What kind of gas you feeding your 3rd gen taco
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 12CRZto16Tacoma, Jan 25, 2016.
  1. Jan 26, 2016 at 10:16 PM
    #61
    Ronin229
    Ronin229 Well-Known Member
    Clearwater, FL
    2016 Limited 4x4 Silver Sky
    Ceramic tint with Air Blue80 on front windshield and sunroof Nfab bars
    I think the compression is kind of high for 87. I find when I run 87, the engine feels sluggish and I get a tank avg of 18.5 mpg. When I run 89 or higher, the engine runs smoother, is more responsive and my tank average goes to 19.5 to 20 mpg.
    whopper likes this.
  2. Jan 26, 2016 at 10:25 PM
    #62
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    The engine is going to run at optimal levels with the factory recommend fuel.
    Heepspo and smitty99 like this.
  3. Jan 26, 2016 at 10:30 PM
    #63
    Bishop84
    Bishop84 Well-Known Member
    The old 1GR had this tidbit .
    1GR- FE engine—
    Unleaded gasoline, Octane Rating 87
    (Research Octane Number91) or higher.
    For improved vehicle performance,
    the use of premium unleaded gasoline
    with an Octane Rating of 91 (Research
    Octane Number 96) or higher
    is recommended.
    The new 2GR has this tidbit.
    Octane rating
    (Unleaded gasoline) 87 (Research octane number 91) or higher
    All modern engines advance timing as far as possible while compensating for detonation. By putting higher octane in you simply allow the ECU to push the timing further than it would with regular 87 octane.
    It makes little difference obviously as the engine was designed around 87 octane but there's cause for running 89 to 91 on a highway jaunt with lots of hills where power is tested.
    I personally wont be running premium unless I plan on leaving the city but I don't blame anyone for using one fuel or the other. As long as they understand what it does.
  4. Jan 26, 2016 at 10:40 PM
    #64
    Sdtrueblue
    Sdtrueblue Well-Known Member
    Markie B
    San Diego, CA
    2015 DCLB Sport
    6112’s/5160’s Snugtop Rebel NTG’s 265/70/17
    I find that after I wash my truck, it runs better
    :notsure:
  5. Jan 26, 2016 at 10:44 PM
    #65
    gray223
    SE Missouri
    2014 Tundra Limited
    There is an optimal timing advance for every engine. The ecu has no reason to pass that. So the factory will find the correct fuel to reach optimal timing. Going for a higher octane rating then recommended will do nothing.
    UNLESS for some reason they can not reach optimal timing advance with out very high octane fuel, and for some reason they don't list it in there manual (too expensive, not available etc). But this knowledge is unknown to me.
    Pretty much this statement in bold is only true if toyota isn't recommending the octane to provide optimal timing advance.
    MORE TIMING ADVANCE DOES NOT EQUAL BETTER PERFORMANCE. Optimal timing=optimal performance, is found right before engine knock occurs.
    Heepspo likes this.
  6. Jan 26, 2016 at 10:51 PM
    #66
    matt 157
    matt 157 Well-Known Member
    California
    2003 Black Xtra Cab 4WD SR5 TRD
    Pioneer DEH 8400 head unit/deck, Crunch 1100 watt amp, 12" Kenwood subwoofer, Kicker mids & tweeters, AllPro front tube bumper, Smittybuilt tow hooks, (welded pipe for muffle) straight-pipe, 4 orange "Raptor" lights in grill, Duratrac tires, American Eagle rims, ProComp 2" front leveling kit, Plasi-Dipped black on chrome trim, PIAA fog lights w/ in-cab switch, Unidin CB/Firestik II/8 ohm PA speaker, TRD leather 5-speed shifter knob
    I don't believe the 91 make my truck any faster than the 87. However I will say that it's a night and day difference when I'm going up a hill. Especially noticeable with the manual transmission because when I run 91 it doesn't lug nearly as bad and it holds higher RPMS easier than the 87. Also with 87 I noticed a "pinging" issue where if I gave it enough gas and lugged it I'd hear a rattling noise. Especially on hills, and that definitely goes away with the higher octane.
    (5VZ-FE 1st gen V6 engine)
  7. Jan 26, 2016 at 11:52 PM
    #67
    Bishop84
    Knock is more likely to occur with heavy load and high temps, such as highway driving, especially in my part of the world. The timing for modern engines ranges wildly if you watch it, and as you said its based on what it can get away with, and what is needed for correct clean injection, especially with the D4S. Watch the data list and you will see it will raise the timing as high as possible, and will not be able to get as high while under load, meaning anything to help it reach a higher timing makes it happy, thus more performance, even if negligible.
    I stand by, 87 city, 89-91 highway.
  8. Jan 27, 2016 at 7:20 AM
    #68
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    My MPG improves by 1.5 after waxing my vehicle... improves/reduces parasitic drag.
    .劉煒, Lawfarin, Heepspo and 2 others like this.
  9. Jan 27, 2016 at 7:41 AM
    #69
    Clearwater Bill
    Billy
    Largo Florida
    Could be the same crowd that insists on 3k oil changes........
  10. Jan 27, 2016 at 7:49 AM
    #70
    smitty99
    Scottsdale
    YUP!
  11. Jan 27, 2016 at 7:57 AM
    #71
    ToyFXR88
    ToyFXR88 Well-Known Member
    WI
    2016 MGM DCSB TRD Sport 6MT
    Dude I pull out of the car wash, and it immediately feels like I have a TRD supercharger with methanol/water injection. The thing is a fuckin hot rod. Then I hit a puddle and everything goes to shit again.
  12. Jan 27, 2016 at 8:37 AM
    #72
    snefo
    snefo Well-Known Member
    Don't do this! You pamper that that thing and it will expect daily washings and more. Then someday you will park your truck next to mine and then I will be extorted.
  13. Jan 27, 2016 at 8:39 AM
    #73
    Sdtrueblue
    Markie B
    San Diego, CA
    2015 DCLB Sport
    I totally believe you, bro!! :woot:
  14. Jan 27, 2016 at 8:49 AM
    #74
    ToyFXR88
    WI
    I think if the problem continues, I'm going to have to take it to my local dealer for investigation
    Sdtrueblue[QUOTED] likes this.
  15. Jan 27, 2016 at 8:52 AM
    #75
    GeneC
    GeneC Well-Known Member
    Maine
    2016 TRD OR Access cab
  16. Jan 27, 2016 at 9:05 AM
    #76
    Sdtrueblue
    Markie B
    San Diego, CA
    2015 DCLB Sport
    Good thing it's covered under warranty!! If a member can plow through some deep potholes while doing 50mph and get the damages repaired, Surely Toyo will cover whatever repetitive damages are resulting from it not being washed properly each week as the owner manual states our trucks should!
  17. Jan 27, 2016 at 9:08 AM
    #77
    gray223
    SE Missouri
    2014 Tundra Limited
    You clearly didn't read my post. You believe that the engine will keep advancing timing and gain performance indefinitely. They already have it tuned from the factory for optinmal performance. If it says to run 91 for better performance then yes it's true. But the sense that higher octane=more mpg and more power is not true, depends on engine.
    But I will admit I do not know much about the 3rd gen engine and not sure how far it's timing can be pushed or how close the timing is from optimal from the factory on recommends gas. My Guess would be it's not far off. But you may be right, in a way.
  18. Jan 27, 2016 at 9:11 AM
    #78
    UrbanT@co
    UrbanT@co Taco FANatic
    Craig
    Bay Area
    '16 DCSBOR 4x2
    * BAMF Grille *50% tint driver/passenger front window * NFAB steps * Bakflip F1 tonnaeu * Bed extender * Bed mat * Weathertech digital floor mats * Black reflective Tacoma tailgate decal
    Isn't the winter and summer blend gas going to have a small percentage of increased/decreased efficiency?
  19. Jan 27, 2016 at 9:18 AM
    #79
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    I would be more inclined to run 93 in the Hot Summer months. I usually run 91 Always Costco or other high tier fuel. All my V6 ford suffered from pre ignition and they were not solved by higher octane. I stoppped buying Fords after having two with pre ignition in the desert.
  20. Jan 27, 2016 at 9:23 AM
    #80
    ToyFXR88
    WI
    Wait, what?
