What kind of Bolt???
Discussion in 'Technical Chat' started by Ron, May 19, 2014.
  1. May 19, 2014 at 1:51 PM
    Ron
    Ron [OP] Member
    Ron
    North Shore, MA
    2014 DBL cab
    Hi; I removed the bolt that holds down the rear of the drivers seat bracket to the floor. I'm wondering what kind of bolt it was that I removed???
    It looks like what is called a "dog end" bolt, that is, a smaller section at the very end that would act as a pilot to help keep the bolt straight when starting to screw it in. This bolt has the "dog end" but that part is threaded.
    Anybody know? Does this serve the same function, or is there a "special" nut under the floor that takes both sized threaded portions of the bolt???
    I posted this in the General chat 2nd Gen. area and haven't got an answer so I'll try here.
    Thanks again.
  2. May 19, 2014 at 6:16 PM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    I don't think there is anything special about a seat bracket bolt. Pics would help....
  3. May 23, 2014 at 1:38 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    its a bolt, put it back to hold your seat down lol. if you lost it any grade 10.9 should do.
  4. May 23, 2014 at 1:45 PM
    Papa Taco
    Papa Taco HARD CAAAAAAARRRRRRRL
    Jared
    Socal
    2011 Access Cab 4x4 6 Speed
    Follow the yellow brick road
    standard bolt......
  5. May 24, 2014 at 9:32 AM
    Ron
    Ron [OP] Member
    Ron
    North Shore, MA
    2014 DBL cab
    Ok, here is a picture, maybe;
    http://s95.photobucket.com/user/Ron99_2006/media/100_1050.jpg.html?sort=3&o=8
    It looks like what they call a "dog end bolt" but has threads on the stepped down portion. Never saw one like this before so wondered if it was "special".
    My question again, is it special? Does it have a doubled size nut under the floor? OR, does it work like the dog end bolt, just a thread starter for alignment???
    Thanks for any constructive or informational comments, :).
  6. May 24, 2014 at 2:57 PM
    welterbf123
    Columbus, OH
    2017 TRD Off Road
    It's nothing special. I'm not sure what they call it, but it's designed so that it can be easily threaded through a hole under the carpet where carpet fibers might get in the way. Any standard bolt will work just fine. You'll have to be mindful of the carpet fibers though!...
  7. May 24, 2014 at 2:58 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    unsure of the thread but the hex head is a 14mm.
  8. May 28, 2014 at 8:00 AM
    Ron
    Ron [OP] Member
    Ron
    North Shore, MA
    2014 DBL cab
    welterbf123 is correct. Confirmed by a source at MIT. That configuration on a bolt is there to ease through bolting of carpeting in an automobile. Also being used by Ford, for the last 30 years or so. Not being a Ford person I didn't know. Thanks to all.
    Ron
  9. May 29, 2014 at 9:13 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Toyota uses them often, all over the place. Nothing special, use a normal bolt in stead if you need to.
  10. May 29, 2014 at 9:28 PM
    tam
    tam Well-Known Member
    tam
    East Bay, CA
    Reasons to steal my truck...
    Icon Ext. Travel C/O, TC UCA, Spidertrax 1.25" spacers, CF hood, Glass bedsides, Doug Thorley cat-back, Goodyear Wrangler Duratrac 265/75/16
    Toyota replaced those bolts with standard bolts. I have an 02 and when I went for replacements they had two different sizes, one for the inner thread and one for the outer.
