017 at 6:41 AM
    TegoTaco
    Ontario, Canada
    Have you ever had issues starting your TACO.
  19. Apr 3, 2017 at 6:45 AM
    SocalOC
    SocalOC Well-Known Member
    2015 Sport
    17" rockstart 2 levling kit 285/70/17 toyo ipen country
    Fuel pump?
  20. Apr 3, 2017 at 6:48 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    ^ that's what I was gonna say
