What kind of flashlight is in your 3rd Gen ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2016BBP, Oct 8, 2016.
  1. Oct 8, 2016 at 10:18 PM
    2016BBP
    2016BBP [OP] Well-Known Member
    Southeast
    SR5 V6 Auto
    Method Wheels, WxTechGuards, TowPkg, KNDropn, 3M-Tint
    The Fenix PD35 ranks high in every review that I have ever seen.
    https://faveable.com/articles/87/best-flashlights-to-combat-the-dark
    http://www.brightguy.com/category/Best-Flashlights
    http://thetacticalguru.com/best-tactical-flashlight/
    http://gearpatrol.com/2015/07/31/10-excellent-everyday-carry-flashlights/
    http://www.infinitepowersolutions.com/tactical-flashlights/
  2. Oct 8, 2016 at 10:21 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Good read. What I like most about the pd series and nitecore offerings in the same style is the lack of a large head/bezel. It the make it or break it for not looking like a dork with a ? in your pocket. I've checked and the beam pattern isn't compromised when you choose a high end light like the fenix.
    2016BBP[QUOTED][OP] likes this.
  3. Oct 8, 2016 at 10:29 PM
    2016BBP
    Southeast
    SR5 V6 Auto
    I agree, the PD35 makes for a great carry, I have the Fenix FD40 as well, which is a great light with the zooming lense but I use it mostly around the house as it does have a larger diameter lense on it.
    IronPeak[QUOTED] likes this.
  4. Oct 8, 2016 at 10:40 PM
    melman8r
    melman8r Well-Known Member
    NY
    '17 TRD Off Road AC w\Prem & Tech Pkg. in Quicksand
  5. Oct 8, 2016 at 10:52 PM
    2016BBP
    Southeast
    SR5 V6 Auto
    melman8r[QUOTED] and IronPeak like this.
  6. Oct 8, 2016 at 10:53 PM
    joetart
    joetart Active Member
    2016 TRD OR
  7. Oct 8, 2016 at 10:58 PM
    OneWipeCharlie
    OneWipeCharlie Well-Known Member
    2016 Inferno Tacoma TRD Sport
    This thread is going to make me buy another flashlight isnt it?
    ryanbitt, 2016BBP[OP] and IronPeak like this.
  8. Oct 8, 2016 at 10:59 PM
    2016BBP
    Southeast
    SR5 V6 Auto
    Family portrait. :D It`s a sickness, but it`s good to have one arms reach away. :notsure:
    jetfishn, ryanbitt and IronPeak like this.
  9. Oct 8, 2016 at 11:30 PM
    HalfWayThere
    HalfWayThere Well-Known Member
    SLO, CA
    2016 DCSB TRDOR 4x4
    What's the self discharge rate of a 18650? Will it be there when I dig it out a few years from now? What I've found on Wikipedia is 1.5-2% per month self discharge at room temperature. Assuming the truck environment will likely be more adverse than room temperature, let's use 2%. So about 75% charge remaining after 2 years. That's actually pretty good. I wonder how well that works out in real life. Anyone have any real-world experience with standby/shelf life on these batteries?
    Wikipedia states self discharge for alkaline batteries is less than .3%/month with an expected life of 5-10 years (I suspect end of life is not from self discharge, but some other mechanism). So after 2 years we are at 92% with alkaline batteries.
    Also, while the single 18650 has high density, if you don't mind the bulk (you need a handle anyway and perhaps better to swing) you get more capacity with a set of C cells.
    All values just what I found with a quick search and I'm playing loose with nominal values but I think they are acceptable for a qualitative analysis:
    18650 3.6V and 3.0Ah capacity = 10.8Wh*
    C-cell primary battery 1.5V and 8.0Ah capacity = 12Wh** EACH or 4x that with a set of 4
    *Not having gone to this tech yet (I am from the 70's, so that's my excuse) I don't know if you really should use all the capacity of these batteries or if you should only discharge to some lower state of charge such as 40%. Here I assume you get it all.
    **To be fair, effective capacity will be considerably worse under heavy load. However, if you have a stack of 4, current draw will be lower at the higher voltage so you will probably be closer to nominal.
    As always, I'm open to corrections and input.
  10. Oct 8, 2016 at 11:34 PM
    IronPeak
    AuggieX
    Back to Back
    You can purchase alkaline CR123A cells, 2x in place of one 18650 if you are concerned about the discharge rate of lithium cells. 18650 cells are used in laptop batteries and have been in use for may years. Another reason I don't like c cells is because they are rarely interchangeable to different devices such as lanterns (often d cells). Having your devices use the least different types of batteries is best. I had a c cell lamp a few years ago and hated having to shop for the expensive c cells just for that one dang light.
    Spare Parts likes this.
  11. Oct 8, 2016 at 11:38 PM
    2016BBP
    Southeast
    SR5 V6 Auto
    Most people that use 18650 batteries use them regularly, they don`t let them sit for 2 years but if you are interested in learning about them, there is lots of info here.
    http://www.batteryspace.com/batteryknowledge.aspx
  12. Oct 8, 2016 at 11:40 PM
    qbizzy
    qbizzy Well-Known Member
    Q
    '16 Taco
  13. Oct 8, 2016 at 11:50 PM
    BarberRider
    BarberRider Merit Badges: Scuba Cliff diving Mirror Awareness
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    It's got a cop motor, a 440-cubic-inch plant. It's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
    Lithium batteries also have a much longer shelf life than alkalines. And they do not corrode when unused like alkalines do. If you are looking for a battery that won't get used much but needs to work years from now, lithiums are exactly what you want.
  14. Oct 8, 2016 at 11:55 PM
    IronPeak
    AuggieX
    Back to Back
    If a concern is battery discharge and you don't mind not having the batteries in the device while being stored a solution would be to purchase a digital timer (15$) and a power strip with a few lithium battery chargers (very inexpensive 10$) and have the timer come on once every two months for a day. The batteries have a 1000+ cycle lifespan so even years won't take much life out of them. They would be ready to go for an emergency in this case. Several flashlights from the manufacturers above have usb charging built in. Where these aren't that great at charging well, you could put these on a timer, or leave plugged in and the light would be charged and ready to go with the batteries in the device for instance in your truck you could leave them plugged in, or even add an usb port to your glove or center console to keep the light in storage there.
    2016BBP[OP] likes this.
  15. Oct 9, 2016 at 12:18 AM
    #35
    faultball
    faultball Well-Known Member
    WHT2017SR5DCLB2WD
    fleshlite...yummmie. so good to be young...hehehe
    sorry could not resist.
    anyways, Fenix fan here LD60 for truck and LD75c for work.
    Joe23[QUOTED] likes this.
  16. Oct 9, 2016 at 12:26 AM
    #36
    Sixgun CO
    Sixgun CO Well-Known Member
    16 Tocoma TRD off-road
    Brand new 07-28
    Sick-o's...
    I carry a Surfire fury and a Surfire titan.
    CusterFan and IronPeak like this.
  17. Oct 9, 2016 at 12:46 AM
    #37
    HalfWayThere
    SLO, CA
    2016 DCSB TRDOR 4x4
    I didn't realize that CR123a lithium batteries could be used in place of 18650's, that's an interesting option.
    Until I looked into it, I assumed the self-discharge rate of Li-ion batteries would preclude standby use but it appears they would be fine. Having a setup where the light charges while not in use would be a great; though I wonder if the built-in chargers (especially in my price range) are sophisticated enough to prevent over-charging under those conditions (charge power cycling several times per day and significant temperature swings). I think having Li-ion batteries charging all the time in my truck would make me nervous. Anyway, there's been some good info shared and I appreciate the input.
  18. Oct 9, 2016 at 5:30 AM
    #38
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    Surefire 6px Pro, and the cheapest Black Diamond head lamp I could find.
    It'll get me by until the topper is installed.
    GSDLVR123 likes this.
  19. Oct 9, 2016 at 5:33 AM
    #39
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    I wish fenix didn't have such a ridiculous markup here in Canada. I want to get one but they're marked up way too much.
    On another note does anyone have any recommendations for a good bright headlight?
    Lately I've been finding it would be better for camping. Just not sure what to get.
    Want something that can take a all the same batteries. So something that takes a 18650
  20. Oct 9, 2016 at 7:31 AM
    #40
    rooney2oons
    rooney2oons Well-Known Member
    Dallas, Tx
    2016 TRD Off Road Silver
    Nothing yet....im a poor bastard.
    somebody has a flashlight fetish.:thumbsup:
