What kind of differential?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 45acp, Aug 19, 2009.
  1. Aug 19, 2009 at 5:26 PM
    45acp
    45acp [OP] Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Finally buying my first Tacoma!
    My apologies if it's a dumb question, but unfortunately I know next to nothing about vehicles. I never heard of differentials until I came here.
    I've read the howstuffworks.com explanation on differentials but how would I know what kind is on my Tacoma?
    To begin with, it's an '04 4x4 w/ standard transmission. No TRD decals.
  2. Aug 19, 2009 at 5:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You should have a code on the sticker on the door jamb. It should be a letter, followed by 2 mumbers, then another letter.
    Example:
    B07A
    Find the code, and post it up, and we can tell ya what you have. :)
  3. Aug 19, 2009 at 5:36 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Guessing an open diff, unless someone has removed the stickers and you have a button that says "RR Diff Lock" in orange writing to the left of the steering column.
  4. Aug 19, 2009 at 5:48 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I'll try and find out what the code is and post it. Thanks
  5. Sep 8, 2009 at 2:42 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Finally brought it home today. Anyway, I think I found the numbers you were talking about. It is B07A
  6. Sep 8, 2009 at 3:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Congrates! You have a 4:30 gear ratio. :)
  7. Sep 8, 2009 at 3:44 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    What does that mean? Sorry. :crapstorm:
  8. Sep 8, 2009 at 4:13 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    hey dont want to take over your thread here 45acp, but Chris i was hoping you could help me out with mine -- B02A
  9. Sep 8, 2009 at 5:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You have 3:58's.
  10. Sep 8, 2009 at 5:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It means for every 4.3 revolutions of the Drive shaft, the rear axel spins 1 time.
  11. Sep 8, 2009 at 6:09 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    cool i didnt know about the code thing. Another side question on my tacoma (1997 basic extended cab 4x4 srs model) i have locking diffs in the front and limited slip in the rear right? to be honest i dont really know if the diff, is correct to use for the front but what do i know i am just a kid.
  12. Sep 8, 2009 at 6:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You have Locking Hubs in the front, and an Open rear diff. :)
  13. Sep 8, 2009 at 6:42 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    what does a tcase ratio mean? I know in lo for the its like 2.5:1 and hi is 1:1
    does that mean with my TRD, in Hi it's 4.1:1, and in Lo it's like a 10:1 drive?
  14. Sep 8, 2009 at 6:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep
  15. Sep 8, 2009 at 9:21 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    If I understand correctly (from what I've read in other threads), the tire size is partially dependent on the gear ratio. Is there a range of tire sizes I can choose from, or am I limited to just one?
  16. Sep 8, 2009 at 9:33 PM
    pittim
    Pennsyltucky
    Boujee Prius
    you can buy whatever fits on your truck.
    once you get into bigger tires you're going to want to regear due to the size of the tire.
    once you get into 33's (with the V6 at least) you'll be able to tell there is some powerloss and should think about possibly regearing. if you go bigger you're definately going to want to regear.
  17. Sep 9, 2009 at 5:18 AM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    If I understand correctly, I can go up to 32", but if I want 33" or above, I'd have to re-gear? I measured the diameter of mine and they appear to be 29".
  18. Sep 9, 2009 at 6:15 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You need to go by the size on the side of the tire. With 4:30's, you would be fine with w 32" tall tire. A 265/75/16 for example.
  19. Sep 9, 2009 at 9:44 AM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Just found the tire sizes on the door frame. Thanks for the help!
  20. Sep 9, 2009 at 9:45 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That size is usually the base tire size.
