What kind of camper do you have?
Discussion in 'Towing' started by RoyB, Apr 18, 2010.
  1. Feb 10, 2019 at 5:09 AM
    #1101
    Oldewing1800
    Oldewing1800 Well-Known Member
    2006 Double Cab
    Dog hair, lost happy meal parts from Grandkids....
    Set as per instructions, and no not really. Only got 50 or so miles on it so far. I know I am ok with the weight, both total and trailer. But hearing bad things about 27 ft lenght, and trying to see if I can "limit" my risk. I am comfortable towing, but also older than I used to be, if you get my drift....
  2. Feb 10, 2019 at 6:57 AM
    #1102
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    I will add my 2 cents...I am pulling a similar trailer to the Ultra Lite 245BHS. All the weights are around the same. I will say, I had to upgrade my suspension in order to pull my TT, and upgrade other areas of my truck. I had to add air bags - OME leaf packs - larger trans cooler - and a scan gage so I can monitor the trans temps. After adding these extras the truck pulled the TT much better and safer. I am using a Trunnion weight distribution set up right now, I have been using this for several years and on long trips I find myself white knuckling it at times because the TT is swaying. I am in the mitts of buying a Hensley Hitch, very expensive. You need to ask yourself a few question: Will you feel comfortable towing that size trailer, can you control the trailer, will you feel safe with your family in the truck and will they feel safe. Will the Tacoma pull that size TT...absolutely, but with modifications to the suspension. You may be spending 3K more on the TT but you will also need to add another 2K in suspension upgrades. now you are at 5K...is it worth it. I have a KZ Sportsman 245BHS, total length is 27' dry is 4470#, loaded for a long trip I average 6100#, my tongue weight is 625#. This weight on a stock Tacoma will bottom you out right on your bump stops. I love my truck and I do believe it will tow whatever you throw at it, but you need to be smart about it. Just because the truck can tow something heavy doesn't mean you can mentally. Good luck in your future purchase and stay safe in your travelsDSCN1809.jpg
  3. Feb 10, 2019 at 10:46 AM
    #1103
    medic2230
    Murph
    Bama! Roll Tide
    I have a Keystone Passport 2400bh at 4810 dry and the 2nd gen Tacoma does fine with it. It’s no speed queen and it will slow down on big hills but maintains 60-65 fine on the highway. Slideout was a big plus for us with the U-Shaped dinette. You can let the slide out about a foot or so to get by it. At home I leave it out all the way. When we stop for food supplies we just let it out enough to get to the kitchen area.
    I had them change my jack out to an electric when I bought it. It’s also prewired for the backup camera. I’ll be adding that myself because they want $600 for the camera and to connect 2 wires along with two screws to hold it on. No thanks.
    Bedroom has entertainment center in the middle with sliding doors on each side. Tv is on the outside of bedroom but it has a place for one on the inside of bedroom too. Outdoor kitchen was a must for us and we enjoy having a second fridge outside for drinks. Helps to keep sand out of the camper. We also like it has a full size queen mattress because that will be replaced before our next trip with a memory foam one.
    We’re not ones to pack anything we might ever need so it keeps the weight down.
    We rented a Winnebago micro mini 1700bh prior to buying. It was way too small for the 3 of us. The 2400bh was perfect for our size family. Only thing with most outdoor kitchens is you lose rear storage compartment. The only one we have is the front one to get to from outside.
    I should probably add also I have Dakar springs in the back too. If stock you may need to upgrade your suspension some way.
    gixxerphil likes this.
  4. Feb 10, 2019 at 10:58 AM
    #1104
    medic2230
    Murph
    Bama! Roll Tide
    I’ve been using the recurve R3 hitch and towed around 1000 miles so far with it. I haven’t had any issues with sway or felt uncomfortable at any point. My camper overall is 27’11”. It can be a little uncomfortable at first it you’re just not used to having something that big behind you. The more you drive with it the more comfortable you’ll get. Main thing is never exceed your comfort zone. The campsite will be there when you get there. Bad things happen when you’re in a hurry. Take it easy and enjoy your trip. If you’re in a hurry or worried about things it just makes the trip not what you were expecting. I try to do all travel during the daytime. Not only will you see road hazards and be able to avoid them it’s a lot easier to change a tire with light than in the dark.
    gixxerphil and jwctaco like this.
  5. Feb 11, 2019 at 9:36 AM
    #1105
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    So I was still debating the merits between the Apex Nano 208BHS and the Apex Ultra Lite 245BHS and was thinking it would be nice if they had something between, and lo and behold I see there is a Apex 226BH!
    It has similar upgrades over the 208 as the 245 (electric jack, aluminum wheels, sink cover, oven, backup camera ready, dual propane, etc.) and comes in at around 4400# instead of the 4600# of the 245, so saving a bit of weight and length, though still not quite down to the 208's 4000#.
    The downside is it isn't a slide, so a bit less interior space (though less to worry about as far as mechanicals breaking and seals around it I'd imagine), and it is 8' wide instead of the narrower 7.5' body. Does the 6" extra width make that much difference in towing, especially on our Tacomas? Any comments on towing a 8' wide trailer, especially from someone that may have done both in the past? I assume it might affect mileage a bit with more surface area facing the wind, but I wonder how much it would really affect that and handling in the end.
  6. Feb 11, 2019 at 5:41 PM
    #1106
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    I can't speak for the 7.5' wide, but towing the 8' sucks fuel. As much as I hate it, that's the nature of the beast. I don't think I'd trade the extra 6" for possibly better fuel economy. Hopefully others will give more input.
    RolfeMobile likes this.
  7. Feb 12, 2019 at 1:42 AM
    #1107
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    The tires on my R-Pod are outside of the body I don't have a sway control and have zero sway.
    jbs1976 likes this.
  8. Feb 17, 2019 at 3:19 PM
    #1108
    eMKay
    eMKay Well-Known Member
    Michael
    Buffalo, NY
    2019 Cavalry Blue DCOR 6MT
    Pro Grill, roof rack, HID headlights, yellow fogs, LED high beams, trailer brake controller
    I picked up a 2013 Jayco X19H yesterday, traded in my 1995 Itasca Passage 25ru for it. Nearly a straight up trade. My motorhome was in excellent condition, so that helped. I always wanted a hybrid but never had anything that could tow anything but the smallest hybrid. We have had pop ups in the past and I loved the open feeling, but not the pain in the ass loading, setup, and unloading.
    The trailer weighs 3669lbs dry, and man, I forgot just how much stuff was in my motorhome, probably 600lbs do stuff that I had to transfer over (I only went there for the annual safety inspection, lol, didn’t intend on trading it in. But they had the right trailer and worked with me) So with the thing loaded up it towed fine.
    Steve721, mr.trd, Maxcustody and 4 others like this.
  9. Feb 17, 2019 at 4:21 PM
    #1109
    "OldManTan"
    Buffalo, NY
    '16 Tundra DC
    Looks like Camping World? Maybe I'll see you out in the campgrounds :cheers:
  10. Feb 17, 2019 at 4:49 PM
    #1110
    eMKay
    Michael
    Buffalo, NY
    :thumbsup:
    We are doing Lake Erie State Park, Golden Hill, Wellesley Island, and probably Letchworth this year.
  11. Feb 17, 2019 at 4:57 PM
    #1111
    deusxanime
    MN
    Does having a Sport vs. Off-Road affect much as far as towing a decent size RV (4000-4500#)? I believe the Sport has a bit stiffer suspension so wondering if that is better or doesn't really matter since either way you'll want to use a WDH and possibly upgrade springs, add Sumo Springs, or even add air bags.
  12. Feb 17, 2019 at 5:16 PM
    #1112
    eMKay
    Michael
    Buffalo, NY
    The shocks are stiffer on the sport, but I think the rear springs are the same, so it won’t make a difference. The WDH makes a huge difference and is a must. I plan on upgrading the springs anyway, but I was thinking I would also need airbags, after towing this thing with the WDH I don’t need them. You may feel different in your situation but try the WDH first.
  13. Feb 20, 2019 at 1:18 PM
    #1113
    Kim1320
    Kim1320 Member
    2017 Toyota Tacoma
    9321A456-2417-4432-A310-BD8DD817A0AD.jpg I have a 2017 TRD OR and tow a Coachman Freedom EXpress 192rbs . It weights right around 4100 lbs dry . I have a weight distribution and sway hitch and the setup sits pretty much level . I am considering adding the Timbren bump stops on rear . Has anyone on here added them and are they worth it alone or would I need to add additional stuff?
    In response to the post where someone mentioned a Hensley hitch at 1600.00 ... if you find one that cheap grab it ... I think my quote was around 2300.00.. I am considering the Anderson hitch as a upgrade.
    airsavage and medic2230 like this.
  14. Feb 23, 2019 at 2:50 PM
    #1114
    scoand10
    scoand10 Member
    After lots of searching I finally have found and purchased a Northern Lite 6'10" slide in camper. 93 on my 03 tacoma.
    TacoManOne, BRFab, G.T. and 5 others like this.
  15. Feb 23, 2019 at 4:42 PM
    #1115
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Jealous! I wanted one for a few years to take up skiing and stuff. Could never find one in good shape/at the right right price
  16. Feb 24, 2019 at 2:12 AM
    #1116
    ogg
    ogg Well-Known Member
    Eric
    Ohio
    2015 TRD OR
    Supercharged with 2.85 pulley King ext travel with resi's Total Chaos Uppers All Pro Expo leafs Fox 2.0 with resi's rear Level 8 wheels 285/75r16 Mickey Thompson ATZ Prinsu rack SOS sliders, front and rear bumpers, skids
    Just picked this up over the weekend. Seems like it's going to pull perfect behind my truck. 20190222_174601.jpg
  17. Feb 24, 2019 at 7:58 AM
    #1117
    Rabbidllamas
    Rabbidllamas Well-Known Member
    Phil
    Tri-Cities WA
    11 DCSB Stormtrooper
    Nice looking setup. Congrats!
    ogg[QUOTED] likes this.
  18. Feb 24, 2019 at 8:05 AM
    #1118
    squeaky
    squeaky Well-Known Member
    Wisconsin
    2014 MGM DCSB Sport 4x4
    Nice looking setup. Are you planning to regear with those tires?
    Casper66 likes this.
  19. Feb 24, 2019 at 9:02 AM
    #1119
    ogg
    Eric
    Ohio
    2015 TRD OR
    I've thought about it before. I've had this setup for a year or so now and it seems like it works out pretty decent. I am supercharged with a smaller pulley so that helps out a ton power wise
    mr.trd and Casper66 like this.
  20. Feb 24, 2019 at 11:53 AM
    #1120
    squeaky
    Wisconsin
    Ah, I’m sure that supercharger works great. I tow a 4500# boat which obviously has much less drag than a camper. I’d sure like to step up to either 275’s or 33 skinny’s, but I definitely do not want to regear. Still debating.
