What kind of issue is this?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Starman1251, Mar 1, 2024.
  1. Mar 1, 2024 at 5:47 AM
    Starman1251
    Starman1251 [OP] Member
    2023 icecap Tacoma SR 4x4
    My Tacoma is relatively new, bought it new, currently around the 6100 mile mark. So last night I was leaving my brothers, it turned on fine nothing different, backed out the drives way, put in in drive and started driving.
    As I turned a corner, that couldn’t have been more than a few feet from where I left, o felt the truck slow down a bit but I proceed to finish the turn at that speed. When I press the gas to keep driving after the corner I just heard the engine rev but no change in speed almost like it was in neutral, looked at the shifter to double check if maybe I hadn’t accidentally knocked it into neutral and I hadn’t, looked at the screen to make sure it said I was on drive and I was. I tried to apply gas again and same thing happened, just revved up. I braked and slapped the bitch into park and just took a second to see if anything came on and nothing did, so I put it back in a drive and it started going normally.
    has this happened to anyone? Any idea why this happened or should I be worried? I havent had a tune done, in a last post I talked about getting a pedal commander but I never went through with that.
  2. Mar 1, 2024 at 5:48 AM
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    I’d check the transmission fluid level.
    kahanabob, Guthlav, 3JOH22A and 2 others like this.
  3. Mar 1, 2024 at 7:15 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    @Starman1251:
    My '21 TRD OR auto does something similar. When I take it out for the first time, and head down my driveway (slight down slope), the torque converter doesn't immediately engage (lock up). I suspect its because there's minimal load on the drivetrain and no real demand on the transmission because of the downgrade. It does eventually lock up once I give it a bit of gas.
    IMHO it's normal behavior.
    brian2sun and Starman1251[OP] like this.
  4. Mar 1, 2024 at 7:31 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Nope……your experience is NOT normal
    Phlogiston, kahanabob and 22Coma6MT like this.
  5. Mar 1, 2024 at 7:38 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    TC shouldn't lock up till 4th I believe.
    Steves104x4 likes this.
  6. Mar 1, 2024 at 7:38 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Take it to the dealer and have the fluid level checked. There could also be and issue with the transmission valve body, programming or the torque converter. Regardless take it to the dealer to have it documented and checked over so if it becomes warranty you have a paper trail.
    This is not normal for an automatic transmission. Also, the torque converter only locks up under certain conditions typical steady state, low torque. ( it has a hydraulically controlled clutch ), it is not locked up under low speed high, high torque demand.
    TacoPacific and Clearwater Bill like this.
  7. Mar 1, 2024 at 7:39 AM
    airforceb2cc
    Don
    KCMO
    What tune do you have? I'm having some issues with KDMax right now. The truck will accelerate uncommanded and will redline between the 2-3 shift seldomly.
  8. Mar 1, 2024 at 8:49 AM
    Starman1251
    The post has been fixed, I meant to say I haven’t had a tune done. Everything is stock
    airforceb2cc[QUOTED] likes this.
  9. Mar 1, 2024 at 1:37 PM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    I agree, this is a non-issue. My truck will do this sometimes right after I pull out of my driveway too, particularly if I’m really feathering the throttle and only right after the first start after hours of sitting. It feels like it’s daydreaming for a second and snaps out of it. I drove a rental Tacoma for a week a while back and it did the exact same thing in the exact same spot and circumstances. I know 3rd gen Tacomas aren’t the only vehicle that I’ve noticed this or something similar with, when their cold either.
    OP, forget about it. You’ll only be wasting your time taking it to Toyota, having them look for a problem that doesn’t exist and they will say they can’t reproduce it 100% guaranteed anyway.
  10. Mar 1, 2024 at 1:44 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    This....
    TacoPacific and OZ TRD like this.
  11. Mar 1, 2024 at 1:47 PM
    MGMDesertTaco
    aside from having the dealer document the issue and look for a solution; any chance the drums were sticking?
    edit: parking brake cable could have been sticking too
    Chew likes this.
  12. Mar 2, 2024 at 12:42 PM
    CT Yankee
    CT
    My terminology may not be correct, but it's like this:
    Start it in the AM, turn around so I can head out, nudge it into D and a bit of the skinny pedal. I essentially coast down the slight grade of my 600' driveway. If I give more pedal it acts like it's in N for a split second until the RPMs increase enough for it to "catch" and accelerate.
    This is the only time it behaves like this - heading slightly downhill, low speed, no real demand to maintain speed (15 MPH perhaps).
  13. Mar 2, 2024 at 1:00 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    My truck has never done this.
    kahanabob likes this.
  14. Mar 2, 2024 at 6:00 PM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    This is not normal. Once you have selected a gear there should be 2 gears engaged and there should be positive acceleration when you apply the throttle. Cold or hot. If it feels like the engine rpm is increasing but the vehicle is not then you may have an issue. And the stall speed of the torque converter will be low so that will not be the issue here.
