What kind of exhaust shoud i go with ?
Discussion in 'Performance and Tuning' started by swalke26, Sep 20, 2009.
  1. Sep 20, 2009 at 12:36 PM
    swalke26
    swalke26 [OP] New Member
    265 bf goodwrench all terrains, rockford p3 12, aftermarket cd player, parrot handsfree
    Im looking in to getting an exhaust on my 4.0 2006 tacoma .... Any suggestions ? Thanks
  2. Sep 20, 2009 at 12:42 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Do you want one for sound or performance?
  3. Sep 20, 2009 at 12:44 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Performance = Dynomax
  4. Sep 20, 2009 at 1:09 PM
    swalke26
    which one sounds the best ?
    which one gives the best performance ?
  5. Sep 20, 2009 at 1:11 PM
    DanGer
    Which ever one sounds best is totally up t oyou and your ear. Flowmaster is the loudest, but loses about 5 HP.
    Dynomax super turbo gives the biggest performance gain at about 5 HP.
  6. Sep 20, 2009 at 5:22 PM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    Do you have any proof of this?
    Change in weather alone will make/break 5-15hp easy.
  7. Sep 20, 2009 at 6:52 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There are quite a few on the market. Best bet is to youtube the sound clips so you can get an idea of how they sound. Then it all boils down to what you want to spend. Quality=money. Also you want to keep in mind what other things you might want to do in the future with mods. That will dictate if you need more flow or not. Do you want to do a cat back or just muffler swap. A muffler swap alone will usually net you a decent gain just because you free up some flow.
    JBA, Magnaflow, Borla, Aerourbine, URD. Take your pic
