What kind of camper do you have?
Discussion in 'Towing' started by RoyB, Apr 18, 2010.
  1. Mar 21, 2020 at 11:01 AM
    #1441
    gotime242
    gotime242 Active Member
    Apex Ultralite 249RBS, about 4800 empty.
    Wd hitch with 800lb bars, have sway control but not installed yet. I do have airbags but leave them low / around 10psi due to WDH.
    Towing short distances (in FL). It does “ok”...still working on setup. I keep it under 60 as well.
  2. Mar 21, 2020 at 11:05 AM
    #1442
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    Welcome to the ApexTaco family! I have an Apex Nano 208BHS, so a bit lighter, but similar profile. It does it, but as you said, definitely need WDH with anti-sway and usually keep it around 60mph top speed. I did have airbags but they never worked right and my WDH (E2) seems to work great keeping the truck level, so I ended up just removing the bags.
  3. Mar 22, 2020 at 3:49 AM
    #1443
    wannabemtnbiker
    wannabemtnbiker Well-Known Member
    Derrick
    Georgetown Tx
    2008 White Tacoma Prerunner
    What about your side mirrors for towing?
    I pull my larger campers with my o4 F250, but thinking about trading in my 28' Cougar for a smaller camper that my o8 Prerunner could safely tow.
    My 36' Lacrosse bumper pull has my F250 towing maxed out just empty.
    So it just sits at the site and is called "home".
  4. Mar 22, 2020 at 5:03 AM
    #1444
    gotime242
    Haven't upgraded yet, will probably try some cheaper strap-ons next time.
  5. Mar 22, 2020 at 5:12 AM
    #1445
    wannabemtnbiker
    Derrick
    Georgetown Tx
    That's kinda what i thought too.
    But after reading more into the topic/posts, I'm not sure it'd be worth the trouble since my Taco doesn't have the towing package,
    Unless i got a small Casitas. But, my o4 F250 is a gas burner and only has 140k miles on it.
  6. Mar 22, 2020 at 8:46 AM
    #1446
    deusxanime
    MN
    toyotaman29 and wannabemtnbiker like this.
  7. Mar 22, 2020 at 9:01 AM
    #1447
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Wide angle camera worked wonders for me. My stock mirrors are pretty much set to see the outside of both lanes down the flanks, and the camera catches whatever is riding/approaching either side of my rear.
    Much cheaper than replacement mirrors, and less "shakey" than strap on mirrors.
  8. Mar 22, 2020 at 9:04 AM
    #1448
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    That’s my plan too.
  9. Mar 22, 2020 at 10:33 AM
    #1449
    wannabemtnbiker
    Derrick
    Georgetown Tx
    Whoa!!
    I'm way behind on towing options and features!
    That's a cool idea. I've seen em on motor homes, but hadn't really noticed one on a travel trailer. My 2 campers are a 2015 and 2016, so maybe those are newer options?
    I'm just used to the big extendable mirrors on my F250 when I tow or towed my campers.
    Rock Lobster[QUOTED] likes this.
  10. Mar 22, 2020 at 10:35 AM
    #1450
    wannabemtnbiker
    Derrick
    Georgetown Tx
  11. Mar 22, 2020 at 11:05 AM
    #1451
    deusxanime
    MN
    I have a rearview camera on my trailer too, but I still wouldn't tow very far without towing mirrors. I always (even when not towing) have my side mirrors adjusted out wide, with only a little overlap with what I normally see in my truck's rearview. Even so, when towing you end up with some pretty big blindspots on the side of the trailer, especially on the passenger side. The BSM helps too, if you have that.
    And I'm saying that with an Apex Nano which is a 7.5' wide trailer, so I imagine it is even worse with a normal 8' wide one.
    wannabemtnbiker likes this.
  12. Apr 11, 2020 at 5:13 PM
    #1452
    Jaybird Tacoma
    Jaybird Tacoma Member
    Kentucky
    Black 2017 SR5 4x4..... 4 door short bed
    756D476A-3CD4-4425-B3B4-9F4A45B4ABDB.jpg I’ve got a 2020 wolf pup 18TO with a slide which weighs about 4,000lbs dry/empty but 5,000 lbs with gear & my little Taco pulls her pretty good
  13. Apr 15, 2020 at 12:01 PM
    #1453
    brtnstrns
    brtnstrns Well-Known Member
    Seattle
    2020 Voodoo Blue TRDOR DCSB
    That's interesting, I've never seen an asymmetric stabilizer jack set up like that. Seems like the one right behind the driver's side wheel wouldn't do much. (unless I'm just getting tricked by perspective?)
  14. Apr 16, 2020 at 5:48 PM
    #1454
    Jaybird Tacoma
    Kentucky
    Yeah that’s an optical illusion on the stabilizer jacks lol
    robssol likes this.
  15. Apr 19, 2020 at 11:09 PM
    #1455
    brtnstrns
    Seattle
    Thought I didn't have a picture of our setup but my wife took a picture of our first outing with the Tacoma. 2019 Forest River NoBo 16.5
    iDiggs9, dre5491, medic2230 and 10 others like this.
  16. Apr 25, 2020 at 8:28 PM
    #1456
    RLM7907
    RLM7907 Member
    2013 Silver Tacoma PreRunner
    My 2013 PreRunner Sr5 should tow a 2019 Wolfpup 18T0 pretty well, correct?
    Jaybird Tacoma likes this.
  17. Apr 27, 2020 at 3:53 AM
    #1457
    Jaybird Tacoma
    Kentucky
    Very nice!!!!!
    brtnstrns[QUOTED] likes this.
  18. Apr 27, 2020 at 12:17 PM
    #1458
    mobgma
    mobgma Well-Known Member
    Edmonton, AB, Canada
    2016 Toyota Tacoma TRD Double Cab Long Box
    Can anyone recommend the largest RV trailer you can pull that has the following items:
    1. 2 axles (a must). any type, does not have to be torsion. I realize it likely is not needed but would prefer.
    2. small slide (for dinette purpose specifically)
    3. queen bed and small bunkhouse bed setup
    4. GVW of 5000-5500 lbs?
    Was looking at the 2020 JAY FLIGHT SLX 8 242BHS but its too heavy with a UVW of 5505 lbs and a GVW of 7000 lbs well exceeding the Taco. The next size down in the series has no slide. Not sure of other brands that meet this requirement.
  19. Apr 27, 2020 at 1:06 PM
    #1459
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    I can only think of one that checks all those boxes but I don't think you'll like my answer.... Flagstaff HW29SC.
    Thats a lot to ask while keeping it that light, I'm afraid.
    robssol and Jaybird Tacoma like this.
  20. Apr 27, 2020 at 1:35 PM
    #1460
    deusxanime
    MN
    Check out the Apex Nano 208BHS. I think it fits most of your checkboxes - has dual axles, dinette on a slide, double over double bunks in the back, queen bed in the front (optional murphy style), and dry weight is 4000#.
    I might be biased, but I think it looks good and matches up with a Tacoma as well, especially a Cement one.
    More info and walkthrough on YouTube.
    You might also be able to squeak by with the slightly larger 245BHS, but personally I think that is getting to be too much for a Tacoma, especially the tongue weight and total weight once loaded with your equipment.
    Medic-2043, TacoManOne, Twize and 4 others like this.
