What kind of gas you feeding your 3rd gen taco
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 12CRZto16Tacoma, Jan 25, 2016.
  1. Jan 27, 2016 at 9:25 AM
    #81
    crzycav86
    crzycav86 Well-Known Member
    Houston
    Sorry, not true all the time. Some engines (typically with low compression ratio or using very high octane) will not knock before reaching "optimal performance". Instead the engine will loses torque with advanced timing because the compression stroke tries to push the crank "backwards". I would agree that typically a modern engine will knock before MBT (mean best torque - google it) is reached.
  2. Jan 27, 2016 at 9:47 AM
    #82
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Ok. But explain this. How does advancing the timing push the crank backwards? Retarding the timing yes because ignition happens earlier in the compression stroke.
    Heepspo likes this.
  3. Jan 27, 2016 at 9:51 AM
    #83
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Can I run 95 Unleaded in my Taco? It's only $4 a gallon here in North Scottsdale. How about 100 Low Lead aviation gas? lol
  4. Jan 27, 2016 at 9:56 AM
    #84
    smitty99
    Scottsdale
  5. Jan 27, 2016 at 9:58 AM
    #85
    gray223
    SE Missouri
    2014 Tundra Limited
    Obviously your truck will go as fast as an airplane. Cause of science and stuff.
  6. Jan 27, 2016 at 10:49 AM
    #86
    crzycav86
    Houston
    youre thinking of it backwards.. advanced timing = ignition earlier in compression stroke. retarded timing = ignition later in compression stroke
  7. Jan 27, 2016 at 10:52 AM
    #87
    jimsmithrn
    jimsmithrn Well-Known Member
    Jim
    2016 Quicksand Tacoma TRD Off Road
    My Taco begs to differ. If it's cold and I have 87 in the tank, I get around 16.5 mpg on the highway. It goes up to 19 with 93. At 50 degrees, the difference is 18 with 87 and 19 with 93. Same trips, same speed, same load, etc.
    Ronin229 likes this.
  8. Jan 27, 2016 at 10:57 AM
    #88
    jimsmithrn
    Jim
    Agreed. Once in a great while, I have to buy ethanol in the city in which I work. Truck mpg goes from 19 to 15. That stuff is horrible and is just another way to fund corn subsidies.
  9. Jan 27, 2016 at 10:58 AM
    #89
    jimsmithrn
    Jim
    I must've missed something. When I use ethanol, the mpg drops considerably. My 16-19 comparison is for regular gasoline without ethanol. The way the dead dinosaurs intended it to be.
  10. Jan 27, 2016 at 11:03 AM
    #90
    gray223
    SE Missouri
    2014 Tundra Limited
    Damn I am. I got all confused. I had it all backwards my bad.
    Ok so I understand now. The engine retards the timing so knock doesn't occur, so the ignition isn't happening to early and the flame front is expanding and pushing the piston down while it's trying to come up. This is knock. The engine needs to retard timing to eliminate knock. The higher octane fuel allows the engine to advance its timing so it can reach optimal timing.
    The questions is, does the recommends fuel octane rating aloe the engine to advance its timing for optimal performance? If it does,there is no reason to go any higher, correct?
  11. Jan 27, 2016 at 11:29 AM
    #91
    jimsmithrn
    Jim
    I think we're miscommunicating. Let me try this:
    87 octane without ethanol: I get 16.5 mpg on the highway.
    93 octane without ethanol: I get 19 mpg on the highway.
    87 octane with ethanol: I get 15 mpg on the highway.
    93 octane with ethanol: I get 16 mpg on the highway.
    So, in my experience with the 2016 Tacoma, mpg is impacted both by ethanol and octane. I have 8300 miles on the odometer at this point and have been paying close attention to the mpg/tank numbers.
    Without ethanol, octane seems to make a pretty big difference. With ethanol, I'm just helping farmers continue to grow a crop that no one wants.
  12. Jan 27, 2016 at 11:42 AM
    #92
    jimsmithrn
    Jim
    That's precisely why I try not to buy ethanol-tainted gas. I live in a county with no ethanol requirement and work in a county with mandatory ethanol. I've tried every combination. If you live in an ethanol-mandatory jurisdiction, I wouldn't spend the money on octane. The few times I've had to buy an ethanol-bastardized version of fuel, I just get the cheap stuff (87) after seeing no decent impact on mpg with 93 octane. When I can tank up at home, I get the better stuff for the 2.5 mpg. I haven't worked out the math on cost-effectiveness, but I like seeing 19 mpg vs. 16.5 mpg. With 8300 miles on the odo, 2.5 extra miles for every gallon works out to be a whole lot of extra miles driven between fill-ups.
  13. Jan 27, 2016 at 10:10 PM
    #93
    Ronin229
    Ronin229 Well-Known Member
    Clearwater, FL
    2016 Limited 4x4 Silver Sky
    Ceramic tint with Air Blue80 on front windshield and sunroof Nfab bars
    My observed increases in mpg and engine feel have been with ethanol fuel (up to 10%) just different octane. So I would think with the 3rd gen with its relatively high compression, octane has an effect on performance. Sure its safe to run it with 87, but is it "optimal?"
    Not sure what the compression difference is between the 2nd gen and the 3rd gen. Perhaps the variances in timing is more pronounced in the 3rd gen, giving it's smaller displacement, but similar power output of the 4.0.
    Either way, gas is cheap right now, so I can afford to ball out a little and run mid. Plus with the 3rd gen's wonky shift points, any perceived increase in responsiveness is always welcomed.
  14. Feb 23, 2016 at 9:11 PM
    #94
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    So I've been running mid-grade on my Taco since I picked up at the dealer. In SoCal, most mid-grades are rated at 89 octane with 87 and 91 being the low and high. So far the Taco has run great with 89 octane.
    With mainly city driving (commuting between work and home 10miles each way)
    Average range has been between 280-290 miles.
    Average MPG according to the dash has been between 15.4-15.8 MPG
    On a few occasion I did a few 20-40mile runs on the highway with cruise control and the dash showed between Avg. 18-22mpg.
    What has been strange to me is during my city commutes, I don't drive hard and the Avg. MPG readout has always stayed under 16mpg and never fluctuating that much. I tend to ignore it because I know its an Average MPG and not current.
    Here is where my story gets weird....
    I have just over 2100 miles on the odometer. Just now I went to fill up with the dash saying I had 12miles range left.
    I accidentally hit 91 octane at the pump and I didn't feel like starting it over, so I said fuk it, I'll just pump 91 this time.
    Topped off the tank with 91 octane for the first time. As soon as I pull out of the gas station the Avg. MPG jumped from 15.8 or so, to 18, then to 20 as I pulled away. A few times I hit 21 and 22 on the street. I wasn't driving any differently than before.
    For some strange reason the Avg MPG reading seemed to have woken up and updated more frequently as I accelerated and decelerated. Almost as if it was giving me real time updates.
    I haven't seen or heard of this before. What makes this weird is the timing.
    I know whatever fuel the engine was getting was not pure 91 since the fuel lines still had 89 in them. If anything it was getting a blend of 89 and 91 octane.
    Why did the Avg. MPG reading become more active after filling the tank with 91 octane? Has anyone experienced this?
  15. Feb 23, 2016 at 9:16 PM
    #95
    little_mule
    little_mule Rock of the Marne
    Texas panhandle
    2016 sr5 dcsb v6 at
    I just realized a few days ago that i have been running 86, im in texas and i dont subscribe to the octane debate. I did fill my last tank with 88. But my mileage has been exceptional with 86 so far
    Heepspo likes this.
  16. Feb 23, 2016 at 9:44 PM
    #96
    StreetTiresJay
    StreetTiresJay Well-Known Member
    Jay
    British Columbia Canada
    '16 Taco TRD Sport DBLcab Alpine White 6M
    Wife in passenger seat, not driver seat :)
    You figure the 0% ethanol increases performance? I have a friend that services tractors and chainsaws as well as other small motors. Ethanol really screws things up. Someone needs to compile a list of ethanol free gas stations...
    I'm not sure if I've been putting ethanol free in my tank. Should Say on the pump no?
    Also I don't necessarily believe higher octane improves mileage. Maybe performance but not mileage by itself
  17. Feb 23, 2016 at 9:44 PM
    #97
    StreetTiresJay
    Jay
    Probably a lack of ethanol in the fuel? Confirm this and I think we have a winner
  18. Feb 23, 2016 at 9:54 PM
    #98
    StreetTiresJay
    Jay
    I'm not a mechanic, nor do I claim that I know what I'm talking about ;) but this makes sense
  19. Feb 23, 2016 at 10:12 PM
    #99
    Heepspo
    Heepspo I wouldn't say I'm missin' it, Bob...
    Washington State
    2016 TRD OR DCSB, Prem & Tech w/JBL, Towing
    Fuel Vector D600 17" Wheels, Toyo 285/70-17 AT2 Tires, Tuff Country 52907 3" Leveling Lift, Full Katzkin Leather (Black with Platinum Stitching), SOS Concepts Streamline Front Bumper, 3M Scotchgard PPF, "no vtec 4me" BHLM, Husky X-act Contour Floor Liners, Cali Raised Faux Pro Grille, Predator Sliders, WeatherTech Mudflaps, UnderCover Ultra Flex Tonneau Cover, OEM Bed Mat, Headlight Revolution Supernova V.4 Headlights/High Beams & Carbide Canbus 2.0 Amber LED Front Turn Signal Bulbs, Salex Console Organizer, Rhino Seat Belt Extenders (removes annoying dinging), 15% Window Tint, JDM ASTAR 800 Reverse Lights, LED Interior Lighting Package, Stant Locking Gas Cap, Redline Tuning QuickLIFT PLUS Hood Struts, Gentex Compass Mirror w/Homelink, mesojdm Ultimate Turn Signals, Hondo Garage Un-Holey Dash Mount and AR15 Bolt Radio Knobs, CBoy808 Custom Bedside Decals and Flags, De-Badged Doors, Tailgate and Interior Visor Stickers.
    I can't believe people still are asking this. Isn't this common knowledge now?
    Seen multiple horsepower runs with motorcycles... and cars and there was an average of about a 1.5% loss going from regular to super unleaded in a car that takes regular.
    Regular unleaded every time. You're not "treating" your truck or cleaning the fuel system with higher octane. Most likely you're very slightly lowering the HP and mpgs.
    Just use quality gas (chevron, Shell, etc) and you'll be fine.
    Bigmikelakers likes this.
  20. Feb 24, 2016 at 4:18 AM
    #100
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    I was filling up not long ago at a pretty big, fairly new Shell station. I had always stopped at "top tier" stations thinking it must be better. As I was fueling a tanker pulled in, and before I left I struck up a conversation with the driver. I was asking him about the gas, top tier, and where he filled up his truck. He told me that all the trucks fill their tankers from the same depot. He also confirmed that he delivers the same gas to Shell that he takes to "non-top tier" stations on his route including mom-pop and others. So......the same top tier gas I was paying 5 cents per gallon more for could be bought down the street at a station not listed at top tier.
    Lawfarin likes this.
