What kind of leveling kit should I get
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bingo33, Jun 1, 2017.
  1. Jun 1, 2017 at 11:23 AM
    Bingo33
    Bingo33 [OP] Member
    Nathaniel
    2013 silver tacoma TRD OR
    Black rims Bed lights
    I'm looking for a leveling kit just to pick up the front end and even everything out but I'm not sure how much lift I want all together. It's hard to get an idea without actually seeing one and knowing how big of a lift it has
  2. Jun 1, 2017 at 11:39 AM
    Pigpen
    Dan
    Northwest Montana
    Billstein 5100 adjustable shocks with the stock coils. Set the adjustment on the second perch from bottom .85" average lift. You'll be happy.
  3. Jun 1, 2017 at 11:42 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    zh137dz likes this.
  4. Jun 1, 2017 at 11:43 AM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    for reference a top plate spacer gives you about 2x the thickness of the plate is lift in the front. So for a 2" lift you would use a 1" spacer. If you have got some miles on the truck- Just replace the shocks with 5100's is probably going to be the best way to go for you.
  5. Jun 1, 2017 at 11:55 AM
    Pigpen
    Dan
    Northwest Montana
    If you're disassembling the shocks, why not upgrade and lift at the same time?
    txtaco87 likes this.
  6. Jun 1, 2017 at 11:58 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Because it's cheaper, and will ride better since the shock isn't being preloaded. Him being a 2013 I bet his shocks are fine.
  7. Jun 1, 2017 at 12:03 PM
    Pigpen
    Dan
    Northwest Montana
    Better is subjective
    I liked the way my preloaded coils (1.75" setting) rode even more than my 885 coils - same lift, 885s ride softer.
  8. Jun 1, 2017 at 12:04 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    SPACCERSSSS BOIII
  9. Jun 1, 2017 at 12:18 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You're right, better is subjective. I should say that it will ride firmer if he were to go your route and preload the coils versus some spacers on top.
  10. Jun 1, 2017 at 1:39 PM
    a986dude
    a986dude Well-Known Member
    2006 Radiant Red Tacoma TRD Sport Double Cab
    If I may hijack the thread, where and how do you measure to see how far off level the truck is?
  11. Jun 1, 2017 at 1:40 PM
    coopcooper
    alberta canada
    from the hub to the wheel well I think
  12. Jun 1, 2017 at 2:50 PM
    Pigpen
    Dan
    Northwest Montana
    Center of hub to bottom of fender. Just remember that once you put anything in the bed, the ass end drops.
  13. Jun 1, 2017 at 4:42 PM
    justdoit
    justdoit Well-Known Member
    Colorado Springs
    22' 4x4 AC TRD Off-Road
    Just take a jack and lift it and look at it yourself.
    I have a 3+2 and I think it looks like I have a slight bro lean, can't stand it.
  14. Jun 1, 2017 at 5:04 PM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    what tires/wheels are going to run
    if stock then i would not lift the back only front
    Mine was just about 2" lower in the front so 1" would give u some rack
