What kind of attachment at the bottom front of my Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ottoh, Mar 22, 2018.
  1. Mar 22, 2018 at 6:44 PM
    ottoh
    ottoh [OP] Member
    2005 tacoma base
    I am wondering what kind of attachment/thing is at the bottom front of my Tacoma?
    I refer to the square thing. It was on the car when I bought it used.
    Here is a photo:
    I have two of them on front:
  2. Mar 22, 2018 at 6:45 PM
    ottoh
    ottoh [OP] Member
    2005 tacoma base
    It is a 2005 Base 2WD 4cyl.
  3. Mar 22, 2018 at 6:45 PM
    ne_dan
    ne_dan Well-Known Member
    New England
    Flat tow hook up?
    stealthmode and jmaack like this.
  4. Mar 22, 2018 at 6:45 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    attach points for a plow??
    stealthmode likes this.
  5. Mar 22, 2018 at 6:46 PM
    ottoh
    ottoh [OP] Member
    2005 tacoma base
    It is a Florida car.... :)
  6. Mar 22, 2018 at 6:46 PM
    tdcoly
    tdcoly Well-Known Member
    I'm guessing it was flat-towed behind an RV.
  7. Mar 22, 2018 at 6:46 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Looks like you’ve got some extra wires running on the passenger side too (yellow and green)
  8. Mar 22, 2018 at 6:50 PM
    ottoh
    ottoh [OP] Member
    2005 tacoma base
    I see!!! WOW! Looks like a flat tow hook up...
  9. Mar 22, 2018 at 6:51 PM
    Newfiebruh
    Newfiebruh Well-Known Member
    Tom
    2010 Black sand pearl access cab Base
    LED's, Tonneau cover, Fog lights, Front mud flaps, Cooper discoverer a/t3 tires, Tailgate reinforce, Cruise control, LED ditch lights, Bluedriver, 8-ball shift knob, Hitch, SR5 grille.
    Looks like a mounting point for a plow, and maybe one of those tiny salters that go on the hitch. Is the truck from florida or you just bought it there
  10. Mar 22, 2018 at 6:58 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Roadmaster flat tow base plates.
    Check driveshaft for aftermarket disconnect.
  11. Mar 22, 2018 at 7:00 PM
    ottoh
    ottoh [OP] Member
    2005 tacoma base
  12. Mar 22, 2018 at 7:02 PM
    ottoh
    ottoh [OP] Member
    2005 tacoma base
    It is a manual 5 speed car.
  13. Mar 22, 2018 at 7:04 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    Well, there ya go. Now ya know. Probably had a snow bird decide to upgrade and forgot to take the brackets when they traded.
  14. Mar 22, 2018 at 7:09 PM
    ottoh
    ottoh [OP] Member
    2005 tacoma base
    THANKS SO MUCH!!! you guys are worth of GOLD!
  15. Mar 22, 2018 at 9:57 PM
    Muddinfun
    Muddinfun Well-Known Member
    A friend of mine has a Jeep with those exact same tow bar brackets. She didn't have a recovery hook, so I made a stinger that fit it for a shackle. The standard stingers are 1 1/2" and 2". That tow bar bracket is 1 3/4" with a 5/8" pin. I wouldn't do any full on balls to the wall snatch strap yanks with it, but a basic pull should be plenty strong enough.
  16. Mar 23, 2018 at 6:06 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    I think this mystery was solved, but some surf racks use connections like this in the font, instead of using a standard single 2in hitch receiver like mine:
    I've been looking for one on CL the past few months and they ALL have double male ends that would fit the OPs truck if the spacing was right.
  17. Mar 23, 2018 at 8:15 AM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    I immediately knew it was a fishing rod holder when I saw the brackets.
    People saying it's to mount a plow, but the hitch is barely big enough to fit my finger in LOL
