What kind of camper do you have?
Discussion in 'Towing' started by RoyB, Apr 18, 2010.
  1. Jan 22, 2021 at 9:50 AM
    #1661
    outflow
    outflow Member
    San Antonio, TX
    2014 TRD Offroad
    It's been great, but this is the first time we've taken it out with the 2014 TRDOR. Our previous tow vehicle was a Subaru Outback with the 4 cyl and CVT. The Subie managed to drag us up the Rockies a couple times but just barely. The camper is around 1850lbs dry, but loaded with water/gear and the dual battery conversion probably is pushing 2300 lbs loaded (haven't weighed it yet). The Outback's tow rating was 2700 lbs but that's generous. The Tacoma's 6500 lb tow rating (offroad 4x4 V6 tow package) made pulling the little Tab super easy. You don't even notice it back there, power wise. We surely took a MPG hit but I didn't calculate it because this recent trip was less than a tank of gas round trip.
    Our Tab is a late 2018 with most of the 2019 upgrades, 320S model (shower). The little camper is perfect for us (wife, me, hound dog) as former tent campers, it's pure luxury. Having a bathroom onboard makes midnight pee events a lot easier than heading into the dark woods with a flashlight. We've never used the shower, but the "galley" has a sink/2 burner LP stove and fridge. The heater is a circulating-glycol type that can run on propane or electricity. This past trip a couple mornings were in the 25F range, light freeze for a couple of hours. We stayed inside, made jiffy pop, watched movies/netflix downloads from our phones through the camper's dvd/tv system and kept the heat on 70 degrees. This model is the base model with the Outback ("offroad" version)'s rack system installed (option). The offroad version has a pitched axle that lifts the camper about 4.5" and has larger AT type tires along with a bigger/better diamond plate front rack. The Outback versions were considerably heavier so we avoided them due to the Subaru's weak tow abilities. I plan on buying the upgraded axle (around $600) from the factory and installing it myself to get some lift now.
    So far we love the camper, we've had it out a dozen times with the Subaru and now once with the Tacoma and it just gets better and better every time. They're not cheap or easy to find but I highly recommend the Tab campers. They're made by Amish craftsmen and are a step above the standard Indiana-made US RVs that are everywhere.
    DanishTaco and Fast1 like this.
  2. Feb 26, 2021 at 9:21 PM
    #1662
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    One that has a shower and a pee pot. Those two items will make your female travel partner happy. Guys can pee in the woods or the side of the road
    and wash off with a gallon of water.
    RolfeMobile and theredofshaw like this.
  3. Feb 26, 2021 at 9:23 PM
    #1663
    ScrippsRanch67
    Bob
    Fiberglass shell
    Your Access cab is the I4? What is the towing capacity for your Tacoma. Find a lightweight trailer at 50-60% of your tow capacity and you will be a happy camper. Look at Jayco.
  4. Mar 1, 2021 at 4:15 PM
    #1664
    Mike G
    Mike G Well-Known Member
    2020 SR5 Tacoma DCLB 4x4 Red
  5. Mar 1, 2021 at 5:29 PM
    #1665
    ScrippsRanch67
    Bob
    Fiberglass shell
    Nice looking unit. I'll check it out online now...what's the function of the outside "tent"? Shower? Toilet?
  6. Mar 1, 2021 at 5:36 PM
    #1666
    Mike G
    My camper is still winterized, so that's just a porta john.
  7. Mar 2, 2021 at 8:15 AM
    #1667
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    Did you remove the Geo Pro stickers and all the other small stickers on the side of the trailer?
    How does the Tacoma handle pulling this smaller trailer? MPGs? S5 transmission selection? How much dirt road can this trailer handle? ground clearance?
  8. Mar 2, 2021 at 8:29 AM
    #1668
    Mike G
    I removed the big side Geo Pro decals and also removed all of the small stickers they plastered all over it.
    The Geo Pro comes with an Off-road package that provides off- road tires and a lift. The camper is not an off-road camper, it would just shake itself apart if taken on any serious trails.
    It can handle maintained dirt roads, just go slow!
    I just posted a pretty detailed review of my towing experience on a FB site, give me a few and I'll see if I can find it.
    Fast1 likes this.
  9. Mar 2, 2021 at 8:31 AM
    #1669
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I don't own a camper, but my Uncle Craig does. He has a 1969 Airstream Caravelle which is light enough that it could be pulled behind my 4-banger Tacoma a short distance, but he pulls it with his 2006 Dodge Ram 2500 Cummins, a truck which I think is bit overkill for the job; He also owns a 1977 VW Westfalia Camper!
  10. Mar 2, 2021 at 8:33 AM
    #1670
    Mike G
    I found my post, pasted below.
    I know a few people who tow a 15TB with a Tacoma so I thought I would offer up my first impression towing with my 2020 Tacoma.
    My truck,
    2020 Tacoma SR5 DCLB, 4x4, V6, auto, tow package(no external trans cooler).
    Aftermarket add-ons,
    265/75/16 Cooper AT3, load range C.
    Bilstein 5100's
    Roadmaster Active Suspension.
    B&M Transmission cooler (70264).
    Recurve R3 WDH
    Tekonsha primus IQ brake controller.
    The trip was on I-70 and I- 68 headed west to Little Orleans MD. The speed limit is 70mph and the route has several long moderate climbs in both directions.
    The handling and weight management is very good, the WDH provided a nice controlled ride with very little rear sag. I didn't notice any trailer sway(65mph), but I could feel a little movement in the whole rig with a moderate cross wind. I accept this as normal and had no issues maintaining lane control.
    Braking,
    I had zero issues with the braking performance and as expected the stopping distances increased but is very controlled.
    The brake controller did a great job managing the trailer brakes.
    Performance,
    I tow in 4th gear with ECT engaged.
    The Tacoma did fine pulling at 65mph on level or slight inclines, it basically just held 4th gear and had no issues.
    When I started pulling the longer steeper grades the transmission
    would constantly downshift to 3rd gear to maintain 55-60mph.
    I'm glad I added the transmission cooler!! I will soon be adding a Scangauge 2 to monitor trans temps.
    This is just my opinion based on my towing experience but I wouldn't want to pull anything heavier than a 15TB with a Tacoma, it is adequate for 3500lbs and under.
    The 3.5 V6 lacks low-end torque and makes it's power higher in the rpm range so you just get used to running higher rpm's to get the performance you need, the engine can handle it!
    I won't be trading in my new Tacoma anytime soon, it does the job well and I really like my new 15TB.
  11. Mar 2, 2021 at 10:54 AM
    #1671
    Fast1
    Minneapolis, MN
    Thanks for providing the detail review of towing the Geo Pro 15TB. Helps with decision making for those of us that are interested in this particular travel trailer.
    Do you have any fuel economy results for your towing and how many miles did you tow the trailer?
  12. Mar 2, 2021 at 11:19 AM
    #1672
    Mike G
    Averaged about 10.5 mpg.
    2.5 hours each way. I maintained a pretty consistent 65mph except on the steep climbs.
    The camper weighs about 2600lbs dry, so I would guess loaded up the total weight would be around 3100lbs.
    All tanks empty.
    The Tacoma does a good job pulling the camper, it does struggle a bit on long steep highway grades, but I expected that.
    If I was pulling anything over 3500lbs on a regular basis I would definitely recommend a full size truck.
    Fast1 likes this.
  13. Mar 2, 2021 at 11:32 AM
    #1673
    captrussia253
    captrussia253 IG: ruslan.khinotskiy
    PNW
    2017 Tundra 2016 4Runner
    Our small off-road rockwood pop up camper.
  14. Mar 3, 2021 at 5:09 PM
    #1674
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    I have the same trailer. Love it so far. Took it CO-TX-LA-MS-AL-GA and back to CO over Christmas. Flawless adventure, looking forward to many more.
    Mine came without any decals. :headbang:
    cshrum and Mike G[QUOTED] like this.
  15. Mar 7, 2021 at 10:50 AM
    #1675
    bodean
    bodean Well-Known Member
    Shawn
    Crowsnest Pass, AB
    02 Taco RCSB, 16 Taco AC6MT, 07 FJC, 22 Bronco
    Sold our camper last summer. Giving the canopy a go this year, had our first night this weekend. Still a little cold up in the mountains, but wasn’t too bad.
    5ABB9765-55DA-4BF5-9BCB-CAC8461840D8.jpg E70D9BDE-7192-45E8-8A1B-A18C11B14363.jpg 235521E4-5D61-489A-9F49-06BD30CB054B.jpg 70822FB2-1D83-43B7-A903-2261A7513E67.jpg E51DA7EA-4253-4CD5-A63E-D21FBD352535.jpg E95EDF25-3E7D-418A-A448-5257B21C4702.jpg
  16. Mar 7, 2021 at 11:04 AM
    #1676
    Fast1
    Minneapolis, MN
    Who makes the canopy you are using?
    edit.. I see the canopy is an ARE commercial series..
  17. Mar 9, 2021 at 8:00 PM
    #1677
    onesojourner
    onesojourner Well-Known Member
    The Ozarks
    The one on the left is a basket case needing a rebuild. The center one is just about ready to camp. The rpod showed us the best way to travel in America, and it's also for sale.
    strider98 likes this.
  18. Mar 12, 2021 at 10:53 PM
    #1678
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I like your glow in the dark farm. :)
  19. Mar 15, 2021 at 8:49 AM
    #1679
    TacoMaps
    TacoMaps Well-Known Member
    Nick
    Oklahoma
    2020 TRD OffRoad DCSB AT
    Which model Rpod is it?
    TIA
  20. Mar 15, 2021 at 9:04 AM
    #1680
    onesojourner
    The Ozarks
