What kind of problems does 4/4.25" backspacing create?
Discussion in 'Wheels & Tires' started by Joehs, Jul 12, 2011.
  1. Jul 12, 2011 at 12:25 PM
    Joehs
    Joehs [OP] Well-Known Member
    Joey
    AL
    Hey all,
    Just finishing up the suspension swap on my truck and now I'm looking into wheels and tires.
    I've got the factory baja wheels that came on the Rugged Trail edition. I've searched quite a bit trying to find the backspacing on them but nobody seems to be sure. Most people think they are 5.5". My question is, what kind of problems will I create with 4.25" backspacing, or 4" as opposed to the "ideal" 4.5" while running 285/75/16's ?
    If it makes a difference, I'm running the camburg uniball UCA's with sway away 2.0" shocks and no sway bar.
    Ideally I'd like to get out of it without having to buy spacers for these, but I just don't think I'm going to clear the UCA enough @ 5.5" backspacing.
    Opinions/comments?
  2. Jul 12, 2011 at 12:28 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    4-4.25 bs will be better than 5.5 for your UCAs. You wont need spacers
  3. Jul 12, 2011 at 12:52 PM
    Joehs
    Joey
    AL
    Ah, just to clarify, they are currently 5.5" i believe, with spidertraxx in either 1.5" or 1.25" they would be 4" or 4.25"
  4. Jul 12, 2011 at 2:58 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I would stick with the 1.25" spacers. It's true that the further your tires stick out the further they will be from the UCA, but some people with 4" backspacing have had rubbing on the OUTER edge of the tire, due to the increased arc the tires makes when turning.
  5. Jul 12, 2011 at 7:30 PM
    Joehs
    Joey
    AL
    That's what I was looking for. How bad is it going to make it at 4.25" of backspacing ? I'm trying to find the best option for my setup but seem to be finding out that it's just best and easiest to switch wheels, despite liking the baja wheels as much as I do ( not to mention being more expensive )
  6. Jul 12, 2011 at 8:05 PM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    I know when I only had 4.25" of backspacing it really caused it to burn when I peed, luckily it cleared up with the proper back spacing.
