What kind of gas you feeding your 3rd gen taco
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 12CRZto16Tacoma, Jan 25, 2016.
  1. Jan 25, 2016 at 4:58 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Octane rating is the fuels resistant to combustion not caused by the spark or knock resistance. Higher compression ratios, forced induction, things that may cause hot spots in the combustion chamber and ignite. Having combustion not caused by the spark. This can result in pinging, piston slap, knock etc. Higher octane fuel will have a resistance to ignite in these conditions.
    Running an higher octane fuel can allow your engine to have a more aggressive timing. This can result in more power, resulting in more efficiency= more mpg. Since the best timing is found right before knock occurs, the higher octane fuel has a higher knock resistance therefore more aggresive timing can be achieved.
    But if the engine can not adapt to the fuel it's using. It will do nothing.
    Better explanation below
  2. Jan 25, 2016 at 5:06 PM
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    So, gray223, my question to you is, can the 1st, 2nd, or 3rd generation Tacoma engine adapt to the fuel it's being fed?
  3. Jan 25, 2016 at 5:07 PM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Higher octane does not "give a slightly hotter burn". It takes more heat to get it to combust, hence its resistance to knock and detonation, but when it is compressed and ignited and burned its not hotter or cooler than normal gasoline.
  4. Jan 25, 2016 at 5:15 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Ok I need to Edit my post.
    Engines are equiped with knock sensors. When the cylinder temp goes up knock somtimes occurs. i.e the gas ignites without a spark. The vehicle then compensates for this by retarding the timing and eliminating the knock. This retarding of timing takes the engine away from it optimal timing, where the best power and effiecency occur.
    So if your engine is happen to retard the timing alot from knock, then a high octane level then recommend will produce more mpg/power.
    Other wise it will do nothing but take more of your money.
    So say I have a truck that's rated for 91 but I always run the lowest grade I can find. The engine will have to retard the timing to eliminate knock coming from the less knock resistant fuel. So I switch to 91 where the truck no longer has to retard the timing from knock and can run in its optimal timing. Therefore you get better mpg then before.
  5. Jan 25, 2016 at 5:27 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Conoco 91 non-ethanol
  6. Jan 25, 2016 at 5:28 PM
    Sam B
    Sam B Well-Known Member
    Samuel
    Poway, Ca.
    16 Red DCLB TRD Sport 4x2
    none
    Corey, When it comes down to it, yes you are correct. I stated it incorrectly. By hotter burn, I was referring to the mixture compressing fully (without pre-ignition that causes knock or ping). So you would get the full benefit of the compression cycle. I have noticed a difference in a tank of 87 and a tank of 91. Was it a big difference...NO. Will it make a difference for everyone...probably not since this is not considered a high compression engine. Are we wasting our money.... yes we are being a little extravagant! But thanks for setting us straight.
  7. Jan 25, 2016 at 5:31 PM
    WOODEX M.E.
    Corey
    Maine
    Haha no worries. :thumbsup: Some of the 2nd gen guys were/are getting a lot of noise from their engines in the form of pinging and had to switch to the higher octane to stop it.
    Sterling_vH111 and JimJustJim like this.
  8. Jan 25, 2016 at 5:32 PM
    WOODEX M.E.
    Corey
    Maine
    Also reading back....sorry for sounding like an ass.
  9. Jan 25, 2016 at 5:37 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    It all comes down to, if your runing higher octane then what the manual suggest, your wasting your money.
  10. Jan 25, 2016 at 5:39 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    I wish I could do some tweaking on my Tacoma.
  11. Jan 25, 2016 at 5:44 PM
    little_mule
    little_mule Rock of the Marne
    Texas panhandle
    2016 sr5 dcsb v6 at
    that's a neat 3-d mountain, needs a few happy bushes tho
    Atowns40 and Aussiek2000 like this.
  12. Jan 25, 2016 at 5:44 PM
    Aussiek2000
    2016 Offroad AC
    That's my main timing table
  13. Jan 25, 2016 at 5:47 PM
    little_mule
    Texas panhandle
    2016 sr5 dcsb v6 at
    science, guess I was never good with graphs
    Aussiek2000 likes this.
  14. Jan 25, 2016 at 5:48 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
  15. Jan 25, 2016 at 5:51 PM
    #35
    Sam B
    Samuel
    Poway, Ca.
    none
    Corey, Now worries. We all need a little levity here and there. We are here to learn and grow(and get corrected occasionally). Really appreciate the feedback!
    addicus24 likes this.
  16. Jan 25, 2016 at 5:56 PM
    #36
    addicus24
    Thanks, gray
    gray223 likes this.
  17. Jan 25, 2016 at 6:07 PM
    #37
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    2016 Tacoma compression ratio is 11.8 to 1. That seems pretty high compression to me.
  18. Jan 25, 2016 at 6:12 PM
    #38
    Aussiek2000
    2016 Offroad AC
    That's static compression. And direct injection can make use of higher compression ratios without the need to use a higher octane
    smitty99 and little_mule like this.
  19. Jan 25, 2016 at 6:23 PM
    #39
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    I still can't believe it. It's 2016 and people still think higher octane means high performance hp adding fuel.
    Unsubbed.
  20. Jan 25, 2016 at 6:24 PM
    #40
    little_mule
    Texas panhandle
    2016 sr5 dcsb v6 at
    direct injection changes the rules, because the fuel can be introduced to the chamber quicker
